#44121 is gonna get it, now. | Page 2 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by rebirthauto, Mar 1, 2008.
  1. rebirthauto
    rebirthauto Karting
    Mar 25, 2007
    161
    Saint Petersburg, FL
    Sebastien
    0. disconnect battery (makes all auto work official).
    1. remove the half-shafts (you can probably get away with only removing the diff ends, but i removed mine all the way to repack them with grease)
    2. slacken the diff mount bolts.
    3. slacken the 2 driveshaft "split splined" collar bolts thru the hole on the tranny side.
    4. support tranny w/ tranny jack
    5. support diff w/ tranny jack
    6. remove all tranny attachments
    7. remove parking brake cable attachment and let it hang. The one that joins over the drive shaft tube.
    8. remove 8 bolts closest to the tranny on the torque tube
    9. separate the tube and diff assembly from tranny by sliding it back, down and out. Make sure that you engine-tranny assembly and tube-diff assembly remain in relatively good alignment during this operation. Watch out as it is somewhat heavy and awkward to balance on the jack.
    i think that's about it. For me the half shafts were the worst part, as the previous guy that touched them had never heard of a torque wrench. They were so tight that one bolt was snapped and another i had to torch off. BTW the nuts on this assembly are captive, so that all you need to worry about is unscrewing the other end.
    Good luck
  2. 400iGuy
    400iGuy Formula 3
    1,066
    Central Florida
    Al
    Thanks. Repacking the half shafts seems like a pretty good idea given what you have to do to get the tranny out anyhow. Thank you very much for the instructions. I'm now working on how to get the car high enough to do this since I don't have a lift. I think a set of 12 ton jackstands I'm looking at that have 30 inches of lift will probably work.
    Al
  3. rebirthauto
    rebirthauto Karting
    Mar 25, 2007
    161
    Sebastien
    #28 rebirthauto, Apr 7, 2008
    Alright, sorry about being a bit under the radar here, but i've had a lot going on.
    Now, as far as progress on this car is concerned here's what has been done so far:
    1. Repaired rusted area near driver header by inserting/welding two 1" square x .125" wall tube section inside existing frame rail, and then welded a .125" thick plate over the whole thing. I may later on opt to remove this plate for a weaker one, more inconspicuous.
    2. While doing the mounts, i found that removing all headers just made alot more sense, and while at it I threw in a new reduction starter, and a set of stainless header that are approx. 1.5" instead of the 1.25" i pulled out of there. The only downside is that the bypass flanges angle didn't exactly line up, and therefore were remove (but kept in stock). On the muffler side *and this car only has the first ones installed), i built some stainless "bullet" looking bits that i then brazed in the bypass pipe to dress it up a bit. I am currently debating the use of header wrap to keep the heat off the frame extension rails.
    3. Replaced the lower front bushing, that were at this point beyond worn out.
    4. Put in a new set of ignition wires.
    5. Reassemble the drive train, and did syn-oil change on the engine, tranny, and rear end, repacked the axles, added K&N Air Filters, and changed the fuel filters.
    6. Put in MB accumulators.
    7. Charged the AC.
    8. Remove the interior, for releathering.
    9. Hired a painter/artist who has been blocking-priming-blocking this thing for the last 2 weeks.
    10. Got the back glass for it, shipped across this great nation to get to my shop in worse condition than the one we pulled off of it, after we pulled it off.
    11. Got a new air dam for it.
    12. Hired a crew to redo the seetmetal on the door bottoms ( I bet you don't have the courage to look down there, but if you do, and they are in good shape, please do yourself the favor of clearing out the drain hole for bejesus' sake).
    I'm sure i'm forgetting something, but this is a good start. Today we are at the crossroads of single stage or base coat - clear coat... you're input is appreciated.
  4. rebirthauto
    rebirthauto Karting
    Mar 25, 2007
    161
    Sebastien
    #29 rebirthauto, Apr 7, 2008
  5. pastmaster
    pastmaster Formula Junior
    Feb 5, 2006
    890
    Alma, Michigan USA
    HOLY SMOKE!!!
    Steady as you go, you are at the mid-point at least. :)
    Ciao...Paolo
  6. Pcar928fan
    Pcar928fan Formula 3
    Jan 21, 2008
    1,702
    Austin, TX
    Sebastian,
    You are ON IT man! Well done! Loving the thought of seeing a 400 back in exceptional condition! Very nice! Looks like first class work too! At the rate you are going when do you expect to finish?
    Thanks for sharing in words and photos too! Most appreciated!
    James
    Austin, TX
  7. rebirthauto
    rebirthauto Karting
    Mar 25, 2007
    161
    Sebastien
    Thank you for the kind words. I am approaching this project with a shock and awe tactic, and it seems to be working so far. Now, does anyone have pro/cons on base coat-clear coat vs. single stage paint? Please chime in.
  8. aidanparte
    aidanparte Formula 3
    Jul 18, 2004
    1,231
    You've made amazing progress so quickly - I'm stunned! What color are you going to paint it and are you changing the color of the interior? I've no clue about single stage vs base coat and clear, sorry.
    Aidan
  9. callaides
    callaides Formula Junior
    Mar 10, 2004
    815
    Detroit, MI
    Well, you don't seem to be going for the 100% concours correct finishes and all, so I think you'd be silly not to go for base and clear. That thing will sing.
    Amazing work so far.
  10. rebirthauto
    rebirthauto Karting
    Mar 25, 2007
    161
    Sebastien
    I'm going to paint it the same color in which i found it, a subtle cream w/ flat black tail and possibly flat black hood vent. We'll eventually reblack the wheels as well and polish their outside rim. As far as the interior is concerned, i've opted to go tan (front and rear seats, and door inserts) and black (everything else) while retaining the "very cool" square weave tan headliner and carpet. I really wanted to go with a tan with baseball mitt tan combo, but i thought that that combo might not be manly enough for what we're trying to do with the car. All this may nevertheless change in the next two weeks, your input is welcomed. Who knows, maybe this car will be too nice for me to keep, so i guess i should listen to you guys.
