328 center console knobs? | FerrariChat
Discussion in '308/328' started by andrews308, May 13, 2014.
  1. andrews308
    andrews308 Rookie
    May 4, 2014
    46
    Cleveland
    Andrew D.
    On the 328's, where/how does one bring the center console "dial knobs" back to life? i.e. the transparent overlay in the car I'm looking at is worn/ faded where the fan and defroster knobs are.
    Can this be fixed to make look nice and new again?
  2. Rich S
    Rich S Formula Junior
    Nov 30, 2013
    501
    Monterey, California
    Rich Saylor
    I have the same problem; the issue being that the square plastic escutcheons- "faceplates" if you like- are printed or silkscreened on the outside first, with a translucent base color, then black over that. If one isn't careful, turning the round dial with your fingers rubbing the faceplate will eventually rub the paint off, resulting in a messy, smeared appearance. To make an entirely new plastic plate, if the plastic plate were just a square part with a large hole, not too hard to make a copy; but the hole is recessed, and there's a slight rim at the edge of the plastic. Such a part would have to be injection-molded in clear acrylic, then painted... or else a printed plastic cover attached (stuck on), leaving the edge to be painted somehow, or else light from the bulb underneath would spill out all around. Very tricky.
    The next option would be to remove the existing damaged paint from the plate by sanding then polishing, which would remove the very slight lip but oh well, then spray the edge (only) black, leaving the upper surface clear, and after having printed plastic film overlays made in color & black, stick them to the top of the plate. Possible BUT uneconomic unless a number of people get together to justify the setup costs involved in having printed plastic overlays made. I talked to the person who does the "Unobtanium" stuff, who agrees that unless there's a substantial order involved it wouldn't be worth the cost of setup and production.
    The last option would be to simply take off the faceplates and paint them black- that would eliminate the backlighting, but at lest the ruined paint wouldn't mar the looks of the interior.
    If anyone reading this might have an interest in going together on redoing the plates somehow, reply to this posting and see what can be done. Personally I think that having sheets of new stick-on overlays (in all 3 colors; black over light blue, yellow, orange) wouldn't cost that much IF several parties went together , and would probably work out fine. I got such a sticker from a supplier in the UK (in blue, the only one he had left), but frankly I think one could do just as well here in the USA as anywhere else! Remember, the graphics for all the plates are identical; only the base color changes, making camera-ready art really easy! Off to the printers and...
    Cheers,
    Rich
  3. andrews308
    andrews308 Rookie
    May 4, 2014
    46
    Cleveland
    Andrew D.
    I agree whole heartdly!!!!! Any one on this- please chime in!
    I gotta believe someone has done this
  4. Rich S
    Nov 30, 2013
    501
    Rich Saylor
    #4 Rich S, May 13, 2014
    OK, I've spoken to a label manufacturer who tells me that such a label can be made, for a few hundred dollars, more or less. The major cost is in the setup of course; once that's done as many sets as are needed can be cranked out. In sets of four, of course, in all 3 colors. So if (for example) 100 sets were made at $500 that would be $5 a set of four. The more the merrier!
    Right now the last one original faceplate I was able to buy cost me about $50... for one.
    Of course to make these work the faceplates would have to be removed, the old paint removed, the surface cleaned up, the center masked off then the edges painted, the masking removed and the new label applied. The adhesive and printed colors (color and black) would be on the underside of the label, with the 10 mil clear film the label is made from serving as a protective film for itself. End of story. For that price each owner should buy 2 or 3 sets as extras in case of mis-application or damage. These types of labels are commonly used in industry which is how they can be made at all, and fairly cheaply at that.
    Any one interested- keep in touch!
