430 challenge centerlock wheels for Scud | Page 5 | FerrariChat
Discussion in '360/430' started by SSR, Jun 14, 2010.
  1. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    Ok, had more discussions with some seriously 'hardcore' techinical engineers today regarding the ABS sensor issue. Unfortunately the guy explained to me it is a bit more complicated regarding the ABS sensor issue than first envisaged. At least on the 360 but I also suspect on the Scud and 430 you may have the issue too as I don't have the information about the exact number of teeth in a 430/430Scud wheel sensor. I think this is why you don't see this conversion normally done. Its not so straight forward as one would suspect...
    Ok, the ABS speed sensor on the road cars has 32 teeth in the sensor for a full rotation of the wheel whereas the challenge cars had a higher resolution sensor using 40 teeth. These extra teeth give the ABS system more precision so it could respond faster on the race cars than it does on the road cars.
    The problem with this ofcourse means the output of the sensor is indeed wrong for the programming of the software used in the road car abs computers. Top and bottom of this is this conversion has just got a whole lot more complicated... ;)
    Ok, here's the options we face to solve the dilemma...
    Option 1:
    1. If you have access to a F430Ch try swapping the abs ecu with the 430 Challenge ecu (and thats even that assuming its compatible with the rest of the computers, it may not be the case and sounds expensive/time consuming) - least liked option to test and could lead down even more rat holes. Least liked idea.
    2. Split the 430Ch bearings (as pictured) and use only the mounting side from the 430Ch together with the original split bearings from the road car. The bearing side from the original 360/430 bearings (which includes the correct abs toothed sensor) and then put back together. This could work (and teams have actually interchanged bearings in this way before) buts again it is not the preferred since the 2 parts normally wear evenly together (flange and mounting point) so the problem with this approach is it leads to a wear mismatch would result in noisy wheel bearings until they bed in which could be quite a while. Not the nicest option.
    3. Preferred option is to use the original ABS sensor from the original road car bearings. These can be removed and the tech I spoke to thinks there is a very good chance they can be directly swapped over onto the challenge hubs so the sensors output is correct for what the road car software is expecting.
    Summary: I'm going to drop off a road car bearing and a 430Ch bearing to their workshop to get them to attempt to do this conversion for me. If this works its the absolute best option because your re-using your original ABS speed sensor so no issues with abs sensors triggering then.
  2. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    One thing they also advised is that they always re-pack the challenge bearings with uprated grease so they last longer and resist wear better.
    Apparently the factory 430Ch bearings don't use very good quality grease so they strongly recommend during the upgrade they are kind of uprated to this better grease. I don't know what grease they actually use but its something I'm going to get them to do too.
    -T
  3. jj525
    jj525 Karting
    Feb 8, 2009
    184
    Virginia, Florida
    Please let us know when you get the spec for that bearing grease.
  4. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    #104 360trev, Jul 27, 2010
    Will try to find out.
    Also once these issues are well understood and a known quantity (if the hub required modifying) I'm going to see if I can arrange a service with the race team so they can do this conversion for other people.
    I personally don't fancy tackling the bearing conversion myself but they know what they are doing regarding bearings and have the experience to do it properly and safe.
    Another way could be an pluggable 'inline' electric signal converter which steps down the 40 teeth signal into 32 teeth signal thus allowing the computer to accept the new hubs without change. I'll make some enquires on this route too as its easier and ofcourse a lot cheaper than shipping hubs around the world!
    One way or another we will get this solved!
  5. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    360 trev you are my man!!!!
    Good info really,I will try to remove the ABS sensor today from the OEM scud bearing...
  6. kopiokosong
    kopiokosong Formula 3
    Sep 25, 2009
    2,376
    the guy who sold me the 430 challenge wheels actually suggested option 2 but my mechanic is just worried about whether the hubs can be put back together safely. he fears the fronts especially might split open at high speeds since thats apparently all thats holding the front wheels in place. trev im counting on u to show me the light!:D
  7. FQ340
    FQ340 Formula Junior
    Jul 23, 2007
    342
    istanbul
    ahmet
    Great thread, i think you will start a new tradition..
    One question thou;
    What if one have a nero Scud with gold stripes (and wheels), would these wheels look good if painted in gold?
    Can't envision it, has any of the 430C's use that or same kinda color any pics?
    But i think that color (gold) is too "chic" for challenge wheels, hope i am wrong.
  8. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    My tech will try to pull the ABS sensor tomorrow,360trev it will be very cool if you can also try this and then we can share info.
    Yes gold challenge wheels will look great in blk 430..
    Remember to do some longer A arm bolts when using Challenge wheels the ET is not very aggressive and they look like very inside the fenders...
    If this mod works will be the Mother of all 430 mods...
  9. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    #109 cwwhk, Jul 28, 2010
    430 Challenge ABS sensor has 48 teeth, not 40. For 360 series including Challenge race car and all street models such as Stradale and Modena all use the same hub bearing part #179070 and that also has 48 teeth ABS sensor.