  11. SouthJersey400i
    SouthJersey400i Formula 3
    Mar 14, 2007
    1,673
    Romulus, NY (Finger Lakes)
    Ken Battle
    The Jag 2+2 was an ugly duckling; the FHC's rocked! What a difference two useless seats make. This is very different from a 308 FT$ or our 400's. IMHO
    Ken
  12. Pcar928fan
    Jan 21, 2008
    1,702
    Austin, TX
    True enough. The 400 is WAY better, but I have such a soft spot for the E-type. Mostly the FHC's and convertibles though...not so much the 2+2's.
    That 400 is really coming along too...gonna be a SWEET car when finished!
    James
    Austin, TX
  13. bjwhite
    bjwhite F1 Rookie
    4,803
    Seattle, WA
    Brian White
    Wow....really? I thought the flat black tail on the cream was ackward. I'd paint it white.
    TAN INTERIOR?!!??!?! Ugh. :) So hey, what are you going to do with the black seats/door panels? Or are you recovering? PM me, I'd be interested in picking up the black from you.
    I think the tail and interior color is obviously subjective opinion. However, I think most of us would agree that the black wheels were terrible on the car. Please re-do them in silver. :)
  14. dstacy
    dstacy F1 World Champ
    11,997
    GMT -5 & GMT +1
    Dave
    Nope, on the tail color factory correct one way on a series 2 car. You might like it another way, but if you want it to be "right" there is only one way.
  15. bjwhite
    bjwhite F1 Rookie
    4,803
    Seattle, WA
    Brian White
    I re-read this sentence about 5 times and still can't figure out what you're saying. :) In my looking, early series II cars had the black tail ala the series I. So for a series II car, you really can go either way.
    Yes? Or were these series II cars painted black at one time by owners or dealers? Or was it an orderable option for early series II cars?
  16. dstacy
    11,997
    GMT -5 & GMT +1
    Dave
    From the factory it was one way for a series 1 car and the opposite for a series 2 car. Now having said that we all know a few cars slipped through with various S1 and S2 stuff on the same vehicle. But generally it is one or the other depending on S1 or S2
  17. rebirthauto
    rebirthauto Karting
    Mar 25, 2007
    161
    Sebastien
    I'm actually recovering the interior. As far as the wheels are concerned, i'm surprised to stand alone on the wheel color, as once i saw them in person, i really dug the concept. I guess we'll see.
  18. rebirthauto
    rebirthauto Karting
    Mar 25, 2007
    161
    Sebastien
    Is there a list somewhere of the available colors for the model and year?
  19. dstacy
    11,997
    GMT -5 & GMT +1
    Dave
    Sebastien, the short answer is "no".
    In the most basic sense all Ferrari's are custom painted. Some colors were only offered during certain years, but that doesn't mean someone didn't special order a color from an earlier time.
    If you need it I have a list of almost every color Ferrari has offered through the years with the color codes. It is a very long list.
  20. dstacy
    11,997
    GMT -5 & GMT +1
    Dave
    This should give you an idea............
    ARGENTO MET 6336031
    ARGENTO NURBURG 101/C (SILVER)
    ARGENTO NURBURGRING 101/C
    AVORIO SAFARI
    AZZURRO CALIFORNIA 524
    AZZURRO DINO 5898349 (20-A-349)
    AZZURRO HYPERION 517/C
    AZZURRO MONACO 515/C
    Abete Met. Saviol
    Acquamarine Met. 722
    Amaranto "ME" It.
    Amaranto - Tetto avorio
    Amaranto 19379 It.
    Amaranto 2.443.413
    Amaranto 20-R-122
    Amaranto 20-R-188
    Amaranto 20153 S It.
    Amaranto 20576 It.
    Amaranto 21228 Acr. It.
    Amaranto 23695 It.
    Amaranto 33371 Met. Acr. It.
    Amaranto Bull Lea 2.443.413
    Amaranto LC 38 Met.
    Amaranto Met.
    Amaranto Roma 16132
    Amaranto Roma 21228 A It.
    Amaranto Savid 102
    Arancio
    Arancio 95.3.2943
    Arancio Fer 302 Glasurit
    Arancio Fly
    Arancio Vaguely
    Arancio Vaguely noble
    Arancio tipo PF
    Argento
    Argento - Tetto grigio
    Argento 1.443.030 A It.
    Argento 106-E-1
    Argento 16003 M
    Argento 18940 A
    Argento 18940 M
    Argento 2.443.009
    Argento 2.443.048
    Argento 20265 A
    Argento 25090 A It.
    Argento 6336031
    Argento 8044523 It.
    Argento Autenil 16278 MM
    Argento Auteuil Lancia 16287
    Argento Luna Savidin 20260
    Argento Met.
    Argento Met. 82421
    Argento Met. It.
    Argento le Sancy
    Avorio
    Avorio - Tetto nero
    Avorio 19375 Sint. It.
    Avorio 19377
    Avorio 19377 It.
    Avorio 19377 M
    Avorio 2.662.016
    Avorio 20-Y-153
    Avorio It. Acr. 20559
    Avorio MM 12043
    Avorio MM 13400 (Fiat 214)
    Avorio Met.
    Avorio Safari
    Avorio Safari 20-Y-546
    Avorio Savidin 4618
    Avorio Tetrarch 2.662.016
    Azzurro
    Azzurro "La Plata"
    Azzurro - Tetto grigio
    Azzurro 1.443.658 A It.
    Azzurro 106-A-29
    Azzurro 106-A-32
    Azzurro 106-A-349
    Azzurro 12241 M
    Azzurro 16229 MM
    Azzurro 16240 MM
    Azzurro 18278 M It.
    Azzurro 18940 M
    Azzurro 19278
    Azzurro 19278 M
    Azzurro 19278 M It.
    Azzurro 2.443.648
    Azzurro 2.666.101
    Azzurro 20-A-167
    Azzurro 20-A-349
    Azzurro 28288 It.
    Azzurro 28973 Acr. It.
    Azzurro 402 Fiat 16402 MM
    Azzurro 402 Fiat Met.
    Azzurro 4351
    Azzurro 4354
    Azzurro 6338005
    Azzurro Chiaro 6800
    Azzurro Dino 20-A-349
    Azzurro Duco 4354
    Azzurro Duco 4354 - Tetto 015702
    Azzurro Gladiateur 2.666.101
    Azzurro Hyperion
    Azzurro Hyperion 2.443.648
    Azzurro It.
