Has anyone experienced loss of voltage to one of the front side lights ( called position lights in handbook) The front right and rear left are fed via 5A fuse ref AF 16 and the front left and rear right are fed via 5 Amp fuse AF20- both of these lines are supplied via relay AR9. This lot being in the front luggage space. With the front right and rear left being on the same circuit, i know the circuit has a volt supply as the rear left is working, but i dont have a 12 volt supply at the front right lamp socket. Any ideas how to get to the wiring loom- is it behind the luggage compartment liner and if so how does it come out.