    Below are pictures of 430C and 360C ABS sensor. As you can see they are identical. So the info you were given does not appear to be correct.
    Caveat: 430 road cars use a different hub part #194134 so possible that may use a different ABS sensor then 430C or 360C, but I some how doubt it because manufacturers like to use common parts as much as possible.
  10. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Press fit of the two hub bearing halves are not that tight. That's not what's holding the wheel in place. There is a big nut inside the hub which screws onto the front spindle or rear drive shaft. This big nut is what's holding the wheel in place. For racing, we check this nut before start of every session to make sure it has not moved. Any movement usually suggest the hub bearing is on it's last leg of service life.
  11. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    #111 360trev, Jul 28, 2010
    Thank you so much for the information! The power of the internet :)
    So, from the posted information we've established;
    1. 360 Modena
    2. 360 Spider
    3. 360 Challenge
    4. Challenge Stradale
    5. 430 Challenge*
    All the 360 range basically used the same Hubs (sku 179070).
    And now its appears that the 430 Challenge also share the same teethed ABS sensor too. [and also the same identical ball bearings themselves appear to be common between the road car bearings and the race car bearings giving the opportunity to buy a cheap road car 5-stud hub and re-use the seals and ball bearings to replace the worn ones in the challenge hubs as long (as the hub bearing carrier itself isn't worn). This appears to be a far cheaper way to re-condition your challenge hubs than simply buying a new one - the ball bearings themselves are not sold seperately from Ferrari they only sell complete hubs but road car hubs are a fraction of the cost of challenge hubs and the only difference is the 5-stud vs center lock fitment.]
    *Since cwwhk has removed and verified the number of teeth on the 430 Challenge ABS.
    **Although we haven't yet verified the magnetic resistance (someone will need to hook up a multimeter to do that).
    Thinking out loud, but if it is indeed true and the 430 Hub signals are different to 360's then perhaps this Center Lock conversion will just 'work' on a 360 easier than on a 430. Perhaps the 430 Challenge uses the older hub abs signal sensors and starting with the 430 (but not 430ch) they used a different sensor.
    I've been told the 360 and 430 wheel hubs are NOT interchangeable by a garage so it would be great to get a picture of a 430 Hub sensor. Maybe this is the reason why SSR is having a problem.
    Perhaps also this is where the conflicting information on the number of teeth is coming from.
    From the information we've been able to find out so far it seems like ;
    1. F430 Coupe
    2. F430 Spider
    3. 430 Scuderia
    All may use a different hub abs sensor (but not the 430ch which uses the original 360ch and 360 abs sensor?) Make sense?
    Finally, for anyone assembling/dissassembling the hubs, here's the correct torques they should be done back up to (verified from the workshop manuals).
    275 Nm Central pin nut
    65÷75 Nm Bearing fastening screw
    65 Nm Upper arm fastening screw
    85 Nm Lower arm fastening screw
    Also posted picture of the central pin nut (item no. 4 on the 3d diagram).
    cwwhk or (anyone else) do you have a regular 430 hub bearing off a road car that we can compare too?
    I think we are finally getting to the bottom this now!!!
  12. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    FYI...
    1241g - Weight of the 4-bolt bearing carrier & ABS sensor & lead (not the full hub assembly)
    2455g - Weight of the heavy duty center lock mount
    ~3.7kg [8.1 lbs] - Total weight PER hub bearing carrier from F430 Challenge.
    This excludes the weight of the center lock nut.
    For comparison with the 5-stud version we should weight that too [with its 5 wheel nuts] and finally the alloy wheels for a direct comparison of unsprung weight. Admittedly the Challenge wheels are 0.5" wider at both front and rear than regular CS wheels but this does allow running of even wider rubber as an option.
  13. kopiokosong
    Sep 25, 2009
    2,376
    omg seems we're close to nirvana. sorry i forget- do the 430 ch bells work on the cs also?
  14. tazandjan
    39,084
    Trev- Remember on the wheel change, you are also changing rotational inertia, which affects acceleration and deceleration, as well as unsprung weight and total weight. The closer the rotating mounting hardware is to the center of the wheel, the lower the rotational inertia, which is a funtion of the weight and radius from the center of rotation, and the better acceleration and deceleration will be. Even if the five bolt system came out slighly lighter, the decrease in rotational inertia from the center mount will offset that to some degree in overall performance.