    Azzurro It. 20336 A
    Azzurro K 2
    Azzurro La Plata 20-A-167
    Azzurro Maserati
    Azzurro Met.
    Azzurro Met. 106-A-32
    Azzurro Met. 19278 A Salchi
    Azzurro Met. 6338005
    Azzurro Met. LC 35
    Azzurro Met. glasso
    Azzurro Perlato
    Azzurro Pininfarina
    Azzurro Reale 16430 MM
    Azzurro Savid
    Azzurro Vincennes 16229
    Azzurro Vincennes 16229 MM
    Azzurro cielo 20-A-547
    Azzurro duco 4354 - tetto nero
    Azzurro ecurie de france
    Azzurro speciale
    BIANCO AVUS 100
    BIANCO AVUS 100 (WHITE)
    BIANCO POLO 905
    BIANCO POLO P 5990152 (20-W-152)
    BLU LE MANS 516/C (BLUE MET)
    BLU MEDIO MET 514/C (NOT STAN)
    BLU MIRABEAU 525
    BLU MONTECARLO 5998548 (20-A-548)
    BLU NART 523
    BLU POZZI 521
    BLU RIBOT MET
    BLU SCURO
    BLU SEBRING503/C (BLUE MET)
    BLU SERA MET FER504/C (NOTSTA)
    BLU SWATERS 513/C (BLUE MET)
    BLU TOUR DE FRANCE 522
    BSC.Met. SA4691
    Beige 12901 MM
    Beige 16260 MM
    Beige 16261 M
    Beige 16261 MM
    Beige 16536 Fiat 536
    Beige 16536 MM Fiat 536
    Beige 222-21
    Beige ICI 222 - 2153
    Biaco - Tetto grigio 12435 M
    Bianco
    Bianco - Tetto grigio
    Bianco - Tetto grigio 10319 M
    Bianco - Tetto nero 02019
    Bianco 02019 - Tetto nero
    Bianco 02019 M
    Bianco 02019 MM
    Bianco 1.441.110 A It.
    Bianco 1.443.110
    Bianco 10019 M
    Bianco 10019 MM
    Bianco 10319 M
    Bianco 10319 MM
    Bianco 10319 MM - Tetto MM 16249
    Bianco 12435 MM
    Bianco 18934
    Bianco 18934 It.
    Bianco 18934 M
    Bianco 19248 lucidato Sint. It.
    Bianco 20-W-152
    Bianco 20214 A It.
    Bianco 20414 A
    Bianco 20414 A It.
    Bianco 21257 It.
    Bianco 2405
    Bianco 28890 Acr. It.
    Bianco 29695 Acr. It.
    Bianco 435
    Bianco 6005 It.
    Bianco 95C.001 Duco
    Bianco 96-W-157
    Bianco Acr. 25416 It.
    Bianco Acr. Salchi
    Bianco Beta Duco It.
    Bianco Duco 18934
    Bianco Duco 9.53.0026
    Bianco Duco 95C-001
    Bianco Duco It.
    Bianco It. 1441110 A
    Bianco Luna Met.
    Bianco Polo 20-W-152
    Bianco Salchi 173 PF
    Bianco Saratoga
    Bianco Saratoga 19248 S
    Bianco Saratoga It. 18934
    Bianco Saratoga It. 21159
    Bianco Saratoga It. 21693
    Bianco Saratoga MM 12435
    Bianco Tetr. 1.441.110
    Bianco avorio
    Bianco avorio It. 6005
    Bianco ermellino savid 20520
    Bianco la toquet MM 13470
    Bianco latte 1631
    Bianco latte duco 1631
    Bianco luna
    Bianco neon It. 10019
    Bianco nitro
    Bianco poldaik MM 10319 - Banda blu Met. 16229
    Bianco polo
    Bianco polo 5990152
    Bianco polo 9265470
    Bianco polo Duco 9163904
    Bianco polo It.
    Bianco polo Salchi
    Blu
    Blu - L. bianco
    Blu - Tetto Bianco
    Blu - Tetto avorio 1433
    Blu - Tetto nero LC 29 MM
    Blu - striscia bianca
    Blu / giallo
    Blu / verde
    Blu 020409
    Blu 106-A-72
    Blu 11456 MM
    Blu 11467 Fiat 467
    Blu 11488
    Blu 16228 MM
    Blu 16446 Fiat 446
    Blu 18942
    Blu 18942 It.
    Blu 18942 It. - Tetto Blu scuro 18942
    Blu 19391
    Blu 19391 It.
    Blu 19391 Salchi
    Blu 2.666.901 S
    Blu 20-A-174
    Blu 20-A-185
    Blu 20100 M
    Blu 20444 S
    Blu 20444 S It.
    Blu 2049 ICI
    Blu Acapulco 2.443.631
    Blu Antille david 20527
    Blu Artico 16440 MM
    Blu Ascot 11400 (Lancia)
    Blu Caracalla 2.666.901
    Blu Caracalla 5.214.1
    Blu Chiaro 106-A-38
    Blu Chiaro Met. 106-A-38
    Blu Conan Doyle
    Blu Danubio MM 16446
    Blu Dauphine MM 12252
    Blu Dino
    Blu Dino 106-A-72
    Blu Dino 20-A-357
    Blu Dino 20-R-350
    Blu Dino 6338006
    Blu Dino Met. 106-A-72
    Blu Ferrari
    Blu Ferrari 20-A-185
    Blu Fiat
    Blu Fiat 42/494
    Blu Fiat 8v
    Blu Genziana 16229 M e banda bianca longitudinale
    Blu Genziana 16299 M
    Blu Genziana MM 16225
    Blu Genziana MM 16229 - Tetto avorio
    Blu Gladiateur
    Blu Gladiateur 2.666.101
    Blu ICI
    Blu LC 29 MM - tetto nero
    Blu Lancia 12069
    Blu Lancia 12069 M
    Blu Lancia 12069 MM
    Blu Lancia scuro
    Blu Lancia scuro 95C.6159 S
    Blu MM 015882
    Blu Met.
    Blu Met. 106-A-72
    Blu Met. 16336 MM
    Blu Met. 397A 5/5 MM
    Blu Met. Fiat 474 IVI
    Blu Met. It.
    Blu Met. speciale 23900 It.