    Cheers, Rich
  5. Rich S
    Nov 30, 2013
    501
    Rich Saylor
    BTW, the easy way to remove the faceplate is to use a very small hex key to undo the knob setscrew (only needs to be loosened, not removed- if removed it might fall into the console, which you REALLY don't want to do!). Next, use a (metric) socket to remove the large nut holding the faceplate onto the switch, and the faceplate will lift right off. It might be stuck to the leather, but that's all. Remove carefully; it's only plastic. Do NOT try to pry up the switch itself! Also avoid letting the switch fall into the depths of the console, when the retaining nut for the faceplate is removed. If done carefully there's no need to undo the console, which is a real PITA, trust me!
    Good luck-
    Rich
    These 4 square faceplates are the only ones that can be removed without undoing the console, though.
  6. ScuderiaRossa
    ScuderiaRossa Formula 3
    2,230
    I would be interested. FYI—the early plates are flat, the later ones have a thin frame around them...
  7. Rich S
    Nov 30, 2013
    501
    Rich Saylor
    It seems that I have both. No real surprise after all these years; the only new one I got had the raised ridge around the edge.
    Although it might be possible to carefully remove the paint in the raised-edge versions of course it would be much easier to simply sand off the face to clear plastic. No more ridge, but who'd really notice? On the other hand damaged paint is pretty noticeable, isn't it?
    Anyone interested in pursuing this is invited to reply to me by email; mine is [email protected]. When I have a few folks on board I'll get serious & do some camera-ready copy to send to the outfit I spoke to for a firm quote. As I said it's the setup that costs, not printing a handful or several hundred or more. So far it looks like we might have 3 of us already; maybe as few as 10 might make things affordable, especially for typical Ferrari prices!
    As for preparing and fitting the labels, I could probably do a set of 4 in an hour or so, should anyone rather have it done for them.
    Cheers,
    Rich
  8. andrews308
    andrews308 Rookie
    May 4, 2014
    46
    Cleveland
    Andrew D.
    I am interested. I think that getting them made is a no brainer.
    I am in for 4 sets- and if you want I will send you A check or cash prior to
    Ordering them.
    I just talked to Ricambi and for 328 these are no longer available.
  9. craiggo
    craiggo Formula Junior
    418
    Redwood City
    Craig
    I'd be game for a complete set also.
    Craig
  10. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,182
    Atlanta
    Tom Spiro
    So I have the same problem - would love a new set as well, but my solution was a bit cheaper and DIY...
    My A/C control was looking bad, so i found a good picture of one and then printed it on a Stcker page - and then cut them out ... and applied it to top of the face plate, painted the edges.
    so at night you can still see the blue, but its not as bright, but looks very good to me.... not concours but nice. I cant find the file but when i do I'll post a pic.
  11. Rich S
    Nov 30, 2013
    501
    Rich Saylor
    Hi, I'll do some artwork, talk to the label company, & get back to you.
    Cheers, Rich
  12. Tricycle
    Tricycle Formula Junior
    Dec 21, 2004
    636
    LA Cnty 4,083sqmiles
    Hey all
    I am also interested in this. Has this gone anywhere?
    Can you find the original Pantone # for the three colors? I sure all of ours have faded to different hues by now.
  13. Rich S
    Nov 30, 2013
    501
    Rich Saylor
    Well, so far it hasn't gone anywhere yet. As for myself, I'm still mulling over ideas on how to reproduce the clear plastic faceplate, then have two two overlays done- one in color, the other in black. A mold can be made of the original faceplate, then injection castings made, but it's very expensive to do and I'd need to have buyers lined up to support the costs involved. The other issue is that there were at least two types of faceplates made- one with just a flat upper surface, and the second one having a ridge around the edge, like a "picture frame" surrounding the top. The latter was apparently supplied to later cars; I have examples of both types.
    So- stuck for now. If anyone wishes to discuss the issue they can contact me at [email protected]!
