News
430 clutch wear, when does it need to be replaced?
Discussion in '360/430' started by forgeahead, Dec 30, 2009.
  1. forgeahead
    forgeahead F1 Rookie
    Sep 16, 2008
    4,326
    Rocky Mount, NC
    Ray
    What does the forum think is reasonable clutch wear for an '07 430 with 3000 miles on it?
    Does 15% sound about right. When do these cars usually need a clutch job? At that rate, it would be about 20k miles. Naturally, there are some variables affecting wear. I was merely wondering what the average is in the vast experience of the F-chat members.
  3. jj99c2
    jj99c2 Rookie
    Sep 28, 2004
    25
    Sammamish, WA
    Not sure what % wear is recommended for replacement.
    I just had my annual service performed and my 2005 F430 with 13.5k miles is at 15% wear (ie 85% left) so it shoudl last well beyond 20k miles.
  4. Nielsq
    Nielsq Karting
    Dec 23, 2006
    245
    NY Metro Area
    Nielsq
    My very experienced Ferrari svc. mgr. told me on can expect, on average, to need new clutch at about 20,000 miles.
  5. Challengehauler
    Challengehauler Formula 3
    Jul 28, 2008
    1,242
    NE Connecticut
    DB
    I agree....for a car that is not beaten.
    4mm is recommended replacement. The clutch position sensor will start to lose its ability to remember where the clutch is at about 4mm. The symptoms would be the car spontaneously going into neutral, and generally not shifting. (F1 only obviously)
  6. The Ape
    The Ape Formula 3
    Feb 28, 2007
    1,758
    Los Angeles
    Ape
    That's pretty much when I had to change my clutch and fly wheel.
  8. LeonG360
    LeonG360 Formula Junior
    Nov 24, 2007
    306
    Calabasas
    Also keep in mind that most of the cars do not start at 100% from the factory, usually somewhere in the mid-90's depending on how the sensor is set.
  9. Hellfrost
    Hellfrost Formula Junior
    Dec 3, 2009
    433
    Naples, FL
    Had the clutch changed recently on the 360 and it read at 17% in 400 miles. My mechanic said that 15% clutch wear is just what the computer reads so you don't end up burning the clutch at the end.
  10. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,646
    Txass
    Bill
    How long a clutch lasts is reflective of how the car is driven. I anticipate getting 30+ out of mine. You determine the life.