    Blu Montecarlo 20-A-548
    Blu Montecarlo 5208548
    Blu Notte 106-A-31
    Blu Ortis 95.3.6159
    Blu Ribot 2.443.031
    Blu Ribot 2.443.631
    Blu Ribot Met. It.
    Blu Saratoga Sint. 19248 It.
    Blu Scuro 20-A-357
    Blu Scuro Dino 20-A-357
    Blu Sera
    Blu Sera 106-A-18
    Blu Sera 106-A-38
    Blu Sera 16439 MM
    Blu Sera 16439 MM - Tetto azzurro 16430
    Blu Sera 18943 It.
    Blu Sera 2.443.603
    Blu Sera 2.443.663
    Blu Sera 20100 M
    Blu Sera 20100 M It.
    Blu Sera 20264 A It.
    Blu Sera 6338012
    Blu Sera 8.296.1
    Blu Sera 99245 It.
    Blu Sera Met.
    Blu Sera Met. 106-A-18
    Blu Sera Met. 6338012
    Blu Tigullio
    Blu Tigullio 16639 Fiat 639
    Blu Tornado 12909
    Blu Tourbillon
    Blu Tourbillon 2.443.009
    Blu Tourbillon 2.443.607
    Blu Tourbillon Met.
    Blu Turchese It.
    Blu Ultrascuro 20-A-174
    Blu chiaro
    Blu chiaro 106-A-32
    Blu chiaro 19343
    Blu chiaro 19343 M
    Blu chiaro 19343 M It.
    Blu chiaro 2.443.604
    Blu chiaro 20295 A It.
    Blu chiaro 28286
    Blu chiaro Acr. 28286
    Blu chiaro Met.
    Blu chiaro speciale
    Blu cielo
    Blu duco 1433 - Tetto AV savid 4001
    Blu ecurie de france
    Blu inverno 12215
    Blu inverno giulietta sprint 12215 MM
    Blu notte
    Blu notte 18943 M
    Blu notte 18943 M It.
    Blu notte 20454 A It.
    Blu notturno 16228
    Blu olandese duco D 1353
    Blu opalescente
    Blu perlato
    Blu porpora 66426 S It.
    Blu scuro
    Blu scuro 11456
    Blu scuro 12069 MM
    Blu scuro 18942
    Blu scuro 18942 It.
    Blu scuro 18942 M
    Blu scuro 18972 It.
    Blu scuro 19391
    Blu scuro 19391 It.
    Blu scuro 2.666.854
    Blu scuro 20-A-174
    Blu scuro 20-A-185
    Blu scuro 20440 S It.
    Blu scuro 20448 S It.
    Blu scuro 20571 A It.
    Blu scuro 21211 It.
    Blu scuro 24259 It.
    Blu scuro 95C 6159 S
    Blu scuro Lancia
    Blu scuro Met. 439 savidin 4691
    Blu scuro con banda bianca
    Bordeaux 10027 M
    Bordeaux 2.664.32
    Bordeaux 20-R-351
    Bruno Acajou
    Bruno Acajou Met.
    CANNA FUC MET 703/C (DARKGREY)
    COLOR UNKNOWN
    COLOUR UPON SAMPLE
    COLOUR UPON SAMPLE
    COLOUR UPON SAMPLE Eldora
    COLOUR UPON SAMPLE blu 10336
    Caracalla 2.666.901
    Celeste
    Celeste 1.443.626 A
    Celeste 10573 - Tetto nero
    Celeste 106-A-16
    Celeste 106-A-26
    Celeste 16284 MM
    Celeste 18284 MM
    Celeste 19321 M
    Celeste 19321 M It.
    Celeste 2.443.625
    Celeste 2.443.631
    Celeste 20411 A It.
    Celeste 28974 A It.
    Celeste 6850 It.
    Celeste Gainsborough 2.443.625
    Celeste Met.
    Celeste Met. 106-A-16
    Celeste Pullman 6850 It.
    Celeste ardenza 16284
    Celeste betulla
    Celeste chiaro 106-A-26
    Celeste chiaro lancia 16300
    Colorado 106-M-73
    Colore non disponibile
    Corsa blu ICI - tetto 10702
    Crema
    EXTRACAMPIONARIO-NOT STANDARD
    Fiordo norvegese savid 20779
    GIALLO FLY 5994490 (20-Y-490)
    GIALLO MODENA 102 (YELLOW)
    GIALLO MODENA DS 4305
    GRIGIO ALLOY 750
    GRIGIO INGRID 720
    GRIGIO MET FER700/CV (NOTSTAN)
    GRIGIO SCURO MET
    GRIGIO TITANIO 3238
    GRIGIO TITANIO METALL. FQ/3238
    GRIGIO TITANIO METALL.FQ 3238
    Genziana LC 29 MM - tetto nero
    Giallo
    Giallo "prototipo"
    Giallo "stemma Ferrari"
    Giallo 13480 MM
    Giallo 2.669.028
    Giallo 826 It.
    Giallo Agip MM
    Giallo Arancio 6450 It.
    Giallo Dino 20-Y-348
    Giallo Dino 20-Y-390
    Giallo Dino 20-Y-490
    Giallo Fly
    Giallo Fly 2.229.004 It.
    Giallo Fly 20-Y-191
    Giallo Fly 20-Y-490
    Giallo Fly 5994490
    Giallo Fly It.
    Giallo Fly prototipo
    Giallo Limone 6400
    Giallo Man O'War 2.669.028
    Giallo My Swallow
    Giallo My Swallow 95.3.2643
    Giallo My Swallow It.
    Giallo Ossido 6402
    Giallo Senape 20-Y-404
    Giallo Senape 20-Y-464
    Giallo Solare
    Giallo Solare 13478 MM
    Giallo Solare A 24473 S It.
    Giallo Tango
    Giallo e Rosso
    Gold Poly
    Gold Poly 2.443.214
    Gold Poly 2.443.248
    Gold Poly 2.443.631
    Gold Poly Met.
    Grigio
    Grigio - Tetto amaranto LC 49 MM
    Grigio - Tetto beige
    Grigio - Tetto bordeaux
    Grigio - Tetto grigio 16249 M
    Grigio - Tetto grigio LC 2 MM
    Grigio - Tetto grigio LC 49
    Grigio - Tetto rsc LC 49 MM
    Grigio 106-E-1
    Grigio 1149
    Grigio 12016
    Grigio 1263
    Grigio 13420 MM
    Grigio 16202
    Grigio 16249
    Grigio 16683
    Grigio 16817 MM
    Grigio 18933 MM It.
