Installing cargo cover | FerrariChat
Discussion in '308/328' started by uberlink, Jun 28, 2014.
  1. uberlink
    uberlink Formula Junior
    Apr 23, 2012
    777
    Twin Cities, MN
    Mark Johnson
    Bought one of those new zippered cargo covers for $175 on eBay. No instructions came with, and mine is entirely missing so I don't have a example to follow. Can someone explain how it's done and maybe post a picture? Is it just held in by the weather stripping back there?
  2. Glassman
    Glassman F1 World Champ
    What the heck is a cargo cover. Are you talking about the bag you put the GTS roof into and set behind the seats?
  3. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
    #3 Alfer, Jun 28, 2014
    assembling a new cover is easy but getting is cosmetically right, say tightly, requires patience.
    I have done it because the zipper needed to be replaced so i replaced the original cover that showed clearly where it was originally folded over the rim.
    The vinyl cover is just folded over the rim around the bagace space and clamped by the rubber that fits on top of that, as you can see on the pics below. Unfortunately will you discover that the vinyl cover is a bit tight(small) making that you puzzle a bit until you find the balance between left-right and front-rear.
    Just use ductape to keep the cover in place. I did not remove the duc tape after since I cutted the width to be fully covered by the rubber.
    Success and have fun!
    Menno
  4. GatorFL
    GatorFL Moderator
    Moderator Owner
    Nov 18, 2005
    17,086
    Wellington, FL
    Duane
    I think he is talking about the zippered cover that fits over the trunk behind the engine.
    Any decent interior guy can install it.
  5. Glassman
    Oh..........Duh!!!!
  6. uberlink
    Apr 23, 2012
    777
    Twin Cities, MN
    Mark Johnson
    Thanks so much. This is exactly what I needed.
  7. chrisbinsb
    chrisbinsb F1 Rookie
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    I used those large black paper clip things to get it places pretty much as I wanted then started working the new rubber strip in over it. Hardest part was getting it pressed down as it was pretty tight. If you are re-using your existing rubber strip it should be easier I would guess
  8. Rifledriver
    37,288
    Thats how I do it but it is supposed to be glued in place. With the spring clips I take a few off and using contact cement glue it in small sections.
  9. Albert-LP
    Albert-LP F1 Veteran
    8,187
    around Modena, Italy
    Alberto Mantovani
    i have the trunk cover but the zipper is not working well: i'm wondering if the zipper can be fixed/changed without changing all the cover and doing all this mess.
    ciao
  10. GordonC
    GordonC F1 Rookie
    4,166
    Calgary, AB, Canada
    Gordon
    #10 GordonC, Jun 29, 2014
    Agreed, from posts here I gathered that a thin bead of adhesive is used around the lip - I used Goop. I installed the eBay cover last month, here's a few photos from that job. I used the binder clips to get the positioning and tension correct, then as Brian advises, removed the clips 1 or 2 at a time to allow short lengths to be glued and the seal strip pushed over top.
    This is a really good time to replace the seal strip, if the rubber seal is worn out and tearing or separating!
    Starting point - the original trunk cover, with failed zipper. To remove, you need to remove two Phillips screws by each latch, and remove the seal strip. The old cover is then peeled off the lip (you'll note the original is glued in place)
  11. GordonC
    GordonC F1 Rookie
    4,166
    Calgary, AB, Canada
    Gordon
    #11 GordonC, Jun 29, 2014
  12. GordonC
    GordonC F1 Rookie
    4,166
    Calgary, AB, Canada
    Gordon
    #12 GordonC, Jun 29, 2014
    Here's the new cover being positioned with the binder clips. (You can see the roll of new trunk seal waiting to be installed.) The key to positioning is to get the latch openings properly located, then work out from there. It helps to have a good look at how the old cover's latch openings are positioned before removing the old cover.
    Once you have the new cover positioned, you can screw in the Phillips screws by each latch.
  13. Albert-LP
    8,187
    Alberto Mantovani
    very useful, Gordon: thank you very much.
    ciao
  14. GordonC
    GordonC F1 Rookie
    4,166
    Calgary, AB, Canada
    Gordon
    #14 GordonC, Jun 29, 2014
  15. bigodino
    bigodino F1 World Champ
    13,198
    The Netherlands
    Peter den Biggelaar
    If it's just the zipper you could go for new zippers instead of a completely new cover. Search Zlideon on Ebay and you'll find them. I've used them and it works great.
    They come in different sizes, colours and shapes. Be sure to get the right size: 5A.
    Best, Peter
  16. Albert-LP
    8,187
    Alberto Mantovani
    Thanks, Peter
    Ciao
  17. Tricycle
    Tricycle Formula Junior
    Dec 21, 2004
    636
    LA Cnty 4,083sqmiles
    Peter,
    Are you sure it is 5A?
    I only see 5 on ebay or amazon and 5A-2 when I google search.
    http://www.zlideon.eu.com/HowToMeasureZlideon/tabid/316/Default.aspx
  18. Alfer
    Alfer Formula 3
    Sep 4, 2007
    1,360
    NH/the Netherlands
    Menno
    I dare to say that I was years ago likely the 1st to find this solution BUT it only worked for about a year at my 328. Than I discovered that the plastic zipper (not the clip) was too much worn and I replaced the long zipper at a cloth repair shop that had experience with leather jackets (also tough material for a needle). The new zipper came from a camping/outdoor shop in the same width, colour and model but it was meant to be used for a sleeping bag since these also have 2 zippers moving in opposite direction however so i had to take a clip off to reverse it taking at least 2 minutes. This I did years ago.
  19. newark_308
    newark_308 Karting
    213
    Newark DE
    Glenn Frenck
    Just got one of these for Christmas from my daughters, the seal came off easy, but from reading your message not sure how to peal up the glued vinyl. It's on and doesn't show any signs of coming off when tugged on. Admittedly gently tugged on.....
    Any tips on getting the glued on vinyl off?
  20. newark_308
    newark_308 Karting
    213
    Newark DE
    Glenn Frenck
    Any tips about how to get the old cover off? Did you cut and leave it folded over the lip and glue the new one over it? Any and all tips welcomed
  21. URAS
    URAS Formula Junior
    Oct 17, 2014
    955
    Canada
    vince
    I haven't tried it myself, but one owner said he used his wife's steamer, placed the nozzle closed to the fabric opening and kept on steaming and pulling. The steam loosens the adhesive on the fabric.
  22. wkumari
    wkumari Karting
    Jul 15, 2011
    169
    Northern Virginia
    Warren
    Where are folk getting the seal / what size seal works?
    I have an issue where the weather stripping / seal is a bit too high - I've adjusted the trunk mechanism (and U bolts) as far as they will safely go, but it still requires me *really* pushing on the trunk lid to close it.
    I did find that some of the little metal "fingers" inside the seal had bent into the channel at the corners, and were stopping the seal from going all the way down, but even after removing them, and hitting the seal into place with a rubber mallet hasn't fully fixed it -- I think my rubber seal is just too tall...
    W
  23. bigodino
    13,198
    The Netherlands
    Peter den Biggelaar
  24. chrisbinsb
    Oct 20, 2011
    3,675
    Santa Barbara
    Chris B
    I had the same issue with mine - best I could do was adjust the bolts and it would just catch. Hoped after that that the seal would compress over time.
  25. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    I removed mine a few weeks back. The engine was warm as I had just returned and that may help.
    Like most things, patience. I would try a little heat (hair dryer, heat gun, warm engine) and then gently peel up the outer edges a little a time while working your way around.
