430 Scuderia Headlight Hazing - Recommendations | Page 6 | FerrariChat
Discussion in '360/430' started by Iceman23, Oct 14, 2013.
  1. f355spider
    f355spider F1 World Champ
    18,036
    #126 f355spider, May 25, 2018
    I had one of my headlights cleaned and polished on the inside by Premier in So Cal. 2.5 years later, it still looks great. I think they charged around $800 or $900 or though. They were kinda slow, about 3 or 4 week turn around. But they disassemble the headlight and do a very thorough job. I had another headlight done by a different shop in So Ca (can't remember the name at the moment), they were faster (and cheaper, maybe $700), but did not remove all the spider webbing. They said the only way to do that is by removal of the UV coating on the inside of the lens, which they refused to do. Whatever...2 years later and it looks even worse now...will need to send it to Premier and get it done right.
  2. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    I don't know if that's true. Are you speaking from experience or speculating? Others here have replaced their lights and, to my knowledge, the spidering didn't come back. Also, there are some folks out there with headlights that never suffered from the spidering in the first place.
    I wish I knew what caused this problem. People have speculated that it's outgassing of chemicals from the carbon fiber, but no one has any proof of this. What's curious is that some people have this problem while others don't. Could be different manufacturing lots, or could be something to do with how the car is used/stored.
  3. f355spider
    18,036
    I've seen at least 10 or 11 Scuds up close, and every one with CF headlights had the problem, and every 2008 without CF headlights did not have the problem
    IcedAmericano likes this.
  4. CrazyMD
    CrazyMD Formula Junior
    Mar 10, 2012
    404
    Southern California
    Experience. But maybe something has changed. Probably the best way is to have them repaired.
  5. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    What does that mean? If you have information, it would be nice for you to share it with the group.
    Do you personally know of anyone who purchased new scud headlights that have ended up spidering?
  6. CrazyMD
    Mar 10, 2012
    404
    Southern California
    Yes, me. First set spidering. 3 years ago purchased another set to the tune of about $5k if I remember right. Same issue.
    Not going to buy headlights again. That’s for sure.
  7. MaranelloDave
    Apr 27, 2010
    2,203
    LA
    Dave
    Well that's disappointing.
  8. scudF1
    scudF1 F1 Rookie
    2,914
    Long Island, NY
    Billy
    My scud is an 08’ with the US CF package. No spidering or a haze on the headlights. No yellowing of the CF pieces in the engine compartment either (I know a lot of people who had that problem as well)
  9. Russell996
    Russell996 Formula 3
    Sep 24, 2010
    2,263
    New Forest UK
    Russell
    +1
    09 16M - no spidering or yellow carbon.
  10. dwe8922
    dwe8922 Formula Junior
    Feb 27, 2004
    401
    FL
    David
    I have a late '09 scud with CF. The car was originally sold in N. California, and headlights were replaced under warranty. That pair was fine until about 1 year after I brought it to FL, and they began to spider. I think it has something to do with the CF off gassing; I've never heard of a regular 430 having the problem. I called a shop a while back that repaired them, and it was about $2k to repair. I don't remember who it was as I lost interest at that price point. And, I wasn't confident the repair would fair any different than the originals. My engine CF is slightly milky as well....
    Subscribed to see if someone can figure out a permanent solution....
  11. koop
    koop Formula Junior
    Apr 30, 2011
    811
    I had my scud headlights cleaned out little over 2 years ago by a local body shop. They opened up the lens and polished out the inside. The headlights looked like new for awhile but the webbing has started to come back slightly. It looks like small fibers clinging to the inside of the lens, possibly from the CF material. Maybe clearcoating the CF would make for a permanent solution.
  12. tonyswfla
    tonyswfla Formula Junior
    823
    Florida
    hair dryer works the best
  13. Andy3101
    Andy3101 Rookie
    Apr 14, 2015
    10
    Florida
    Craig
  14. f355spider
    18,036
    I took a closer look at my headlight that was cleaned about 2.5 years ago by Premier Motorsports Inc and sure enough...if I look up close, I can faintly see little traces of the fibers coming back. Standing three feet away, still looks fine. Maybe at the 6 year point it may need to be redone, but still fine now. I agree that applying some sort of flat or matte finish clear over the CF maybe the permanent solution. I recall speaking with the owner at Premier and he said it would eventually come back
  15. grudk
    grudk Karting
    Mar 29, 2005
    105
    Manhattan Beach
    My 2 cents having tried the heat gun on my 09.... it helps, but the spidering is still there. It just doesn't catch the light in the same way. Seems as if you are melting the residue/inner lining a bit, and my guess is that smoothes it out and makes the 'spidering' pattern less noticeable.... not really 'clear' but improved maybe 50% IMO. Premier doesn't seem to be returning calls. There was a guy in SoCal who would disassemble by heating the unit in an oven to loosen the lens, and then polish the inside; he moved back to Europe. I'm looking into replacement.
    flash32 likes this.
  16. f355spider
    18,036
    #142 f355spider, May 20, 2025
  17. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,799
    Pittsburgh, PA
    That's what Amex Platinum is for...any issues and they just refund your money. Never had one issue.
  18. GogglesPisano
    GogglesPisano F1 Rookie
    3,105
    East Bay, California
    Joe
    It’s important to note that while founders is a new company, the guy that started it has been in the lighting business for over 20 years and lots of us are running parts from the previous brand he started with no issues.
    singletrack likes this.
  19. f355spider
    18,036
    Thats terrific for you. Not sure about all the other buyers.
  20. singletrack
    Mar 16, 2011
    5,799
    Pittsburgh, PA
    Just giving advice. Most credit card companies will do the same. Amex Plat is just the best as they will take your word for it with proper documentation and immediately refund the money while doing any investigation. If the vendor only accepted say venmo or paypal, then it would be a red flag and carry more risk.
  21. singletrack
    Mar 16, 2011
    5,799
    Pittsburgh, PA
    Yah I was going to do mine myself actually. But the outside of one of mine has a crack, so was looking for a cheap donor light to correct that. With the price of these in the gb, and the updated lighting, it was a no brainer for me. I drive my scud a lot at night, and don't have spectacular night vision, so jumping in it from a car with a modern lighting system is a bit painful.