    Grigio 18940 M
    Grigio 18940 M It.
    Grigio 2.443.931
    Grigio Acciaio brunIt.o savidin 20259
    Grigio Acr. 20266
    Grigio Acr. 28284
    Grigio Alba 13421/1
    Grigio Alba It.
    Grigio Albany 16240
    Grigio Albany 20266 A It.
    Grigio Argento
    Grigio Argento 16003
    Grigio Argento 16003 MM
    Grigio Argento 16003 con banda blu bianco rosso
    Grigio Argento 16003 con bandiera belga sulla cala
    Grigio Argento 18840 M It.
    Grigio Argento 18940 It.
    Grigio Argento 18940 M
    Grigio Argento 18940 M It.
    Grigio Argento 18940 M per tetto - Grigio notte 18
    Grigio Argento 2.443.009 A It.
    Grigio Argento 20265 A It.
    Grigio Argento 20265 Acr. It.
    Grigio Argento 21256 It.
    Grigio Argento 220
    Grigio Argento 220 LCH
    Grigio Argento 220 Salchi
    Grigio Argento 25090 A It.
    Grigio Argento 27896 It.
    Grigio Argento 28014 Acr. It.
    Grigio Argento Acr. 28617 It.
    Grigio Argento Acr. 28786
    Grigio Argento Acr. 28977 It.
    Grigio Argento Acr. It.
    Grigio Argento It.
    Grigio Argento Met.
    Grigio Argento Met. 16003
    Grigio Argento Salchi
    Grigio Argento mercedes
    Grigio Azzurro 19385
    Grigio Azzurro 19385 It.
    Grigio Azzurro K 2
    Grigio Beige 2.443.813 A It.
    Grigio Bicolore
    Grigio Camping 12004
    Grigio Camping 19249 It.
    Grigio Canna di fucile
    Grigio Chiaro 15702 MM
    Grigio Conchiglia
    Grigio Conchiglia 15702 M
    Grigio Conchiglia 16249 - Tetto grigio 16674
    Grigio Conchiglia 16249 M
    Grigio Conchiglia 16249 MM
    Grigio Conchiglia 16439
    Grigio Conchiglia 18933 It.
    Grigio Conchiglia 18933 MM It.
    Grigio Conchiglia 19175 It.
    Grigio Conchiglia 21694 It.
    Grigio Conchiglia 23992 It.
    Grigio Conchiglia VM 16249
    Grigio Conchiglia betulla
    Grigio Duco 1149
    Grigio Ferro 106-E-8
    Grigio Ferro 6336011
    Grigio Ferro Met. 106-E-8
    Grigio Fiat 1263
    Grigio Fiat 16677
    Grigio Fiat 634 D - 1263 Duco
    Grigio Florida 16665 MM
    Grigio Fumo
    Grigio Fumo 16672
    Grigio Fumo 16672 M
    Grigio Fumo 16672 MM
    Grigio Fumo 18944 M
    Grigio Fumo 18944 M It.
    Grigio Fumo 18944 MM
    Grigio Fumo 20294 A It.
    Grigio Fumo 20294 Acr.
    Grigio Fumo 20294 Acr. It.
    Grigio Fumo 20294 It.
    Grigio Fumo 20294 M
    Grigio Fumo 21266 It.
    Grigio Fumo 28285 Acr. It.
    Grigio Fumo 28285 It.
    Grigio Fumo 28806 Acr. It.
    Grigio Fumo 7798130/21
    Grigio Fumo 82481
    Grigio Fumo Acr. 27850 It.
    Grigio Fumo Acr. 28975 It.
    Grigio Fumo Acr. 29318 It.
    Grigio Inglewood 16201
    Grigio LC 2 - Tetto grigio LC 49
    Grigio LC 2 MM
    Grigio LC 49
    Grigio LC 49 - Tetto amaranto 015472
    Grigio LC 49 - Tetto verde LC 17
    Grigio LC 49 MM
    Grigio LC 49 MM - Tetto grigio LC 5
    Grigio LC 49 MM - Tetto rosso scuro Met.
    Grigio LC 7 MM
    Grigio Latte 015702 - Tetto verde 395
    Grigio Le Sancy 2.443.009
    Grigio MM 015702
    Grigio MM 15702 M
    Grigio MM LC 49
    Grigio MM LC 49 - Tetto Amaranto 015472
    Grigio MM LC 49 - Tetto Grigio Fumo 16672
    Grigio Mahmoud 2.443.931
    Grigio Mammouth
    Grigio Met.
    Grigio Met. 16003
    Grigio Met. 16201 M
    Grigio Met. 16249
    Grigio Met. 16650
    Grigio Met. 16650 M
    Grigio Met. ICI
    Grigio Met. LC 2 MM - tetto LC 49
    Grigio Met. LC 49
    Grigio Met. LC 49 - tetto LC 2 MM
    Grigio Met. LC 49 - tetto LC 5
    Grigio Met. LC 49 MM - tetto amaranto 015472 MM
    Grigio Met. MM 16201
    Grigio Met. MM 16672
    Grigio Met. MM LC 2
    Grigio Met. MM LC 37
    Grigio Met. MM LC 49
    Grigio Met. SPE 16503 L
    Grigio Met. chiaro - tetto grigio Met. scuro
    Grigio Met. speciale
    Grigio Montebello 16003
    Grigio Montebello lancia 16003
    Grigio Newmarket 16817
    Grigio Newmarket 16817 MM Acr. It.
    Grigio Notte
    Grigio Notte 106-E-28
    Grigio Notte 106-F-28
    Grigio Notte 18933 M
    Grigio Notte 18933 M It.
    Grigio Notte 18933 Salchi
    Grigio Notte 20265 It.
    Grigio Notte 20266 A
    Grigio Notte 20266 A It.
    Grigio Notte 20266 Acr. It.
    Grigio Notte 20266 It.
    Grigio Notte 20366 Acr. It.
    Grigio Notte 22666 A It.
    Grigio Notte 28284 Acr. It.
