430 Scuderia Front End knock noise | Page 2 | FerrariChat
Discussion in '360/430' started by MiamiScudLover, May 4, 2023.
  1. ShineKen
    ShineKen F1 World Champ
    19,762
    Southern California
    Nostradamus
    Eurospares approved parts are from various sources, seldom their own. Some parts are from Superformance. You have no choice if it’s the only option. If there is an OE option and the price difference is marginal, 9/10 times I’m avoiding the Eurospares approved parts.
    LorenzoR likes this.
  2. LorenzoR
    LorenzoR F1 Rookie
    #27 LorenzoR, Aug 12, 2023
    Very true if no choice and I agree 100%
  3. f355spider
    f355spider F1 World Champ
    18,039
    Replacing the lower shock bushing was not the fix, according to this follow up video.
    He has since replaced all the ball joints, but is not clear if this has resolved the issue or not, as anytime you unweight the suspension by putting it on a lift, it can take a few hundred miles for the knock to return. Its been 11 months since this post with no follow up video. I emailed him tonight asking for an update. :) I have replaced all my ball joints with Hill Engineering a few years ago, and the ball joints didn't fix it.
    Since my flamboc replacements 2.5 or so years ago, my knock has returned, but it is very intermittent, and much more faint. Previously it was pretty persistent and quite loud.
  4. ttforcefed
    ttforcefed F1 World Champ
    19,241
    This seems to be a scud issue but not a 430 issue, so maybe the answer is in whatever makes the 2 different suspension wise?
  5. Jaymac
    Jaymac Formula Junior
    930
    New Hampshire
    Jeremy McCurdy
    For me, the fix was the factory-correct Molykote UN paste on the lower shock bolts, as noted in the WSM. I couldn’t believe it would be that easy, but it was. This was after replacing the upper and lower ball joints, the tie rod ends and the sway bar end links. There was still residual knocking after replacing all of the above, and I saw a recommendation for the Molykote UN, and much to my surprise and happiness, it worked!!
    collegeboy likes this.
  6. f355spider
    18,039
    What model car do you have?
  7. Jaymac
    930
    New Hampshire
    Jeremy McCurdy
    ‘03 360
  8. f355spider
    18,039
    Might be worth a try, but Scuderias have an updated bolt with a Teflon coating. I went ahead and replaced them a couple years ago...no change.
  9. Jaymac
    930
    New Hampshire
    Jeremy McCurdy
    I know the later 360’s also updated the bolt, to one coated with the MolyKote UN, so it sounds like they updated that again for the Scud to Teflon? Whatever it is, I hope you track it down and get it sorted!
  10. f355spider
    18,039
    It may be the exact same bolt. When I swapped them they looked identical...so it already had the updated ones.
  11. Jaymac
    930
    New Hampshire
    Jeremy McCurdy
    I believe mine already had the updated one as welll, but after 20 years, a fresh application of the correct Molykote did the trick! YMMV.
    f355spider and collegeboy like this.
  12. teoh2005
    teoh2005 Rookie
    Jul 28, 2005
    16
    Chicago
    Khanh
    Also replaced lower front shock bolts with Molykote paste after replacing all upper/lower ball joints and bushings on my 08 scud. Noise finally went away after trying to solve it for a few years.
    Jaymac likes this.
  13. teoh2005
    teoh2005 Rookie
    Jul 28, 2005
    16
    Chicago
    Khanh
    Was the molykote paste applied? if not may want to try, worked for me with new bolts. Knocking now gone.
    I emailed Jayemm to try the same, not sure if he's done it yet.
    f355spider likes this.
  14. Jaymac
    930
    New Hampshire
    Jeremy McCurdy
    Nice! Happy to hear it worked for you too! Hopefully it works for everyone else :D
  15. f355spider
    18,039
    #40 f355spider, Dec 2, 2024
    This stuff?
    https://www.dupont.com/content/dam/dupont/amer/us/en/Molykote/public/documents/en/MOLYKOTE_U-N_Paste_71-0117F-01.pdf
    Appear to be sold in cans or squeeze tubes.
    https://www.dupont.com/products/molykote-u-n-paste.html
    The "UN" variant seems to be a little harder to find online.
    Thought I could find it on Amazon, Grainger or Zoro...no luck. I see a seller in Poland selling it in tubes on eBay... in fact all the sellers I can find are in Europe or North Africa. One in Hong Kong. Appears to be used in the aviation industry.
    Is a little 50g tube going to be enough for both bolts?
    https://www.ebay.com/itm/395821262984?chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=395821262984&targetid=2299003535955&device=c&mktype=pla&googleloc=9189527&poi=&campaignid=21214315381&mkgroupid=161363866036&rlsatarget=pla-2299003535955&abcId=9407526&merchantid=6296724&gad_source=4&gclid=CjwKCAiA0rW6BhAcEiwAQH28IlrbPDBTEp8oe6XFNAq4JOGV05WidGCAGqwFty7osHGDHj6USMwjZBoC_sYQAvD_BwE
  16. teoh2005
    teoh2005 Rookie
    Jul 28, 2005
    16
    Chicago
    Khanh
    My shop used a 50g tube for the front bolts. Likely still have some left thx.
  17. Jaymac
    930
    New Hampshire
    Jeremy McCurdy
    Yes. I got the one from the eBay Poland seller, 50g. I have plenty left after doing all 4 bolts.
  18. f355spider
    18,039
    Thanks, I placed the order just now....might be a few weeks to receive it.
    Funny, I went for a drive on Saturday and never head any knocking at all. Intermittent nature of the problem.
    Jaymac likes this.
  19. Jaymac
    930
    New Hampshire
    Jeremy McCurdy
    It took a few weeks for mine to arrive too. I hate intermittent issues, and those that fix themselves. I just spend my drives waiting for them to return!
  20. Mario Andretti
    Mario Andretti Formula 3
    1,767
    Boston
    I am not sure why Molykote and not a modern synthetic lube, it is just a high temp lube... check specs... but anyway, if anyone wants it, I have a full 50g tube never used which I can send. Just pay me the ebay price and postage.