    Cheers,
    Rich
  14. thoke
    thoke Karting
    Jul 31, 2011
    136
    Ridgway CO
    T.Hoke
    #14 thoke, Jan 9, 2015
    It appears that the root cause of this is the OE knobs. They’re small/short and cause the finger tips/nails to rub on the faceplate when making adjustments. Also, the position indicator needle will sometimes scratch the surface. We can replace the faceplates (if they somehow become available again), but the replacements will also become scratched if the root cause of the problem continues. Taking a preventative measure on this issue, I made some new knobs. They’re slightly larger in diameter and taller to prevent my finger tips from touching the faceplates. Much easier to rotate and no more worry about ruining the OE faceplates. It’s a simple mod and takes only a few minutes to replace the old knobs. For concours events or when it’s time to sell the car, it’s very easy to change back to OE. Made a few extra sets when having the parts machined – they’re listed on ebay. A few sets with smooth surfaces and a couple sets with knurled surfaces.
    Auraraptor likes this.
  15. LostAussie
    LostAussie Formula Junior
    Jun 13, 2013
    727
    Piemonte
    Stuart
    Damn, that's a really smart idea. They don't even look out of place.
  16. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,185
    So. CA & NV
    Peter
    I would be in for a yellow and blue plate. I've been looking around and haven't been able to find them anywhere. In the cars being parted out, IF they have them, they want to sell the plate with the switch.
  17. Yo328
    Yo328 Karting
    Jul 26, 2014
    181
    Brentwood CA
    Yoram Limor
    I would love to have some for down the road when mine show wear.
  18. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Rich,
    Count me in for a set - flat style. Let's proceed with the project.
    -Paul
  19. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Rich - any update?
  20. Rich S
    Nov 30, 2013
    501
    Rich Saylor
    Not yet. However with the interest seen so far it might be a good idea to proceed with some real quotes. As I see it the real difficulty is the clear plastic molded faceplates themselves; or else the only other direction would be to have thin plastic overlay "labels" made in the various colors, then apply then to the original molded plates. Then there's the issue of whether or not to go with the flat faceplate design or the one with raised edging; I have both- my 328 (an '86) has the all-flat face, but the only new replacement plate I found was the raised one, in orange/black, for a later car. "88 or '89? I don't know.
    If the consensus is to restore the original plates with an overlay piece, it night be possible to have them cut 2 ways- to fit over the entire surface, edge to edge, and also to fit within the raised edge type. To sand off the paint from the original flat plate would be easy, but less so on the raised edge type, which would involve scraping paint off the middle,with an xacto knife or something. Or else sand it flat and be done with it. Making the stick-on labels is of course much less difficult and expensive; making the entire part- new- would be a lot more expensive, but anything can be done if the financing is there. I could most likely interest one of the aftermarket suppliers in committing to buying all new parts- in full sets, of course, even though many owners would only want a few, but then again if there are slight differences between new & old it would be best to change all 4, yes? So- if that's the consensus, fine, but first I'll have to get prices and minimum quantities.
    Input, guys? BTW I really like the look of the new, taller knobs! Nice job!
    Cheers,
    Rich
  21. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Personally, I'm interested in the overlays, but either way is better than what's available today (nothing)....
  22. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Beautifully done!
  23. TrojanFan
    Nov 17, 2008
    5,185
    So. CA & NV
    Peter
    I don't know enough about 3D printing, but can pieces be made in clear with that process? If so we could then may an over lay in the appropriate color and then a black one over that.
    As a temporary measure, I completely sanded one of mine to the clear plastic, painted the color on the back of the piece and then made a photo copy of a piece onto a sticker, placed it on the top and used a hobby knife to cut everything away leaving a sticker over the clear part. I then painted it black and peeled off the remaining sticker portion. Not perfect but looks OK for a temporary piece until a better method is found. The weak link is how good you are with a hobby knife in cutting out the pattern.
  24. Tricycle
    Dec 21, 2004
    636
    #24 Tricycle, May 28, 2015
  25. marklintott
    marklintott Formula Junior
    585
    Taipei Taiwan / Somerset UK
    Mark Lintott
    Love these - they look better than original!
    PM sent just in case you have any....
    Cheers
    Mark