    Grigio Notte 28289 Acr. It.
    Grigio Notte 28976 Acr. It.
    Grigio Notte 29694 Acr. It.
    Grigio Ortello 2.443.613
    Grigio Ortello 2.443.813
    Grigio PF 160
    Grigio Platinato MM 16656
    Grigio Savidim
    Grigio Schell Betull
    Grigio Scuro
    Grigio Scuro 13420
    Grigio Scuro 13420 M
    Grigio Scuro 13420 MM
    Grigio Scuro 18432 It.
    Grigio Scuro 18932
    Grigio Scuro 18932 It.
    Grigio Scuro 19238 M It.
    Grigio Scuro 20-E-166
    Grigio Scuro 20108 It.
    Grigio Scuro 20152 It.
    Grigio Scuro 20152 S It.
    Grigio Scuro 20152 Sint. It.
    Grigio Scuro 24008 A
    Grigio Scuro It.
    Grigio Scuro Met.
    Grigio Scuro Met. 24008
    Grigio Scuro Sint. 18932 It.
    Grigio Scuro Sint. 28132 It.
    Grigio Scuro Sint. It.
    Grigio Scuro serie ME It.
    Grigio Scuro spec. Silverstone
    Grigio duco 1114
    Grigio medio 19248 It.
    Grigio medio 19249
    Grigio medio 20434 A It.
    Grigio medio 20434 Sint. It.
    Grigio perla MM 015702
    Grigio stilan. 16201M
    Grigio topo
    LC 49 - Tetto LC 18
    Luce bosco 2.443.550
    MARRONE MET
    Marrone
    Marrone - Tetto grigio
    Marrone 106-M-73
    Marrone 19373 It.
    Marrone 19378 It.
    Marrone 2.443.221
    Marrone 2.662.378 S It.
    Marrone 20-M-189
    Marrone 20-R-189
    Marrone 20235
    Marrone 20235 S It.
    Marrone 20325 It.
    Marrone 20325 S It.
    Marrone 20325 Sint. It.
    Marrone 6332007
    Marrone Colorado
    Marrone Colorado 2.443.221
    Marrone Met.
    Marrone Met. 106-M-73
    Maxoloid Azzurro Reale
    Maxoloid Beige Classico 16260
    Maxoloid Grigio Fumo 16672
    Molvedo 2.443.632
    Mountain blu
    NERO 1240 (BLACK)
    NERO 5991619 (20-B-619)
    NERO CARB MET 901/ (BLACK MET)
    NERO DAYTONA 910
    NERO DAYTONA WB 508
    NERO DS 1250
    NERO FER 1240
    NERO FER 1240
    NERO FER DS 1250
    NERO MET 906/C
    NERO TROPICALE
    NUOVO NERO DAYTONA 506
    Nero
    Nero - Tetto grigio saloma
    Nero 10036
    Nero 10036 MM
    Nero 11911 MM
    Nero 18656
    Nero 18656 It.
    Nero 18656 S
    Nero 18656 S It.
    Nero 18929
    Nero 18929 It.
    Nero 18929 M
    Nero 19374
    Nero 2.667.004
    Nero 2.667.004 S
    Nero 20-B-50
    Nero 20-B-50 e Verde
    Nero 20-B-619
    Nero 20581 A It.
    Nero 20581 Acr. It.
    Nero 26757 It.
    Nero 5991619
    Nero Dark Ronald
    Nero Dark Ronald 2.667.004
    Nero It.
    Nero Sint. 18656
    Nero Tropicale
    Nero Tropicale 52701
    Nero Tropicale IVI
    Nero Tropicale IVI - senza tetto
    Nero Tropicale IVI 2616
    Nero VM 10036
    Nero e Grigio
    Nocciola
    Nocciola 106-M-27
    Nocciola 16259
    Nocciola 16259 M
    Nocciola 16259 MM
    Nocciola 19379 M
    Nocciola 19397
    Nocciola 19397 M
    Nocciola 19397 M It.
    Nocciola 19397 Salchi
    Nocciola 2.443.607
    Nocciola 20451 A It.
    Nocciola 20458 A It.
    Nocciola Met.
    Nocciola Met. 106-M-27
    ORO CHIARO FER 104/C
    Oro
    Oro 16288 MM
    Oro 2.443.248
    Oro Andalusia MM 16265
    Oro Chiaro
    Oro Chiaro 106-Y-137
    Oro Chiaro 106-Y-19
    Oro Chiaro 106-Y-490
    Oro Chiaro 16213 MM
    Oro Chiaro 19410 M
    Oro Chiaro 19410 M It.
    Oro Chiaro 20450 A It.
    Oro Chiaro 20450 Acr. It.
    Oro Chiaro 6334015
    Oro Chiaro Met.
    Oro Kelso
    Oro Kelso 2.443.214
    Oro Kelso 2.443.214 It.
    Oro Kelso 2.443.625
    Oro Longchamps 16288
    Oro Longchamps 16288 MM
    Oro Longchamps Acr. It.
    Oro Nashrulleh 2.443.248
    Oro Nashrulleh 2.443.413
    Oro Nashullah
    Oro Scuro
    Ortello 2.443.813
    Prugna 20-R-549
    ROSSO BARCHETTA 312
    ROSSO BARCHETTA 320
    ROSSO CHERRY (959301)
    ROSSO CHIARO 5995190 (20-R-190)
    ROSSO CORSA 300
    ROSSO CORSA DS 322
    ROSSO CORSA DS 322
    ROSSO CORSA FER 300
    ROSSO CORSA FER 300/6
    ROSSO FER 300/9
    ROSSO FER 302/C
    ROSSO FIORANO 321
    ROSSO MET FER 305/C
    ROSSO MONZA 311/C
    RUBINO MICALIZZATO 324
    Rame 106-M-49
    Rame 106-R-49
    Rame Kupfer 23584 A It.
    Rame Met.
    Rame Met. 106-R-49
    Riverniciata su Nero Tropicale IVI - Grigio perla
    Rosso
    Rosso
    Rosso - L. bianco
    Rosso - Tetto Beige
    Rosso 02027 MM
    Rosso 10027
    Rosso 10027 MM
    Rosso 10593
    Rosso 10593 MM
    Rosso 10593 MM con tetto nero 18929
    Rosso 133-R-9
    Rosso 1477 IVI
    Rosso 16119 MM
    Rosso 169-R-26
    Rosso 19374
    Rosso 19374 It.