    Taz
    Terry Phillips
  15. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    #115 SSR, Jul 28, 2010
    oem scud has 48th (my tech checked today) tomorrow I will know how many has the 430 CH ABS
  16. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    #116 360trev, Jul 28, 2010
    ABS ECU Pin out
    Pin Description
    01 Speed sensor (rear RH), Analogue input
    02 Speed sensor (rear RH), Analogue input
    03 Unused Pin
    04 Speed sensor (front RH), Analogue input
    05 Speed sensor (front RH), Analogue input
    06 Speed sensor (front LH), Analogue input
    07 Speed sensor (front LH), Analogue input
    08 Speed sensor (rear LH), Analogue input
    09 Speed sensor (rear LH), Analogue input
    10 Unused Pin
    11 K diagnosis line, Communication line
    12 L diagnosis line, Communication line
    13 Unused Pin
    14 Brake pedal switch, Digital input
    15 ECU power supply +15 (key), Power input
    16 Hydraulic unit power supply, Power input
    17 Hydraulic unit power supply, Power input
    18 Hydraulic unit power supply, Power input
    19 ECU Power supply, Power input
    20 Unused Pin
    21 Unused Pin
    22 Unused Pin
    23 Unused Pin
    24 Unused Pin
    25 Unused Pin
    26 Unused Pin
    27 Unused Pin
    28 Unused Pin
    29 CAN Line, Communication line
    30 CAN Line, Communication line
    31 Unused Pin
    SD2 Errors
    LH FRONT ABS INTAKE VALVE
    RH FRONT ABS INTAKE VALVE
    LH REAR ABS INTAKE VALVE
    RH REAR ABS INTAKE VALVE
    LH FRONT ABS EXHAUST VALVE
    RH FRONT ABS EXHAUST VALVE
    LH REAR ABS EXHAUST VALVE
    RH REAR ABS EXHAUST VALVE
    SOLENOID VALVE INPUT
    SPEED SENSOR FOR LH FRONT WHEEL: NO SIGNAL
    SPEED SENSOR FOR LH FRONT WHEEL: ITERMITTENT SIGNAL
    SPEED SENSOR FOR RH FRONT WHEEL: NO SIGNAL
    SPEED SENSOR FOR RH FRONT WHEEL: INTERMITTENT SIGNAL
    SPEED SENSOR FOR LH REAR WHEEL: NO SIGNAL
    SPEED SENSOR FOR LH REAR WHEEL: INTERMITTENT SIGNAL
    SPEED SENSOR FOR RH REAR WHEEL: NO SIGNAL
    SPEED SENSOR FOR RH REAR WHEEL: INTERMITTENT SIGNAL
    TOOTHED WHEEL TOOTH
    SCAVENGE PUMP
    BATTERY VOLTAGE
    FOOT BRAKE PEDAL SWITCH
    ECU ERROR
    PRIMARY VALVE 1
    PRIMARY VALVE 2
    PILOT VALVE 1 (USV1)
    PILOT VALVE 2 (USV2)
    CAN
    ENGINE MAINTENANCE MESSAGE
    TEMPORARY FAILURE
    CAN - DASHBOARD FAULT MESSAGE
    CAN - ENGINE REVOLUTION FAULT MESSAGE
  17. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    If you can hook up an SD3 Computer to your car I'm guessing it will be showing;
    TOOTHED WHEEL TOOTH
    The error is set when an incorrect number of "teeth" or an incorrect distance between the "teeth" is detected on the toothed wheel of one of the wheel speed sensors.
    Please post pictures of the sensor so we can compare!!
    Cheers,
    Trev
  18. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    Terry, valid points indeed.
  19. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    Ok I will post pics,but I hope that the problem will be solved changing only the ABS rings...
  20. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    #120 SSR, Jul 29, 2010
    Ok OEM scud ABS sensors are 48 th also OEM CH ABS sensors are 48 th so here I dont have a problem the only difference is that the CH plastic ring is blue and the scud plastic ring is black both are inductive type same connector.
    So maybe the reason why I got the error message was because I lifted and changed all the hubs etc.So I think I have to use the car and then scan.
    Ufff good news until here.
  21. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    Let us know how you get on. They may look similar but are they identical? I'm told they 430 and 360 wheel bearings are not interchangeable so what is the difference which stops them from working? If its not the teeth what else? Very strange.
    Are you using the sd3 to pull faults? If so what ones are being logged?
  22. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    Yes they are identical apart from the different plastic color.
    I other cars when they are lifted and they have active suspensions and you change shocks etc when putting them in the floor some codes turn on and in most cases they erase after a little trip so I think or hope this is what is the situation I will align next Monday and then test...
  23. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    #123 360trev, Aug 2, 2010
    Any news?
    Here is the picture of the socket to fit the center lock nuts..
    Its a sst, specialist service tool you can order direct from the dealer, the part number is AV3848.
    Plus an added bonus picture to illustrate the width of those enormous rear wheels next to 2 cans of Polish Tyskie beer ;) lol !
  24. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    SSR, Another question is where did you get those BBS stickers from? I need 2 sets...
    Thx,
    Trev
  25. SSR
    SSR Formula 3
    Jun 14, 2007
    1,134
    Today we made the alignment.
    FRONT
    Camber 2.5
    Toe 0 mm
    Ride Height 1 finger gap
    REAR
    Camber 2.1
    Toe 2 mm
    Ride Height 1.5 finger gap
    PSI 38 F-R
    Then corner balance.
    48% F - 52% R
    49% cross
    Adjusted the challenge bar end links.
    Then we wen to the dealer to scan all the computers,it is a 3 mille trip so nothing really important to say bat the car felt of apart from all the lights in the dash.
    Tomorrow they will scan the car and I hope we can clear all the errors.
