430 Scuderia Headlight Hazing - Recommendations | Page 4 | FerrariChat
Discussion in '360/430' started by Iceman23, Oct 14, 2013.
  1. Iceman23
    Iceman23 Karting
    Mar 21, 2013
    173
    Miami
    Ruben Salama
    Evan
    Sorry to hear about weather. Haven't found that 458 yet but in do time.
    I'm looking for another toy say a 911 TT. Keep you posted if I get one so you can give me some advice. Stay warm and be in touch.
  2. Iceman23
    Iceman23 Karting
    Mar 21, 2013
    173
    Miami
    Ruben Salama
    #77 Iceman23, Apr 13, 2014
    Hey guys
    So I had to do some maintenance on my lights as the hazing was getting pretty bad. Did the same as last time. Used blow dryer and held same position on full heat at about .5 inch away from plastic. To start seeing difference, need to keep there about 5-10 minutes. Then improvement comes around. Attached are a few before and afters.
  3. RobertM
    RobertM Formula 3
    Apr 17, 2005
    2,456
    Weston, Florida
    Robert M
    great news !!! also I wonder if the issue is due to the carbon.... seems like this is a typical issue with the lights
  4. Iceman23
    Iceman23 Karting
    Mar 21, 2013
    173
    Miami
    Ruben Salama
    Rob,
    Not sure. I think it has a lot to do with moisture and the sealant that allows that moisture in. Just my thoughts. But hopes this helps everyone out there.
  5. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,793
    Pittsburgh, PA
    Great result. So odd though.
  6. RobertM
    RobertM Formula 3
    Apr 17, 2005
    2,456
    Weston, Florida
    Robert M
    I have not seen this on the 430 lights, only the scuds. I wonder if air gets through the carbon weave and then the air moisture gets stuck with no where to go and then creates some sort of mold ... just a thought.
  7. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    Just picked up a heat gun today. Going to give this a shot this weekend. Will post before & afters. Wish me luck....
  8. BluNart
    BluNart Karting
    Jul 2, 2013
    125
    New England, USA
    Blu
    Good luck!
  9. -CD-
    -CD- F1 Rookie
    3,830
    near the Nürburgring
    Christian
    Just try with the heat gun and it works!
    A lot of the hazing is gone.
    Finally polished the outside and the result is much more better
    than before! :)
  10. singletrack
    Mar 16, 2011
    5,793
    Pittsburgh, PA
    Question - I have Xpel on the lights. Think the heat gun is going to make that peel? Not a biggie...can just replace those little strips. My scud has this issue - which was disclosed. Doesn't bother me because I saw this thread. I also confirmed with Ferrari of San Francisco that they only see this on Scuds - has to be something with the carbon I think. I'm running my projectors the whole way across the US also to see if that helps clear it up...we will see.
  11. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    I always drive with the lights on but this hasn't done anything to reduce the hazing. Then again, you may be driving stretches longer than I have ever driven in my scud.
  12. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    #87 MaranelloDave, May 4, 2014
    Okay, tried my hand with a heat gun today. I was working in the shared garage of my condo complex and didn't have much light so I taped a flexible flashlight to the heat gun as shown in the pic below. I made sure not to cover its vents or place the light too close to the heat gun tip. I suppose I could have left the headlights on instead, but this method worked well for me.
    I used the highest heat setting on the heat gun, which is around 1,000°F. I worked the heat gun back and forth over an area of about 2-3 inches at a distance of about 3 inches so as not to focus the heat on any one spot for too long. Within 10-15 seconds, the hazing started to go transparent. You could actually see it change from frosty to clear as a wave that progressed across the inside of the light housing. Within about 5-10 minutes, the plastic lens got as clear as it was going to get. It's important to note that, once the hazing turns from frosty to nearly transparent, it will not get any better so there is no point in further heating the lens. It's about a 90% improvement, but a light "ghost" of the hazing remains. I made the mistake of trying to get the last bit of the hazing to disappear by focusing the heat gun on one spot, and this resulted in minor distortion of the surface of the lens.
    As you can see from the photos (before on top, after below), there was a huge improvement in the look of the lights. While the lenses are not "like brand new," they are good enough for me, especially considering that the alternative is to spend $3k+ per light for new ones.
  13. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,131
    TX
    TN
    Ver nice result considering that your light had significant hazing/spidering on the picture.
  14. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,131
    TX
    TN
    I am pretty sure that it is ok with the bra since the heat gun is what my clear bra guy used on my car when I had some dull scrape marks on the bra on the rocker panel due to the service guy's shoes. The spidering are also seen on the 430 but not as frequent since my dealership's body shop manager (authorized Ferrari body shop) said that it occurs on all 430, not just Scuds.
    In terms of the results with heat, I definitely think that this is a mold/fungus problem due to moisture IMO.
  15. singletrack
    Mar 16, 2011
    5,793
    Pittsburgh, PA
    Massive improvement - nice job!
    Thanks - I'm going to try this out later today and will report back...if the bra gets damaged, I'll just replace the light covers - no biggie. Appreciate the input!
  16. singletrack
    Mar 16, 2011
    5,793
    Pittsburgh, PA
    #91 singletrack, May 5, 2014
    Success! Not perfect, but a huge improvement. I also held the heat gun in one place a touch too long which led to a sort-of surface crack in the headlight. Wet sand, then polish removed it - but it was a big time sink. As long as you keep it moving, and don't get too greedy, you can realize a great improvement.
  17. singletrack
    Mar 16, 2011
    5,793
    Pittsburgh, PA
  18. singletrack
    Mar 16, 2011
    5,793
    Pittsburgh, PA
    FYI - I did have to remove the Xpel - the adhesive started to bubble up underneath after about 5 mins. No biggie - will order some new pieces and re-apply.
  19. Iceman23
    Iceman23 Karting
    Mar 21, 2013
    173
    Miami
    Ruben Salama
    Beautiful job. Glad this small technique helped. Just have to spread the good word :)
  20. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    What did you use to wet sand the surface blemish? And to polish it?
  21. singletrack
    Mar 16, 2011
    5,793
    Pittsburgh, PA
    Thanks - FYI...another relevant fact - used max setting on my heat gun which was 1100F. You want to move it about an inch per second.
  22. singletrack
    Mar 16, 2011
    5,793
    Pittsburgh, PA
    Mother's headlight restoration kit - includes a few wet sanding pags, a powerball applicator which can be used with a standard drill, and a plastic polish. It takes quite a while but is fairly idiot-proof if you follow instructions. I ended up using a porter cable and Meg's 105/205 to polish vs. the Mothers "powerball" and their plastic polish, but I'm sure that would have worked as well.
  23. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    Thanks. I'll check that out. I have a wavy spot on the surface where I got to greedy.
  24. singletrack
    Mar 16, 2011
    5,793
    Pittsburgh, PA
    #99 singletrack, May 5, 2014
  25. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,131
    TX
    TN
    Very very nice result on the hazing, but great job on polishing out the blemish due to the heat.
    I think heat can fix scuffed blemish on clear bra but only for short burst of heat but at a further distance from the bra compared to the headlight hazing and less heat since you would worry not only about the bra but also about the paint underneath the bra.