    Rosso 19374 M
    Rosso 19374 Sint. It.
    Rosso 19948 Acr. It.
    Rosso 2.664.901 S
    Rosso 2.664.901 S It.
    Rosso 20-R-187
    Rosso 20-R-190
    Rosso 20-R-351
    Rosso 20200
    Rosso 20200 It.
    Rosso 20200 S
    Rosso 20200 S It.
    Rosso 20200 Sint.
    Rosso 20200 Sint. It.
    Rosso Acr. 25621 It.
    Rosso Alfa Romeo It.
    Rosso Amaranto 02027 M
    Rosso Amaranto Roma 16132
    Rosso Bordeaux 10027
    Rosso Bordeaux 10027 MM
    Rosso Bordeaux 2.664.032
    Rosso Bordeaux 20-R-351
    Rosso Bordeaux MM 10027
    Rosso Cherry
    Rosso Cherry 95.3.9301
    Rosso Chiaro 5995190
    Rosso Cina
    Rosso Cina 10847 It.
    Rosso Cina 20456 It.
    Rosso Cina 20456 S
    Rosso Cina 20456 S It.
    Rosso Cina 22450 It.
    Rosso Cina 25996 It
    Rosso Cina 815
    Rosso Cina 95C 9614
    Rosso Cina Chiaro
    Rosso Cina Duco 9467542
    Rosso Cina Duco 9539614
    Rosso Cina It.
    Rosso Cina MM
    Rosso Cina MM 10593
    Rosso Cina MM 10847
    Rosso Cina MM 10847 It.
    Rosso Cina MM 17847
    Rosso Cina con banda bianca
    Rosso Cina ex MM 10847
    Rosso Cinese D 815 duco
    Rosso Cordoba
    Rosso Cordoba 106-E-7
    Rosso Cordoba 106-R-136
    Rosso Cordoba 106-R-7
    Rosso Cordoba 20-R-136
    Rosso Cordoba It.
    Rosso Corsa - Tetto nero
    Rosso Corsa 10593
    Rosso Corsa 10593 MM
    Rosso Corsa 10598 MM
    Rosso Corsa 29525
    Rosso Corsa 6504 A It.
    Rosso Corsa con banda bianco/rosso/blu
    Rosso Corsa con banda logitudinale bianca
    Rosso Dino 106-A-72
    Rosso Dino 20-A-349
    Rosso Dino 20-R-350
    Rosso Dino 5995350
    Rosso Duco 815
    Rosso Ferrari 10593
    Rosso Ferrari 20-R-187
    Rosso MM 02093
    Rosso MM 10043 - nero
    Rosso MM 10593
    Rosso MM 10953
    Rosso Maya 12441
    Rosso Maya 12441 MM
    Rosso Mercedes
    Rosso Met. 133-R-10
    Rosso Met. 16244 M
    Rosso Met. 6335010
    Rosso Met. MM 10593
    Rosso Met. MM 16213
    Rosso Met. MM 16244
    Rosso Met. Pininfarina
    Rosso Met. speciale 262
    Rosso Nearco
    Rosso Nearco 2.443.221
    Rosso Nearco 2.664.032
    Rosso Nearco It.
    Rosso Rubino
    Rosso Rubino 106-R-12
    Rosso Rubino 106-R-83
    Rosso Rubino 16119
    Rosso Rubino 16119 M
    Rosso Rubino 16119 MM
    Rosso Rubino 16213 MM
    Rosso Rubino 2.443.459
    Rosso Rubino 2.443.459 It.
    Rosso Rubino 20-R-12
    Rosso Rubino 20-R-350
    Rosso Rubino 20-Y-348
    Rosso Rubino 24747 A
    Rosso Rubino 6335009
    Rosso Rubino Acr. 19327 M It.
    Rosso Rubino It.
    Rosso Rubino MM 16119
    Rosso Rubino MM 16213
    Rosso Rubino Serie ME It.
    Rosso Rubino VM 16119
    Rosso Rubino chiaro 16213
    Rosso Rubino chiaro MM 16213
    Rosso Scuro 6503 It.
    Rosso Sint. 20200 It.
    Rosso Sir Ivor
    Rosso Sir Ivor 9539301
    Rosso Speciale 50002/95M 5208
    Rosso Toreador
    Rosso Vivo 10043M
    Rosso Vivo MM 10043
    Rosso chiaro 20-R-190
    Rosso con banda trasversale nera
    Rosso corsa
    Rosso corsa Ferrari
    Rosso e Bianco
    Rosso e Marrone - Tetto beige chiaro
    Rosso e Nero
    Rubino 106-R-12
    Rubino 16213 M
    Rubino Chiaro 106-R-12
    Rubino Chiaro 16213 M
    Rubino Chiaro 16213 MM
    SILVER MET. FER 101/C
    Savia 4008
    Shell Grey - Tetto MM LC 5
    Signal Orange Porsche
    Testa di Moro (Marrone It.)
    Turchese 2.443.214
    Turchese 2.443.632
    Turchese 23132 A
    Turchese Chiaro
    Turchese Molvedo 2.443.632
    VERDE BRITISH RACING 611
    VERDE INGLESE 606 (GREEN)
    VERDE MEDIO MET
    VERDE MUGELLO FER 608/C
    VERDE SCURO FER 603/CV (NOTST)
    VERDE SILVERSTONE 607/C
    VERDE TENUE FER 604/C
    VERDE ZELTWEG 610
    VERN.ROSSO SCUDERIA 2311
    VERNICE 106A16 CELESTE
    VERNICE 106R7 ROSSO CORDOBA
    VERNICE 133A12 BLU SERA METALL
    VERNICE 133A5 AZZURRO METALL.
    VERNICE 133A6 BLU DINO METALL.
    VERNICE 133E11 GRIGIO FERRO
    VERNICE 133E4 ARGENTO AUTEIL METALL.
    VERNICE 133G13 VERDE MEDIO MET
    VERNICE 133G14 VERDE PINO META
    VERNICE 133M7 MARRONE DINO MET
    VERNICE 133R10 ROSSO METALL.
