430 DIY Motor Mounts | Page 2 | FerrariChat
Discussion in '360/430' started by Joegnsx, Jul 18, 2015.
  1. euro_king
    euro_king Formula Junior
    Mar 18, 2009
    758
    San Jose, Jakarta
    Jastien Weiss
    How about some weather condition? will it damage this motor mount?.Some of us that live in asia or middle east had experience super extremely hot weather and extreme humidity.
  2. Joegnsx
    Joegnsx Formula Junior
    Dec 1, 2012
    955
    Valrico, FL & Franklin, NC
    Joe Gliksman
    It gets pretty hot and humid in Florida too -- not sure if there is any correlation, but the engine compartment gets so hot, and with the mounts just a few inches from the exhaust manifolds, I really think the heat is a factor for the failure. I am thinking about adding some heat shielding.
  3. Joegnsx
    Dec 1, 2012
    955
    Joe Gliksman
    Update--had a chance to drive "spiritedly" today and there is a big difference as a result of the new motor mounts. I didn't know the feel and sounds were a problem before -- tighter and smoother shifting when pushing hard, and vibration reduced. Too bad they don't last.
    whatheheck likes this.
  4. Joegnsx
    Dec 1, 2012
    955
    Joe Gliksman
    I learned today the 458 has heat shields for the motor mounts--an improvement over the 430. This probably due to failures on the 430 and 360. I will add some to mine.
  5. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,769
    Pittsburgh, PA
    Interesting. Thanks for sharing that!
  6. m3power222
    m3power222 Formula 3
    Feb 24, 2006
    2,399
    Camas, WA
    Wilson
    Any aftermarket mounts that are better built? Suggestions on where to purchase?
  7. m3power222
    Feb 24, 2006
    2,399
    Camas, WA
    Wilson
    #32 m3power222, Aug 14, 2016
    Just replaced the motor mounts over the weekend with the help of a friend. Car is a 2006 with 19K miles.
    If you have a lift/air tools/engine lifter it is very quick to do. Took about 35 mins.
    A tip is do not tighten all the engine mount bolts until you have all the bolts/nuts on. Once they are on lower the engine and remove the engine lifter and tighten all the bolts. This way you don't have to spend anytime trying to line up any of the bolts.
    Night and day difference with the new engine mounts. Much smoother and no rattle noise at idle.
  8. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    I just what to extend a big Thank You to the OP for creating this thread and to everyone that contributed with tips and great recommendations.
    My 2006 F430 spider has 28K miles now. PPI last year identified sagging motor mounts and engine vibration at idle is now pretty bad so I will have to replace my motor mounts very soon.
    Since this thread is now almost 2 years old, wondering if anyone knows of a better aftermarket motor mount available?
    Thanks in advance,
    Dan
  9. Joegnsx
    Dec 1, 2012
    955
    Joe Gliksman
    I too wonder if there is some aftermarket option for mounts— but I think with some heat shielding, the OEM ones might last longer...
  10. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    I will go ahead and just order original part, and as suggested I will create a heat shield close to it in hoping to prolong its life.
    Thanks.
    Dan
  11. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Does anyone know torque values of the motor mount bolts?
  12. little_daz
    little_daz Karting
    Jul 28, 2012
    176
    According to the workshop manual:
    Hope this helps.
  13. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Awesome!
    Thank you!
    Dan
    little_daz and Flea7 like this.
  14. Flea7
    Flea7 Formula 3
    1,904
    PNW
    SKIM
    Dan,
    Do you need a workshop manual ??
  15. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Hi Seung,
    I have one already.
    Thanks though!
    Dan
  16. little_daz
    little_daz Karting
    Jul 28, 2012
    176
    You're welcome mate.
  17. delaney
    delaney Formula Junior
    Nov 8, 2003
    704
    St Petersburg, FL
    PETER DELANEY
    I replaced mine at 10k miles because everyone said they always go bad. Took the old ones off and couldn’t tell the difference between old/new. One caveat, car never tracked.
  18. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    I want to thank the OP and everyone that contributed to this great thread.
    I had bad engine vibration at idle and that was identified during PPI and also by the dealer when I had my car serviced.
    I cant remember the quote I received but it was pretty high.
    Based on this thread its not that difficult to replace so I tried it last weekend.
    Took me about 4 hours from start to finish taking my time.
    Summary:
    Fairly easy to replace.
    Original motor mount is cracked & needs replacing badly. See photos.
    New one looked like its heavier duty and should last longer.
    Bad vibration at idle is gone!
    Thanks!
    Dan Image Unavailable, Please Login Image Unavailable, Please Login
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login View attachment 1268738
    cpep and f355spider like this.
  19. FrankForrest
    FrankForrest Rookie
    Nov 12, 2016
    49
    Pacific Northwest
    Glen
    Do the taller, separate left and right triangle shaped engine mounts go bad too? Or just these flat, rectangular pads? My PPI states motor mounts bad but they didn't identify which ones. Thanks to this thread, I'm going to do these myself, but want to make sure I get the correct pads.
  20. Joegnsx
    Dec 1, 2012
    955
    Joe Gliksman
    I’ve only worked with the square motor mounts—and I think that’s all we are referring to...I have a bit of an update—37K miles now and had a vibration noise, so decided to check the motor mounts—they looked like new—so lasting longer than the originals. The noise was exhaust mount
    I still think exhaust heat causes the mounts to fail.....
  21. whatheheck
    Mar 27, 2006
    4,138
    Seattle, Wa
    Dan L.
    Sorry these are the only engine mounts I am aware of.
    Where are the triangle ones?
    Sent from my SM-G955U using Tapatalk
  22. FrankForrest
    FrankForrest Rookie
    Nov 12, 2016
    49
    Pacific Northwest
    Glen