    VERNICE 133R9 ROSSO RUBINO MET
    VERNICE 133Y15 ORO CHIARO META
    VERNICE 20G186 VERDE SCURO
    VERNICE 306 PRUGNA MET. FE 95/
    VERNICE 602 VERDE CH. MET.FE 9
    VERNICE 99R350 ROSSO DINO
    VERNICE AZZURRO FER 500
    VERNICE AZZURRO FER 502C
    VERNICE AZZURRO MET.FE 95/5898 F505
    VERNICE BLU MEDIO MET.FE95/5899 F506
    VERNICE BLU SCURO FER 510
    VERNICE MARRONE FER 303C
    VERNICE MARRONE MET. FE 95/858
    VERNICE ORO CHIARO FER 103C
    VERNICE ROSSO DINO FER 301
    VERNICE VERDE MEDIO FER 600C
    VERNICE VERDE PINO FER 601C
    Verde
    Verde "HP"
    Verde - Tetto grigio
    Verde - Tetto verde 16364 M
    Verde 106-G-21
    Verde 11330 MM
    Verde 19394
    Verde 339 lichberoid
    Verde 6012 It.
    Verde Acr. 25620 It.
    Verde BP
    Verde Bahram 2.443.546
    Verde Bahram 2.443.546 It.
    Verde Bahram It.
    Verde Blenheim 2.443.578
    Verde Bosco
    Verde Bosco 16220
    Verde Bosco 16220 MM
    Verde Bosco Savidim 75337
    Verde Bottiglia
    Verde Bottiglia 16364
    Verde Bottiglia 16364 - Tetto 16348
    Verde Bottiglia 9.537.478
    Verde Bottiglia Duco
    Verde Brillante 15533 ME
    Verde Chiaro
    Verde Chiaro - tetto Verde Scuro
    Verde Chiaro 19316 M
    Verde Chiaro 19319 It.
    Verde Chiaro 2.443.502
    Verde Chiaro Acr. 29268 It.
    Verde Dora 16348
    Verde Dora 348 Fiat
    Verde Dora MM 16348
    Verde Germoglio 20-G-465
    Verde Lip
    Verde MM 015251
    Verde Medio
    Verde Medio 106-G-29
    Verde Medio 19400 M It.
    Verde Medio 19947 A
    Verde Medio 19947 A It.
    Verde Medio 19947 M It.
    Verde Medio 2.443.561
    Verde Medio 6337013
    Verde Medio It.
    Verde Medio Met.
    Verde Medio Met. 106-G-29
    Verde Medio Met. 633.7.013
    Verde Medio Niyinsky
    Verde Medio Niyinsky It.
    Verde Met. spec. 26064 A
    Verde Pimlico 12040
    Verde Pimlico 12040 - tetto grigio 11618
    Verde Pimlico 12040 MM
    Verde Pino
    Verde Pino 106-G-30
    Verde Pino 19404
    Verde Pino 19404 M
    Verde Pino 19404 M It.
    Verde Pino 2.443.578
    Verde Pino 2.443.625
    Verde Pino 20-G-355
    Verde Pino 20453
    Verde Pino 20453 A
    Verde Pino 20453 Acr. It.
    Verde Pino 20453 It.
    Verde Pino 8.296.1
    Verde Pino Blenhrim
    Verde Pino Met.
    Verde Pino Met. 106-G-30
    Verde Pino Met. 19404 It.
    Verde SS 6630418 - Ton. 903
    Verde Salchi nitro PF 82
    Verde Savidim 20258
    Verde Scuro
    Verde Scuro 19394
    Verde Scuro 19394 It.
    Verde Scuro 19592 It.
    Verde Scuro 2.665.902
    Verde Scuro 20-G-186
    Verde Scuro 20-G-355
    Verde Scuro 20449 S It.
    Verde Scuro 20573 Acr. It.
    Verde Scuro Fiat 339
    Verde Scuro MM 10517
    Verde Scuro Sint. 20449 It.
    Verde Scuro speciale
    Verde Seabird 2.665.902
    Verde Seabird 2.665.982
    Verde Senna
    Verde Senna MM 16340
    Verde Tevere
    Verde artic 2179 IC
    Verde artic green 2179 ICI
    Verde azzurro taormina 16227
    Verde con tetto Nero Tropicale IVI (verde Fiat 113
    Verde pino 633.7.014
    Verde speciale
    Viola 106-A-71
    Viola 2.443.412
    Viola Blandford Stalvert
    Viola Blanford
    Viola Dino 106-R-71
    Viola Dino Met. 106-A-71
    Viola Met. 106-A-71
    Volpe Argentata 106-E-44
  21. rebirthauto
    rebirthauto Karting
    Mar 25, 2007
    161
    Sebastien
    Dave,
    Will you ever cease to amaze. I didn't realize the flexibility in the matter. Now, with all that wine around, i couldn't manage to spell my name right, much less gather all this info. As for the black tail, having taken the car apart, i would be extremely doubtful if it didn't come that way from the Factory. Thanks a bunch, and it is a good start to identify my color, since i can't locate the darn sticker. Do you know of some online color chart for the stuff?
    BTW my favorite is "Colore non disponibile", now run that one by your PPG rep for a match.
  22. Pcar928fan
    Jan 21, 2008
    1,702
    Austin, TX
    WOW! Dave, YOU ARE THE MAN! That is an amazing list! I am shocked by how many different colors there are!
    James
    Austin, TX
  23. bjwhite
    bjwhite F1 Rookie
    4,803
    Seattle, WA
    Brian White
    I used to think that, but there are at least two Series II cars that I've seen for sale with the black tail. 44121 and 43665 are two examples...
  24. aidanparte
    Jul 18, 2004
    1,231
    If Dave were really smart he'd have posted samples of the colors as well.
    I think the black tail looks really great. It gives the car a special design touch - I think Pininfarina got it right.
    Aidan
  25. dstacy
    11,997
    GMT -5 & GMT +1
    Dave
    My interest level in arguing this point any farther ranks slightly above having double root canal.
    Its just like the difference between the hood vent grille on a series 1 car versus a series 2 car.
    Don't listen to me I'm just some schmuck, do the research and you'll see what the answer is.
    <laughing> Everyone knows I'm not smart. Just ask my wife, she'll tell you.
    :D
