456 / 550 / 575 Cross Reference, Interchangeable Parts Source Thread | Page 18 | FerrariChat
Discussion in '456/550/575' started by Cribbj, Jan 9, 2013.
  1. chris1866
    chris1866 Formula Junior
    Mar 14, 2005
    566
    Atlanta
    Chris
    I am trying to verify whether or not the LH and RH crank sensors are different for the 550. The plastic on the connectors are both cracked on mine in identical fashion, (my cam sensor did the same but ultimately failed), so I'm relatively confident that they are original.
    Ferrari calls them:
    164082 "RH angolar speed sensor"
    164083 "LH angolar speed sensor"
    Looking at the ones on the car, both have the exact same Bosch part number: 0261210152.
    Has anyone been able to confirm this?
  2. asgor
    asgor Formula Junior
    Sep 8, 2016
    720
    Virginia, USA
    They are the same. The part number difference is simply because one has a blue mark on its sleeve (or an entirely blue sleeve, I can't remember at the moment) to distinguish it from the other - makes it easier to tell LH from RH, I guess.
    F456M and chris1866 like this.
  3. Aerosurfer
    Aerosurfer Formula 3
    1,969
    Indianapolis
    Nick
    As posted elsewhere on the forum, the 360/430 driver side wiper arm fixes the issue of it hitting the hood on at least the 456. Its a straight bolt on piece. The 430 has spray jets in the hood, so there is some routing of the washer line along the wiper that needs to be routed, the factory clips work
    Part number 65409200
    Still makes me wonder the over engineering of this part
    The 430 wiper is the closer one in the picture with both arms.
    F456M, Konadog06 and Auraraptor like this.
  4. Aerosurfer
    1,969
    Indianapolis
    Nick
    In keeping with Does anyone know of a cross reference part to the washer line clips. Available at the big vendors, but just seeing where else these may be used
    Part 61559400
  5. bay
    bay Formula 3
    Mar 13, 2011
    1,280
    Belgium
    Bernard
  6. bay
    bay Formula 3
    Mar 13, 2011
    1,280
    Belgium
    Bernard
  7. Aerosurfer
    1,969
    Indianapolis
    Nick
    Replaced my wipers today... for us 456 owners the washer jet is integrated into the wipers. Found these Bosch 609 (about 24") wipers are proper size for the windshield and they come with the integrated sprayer that the original hose can attach into
    For the Passenger side, aside from the fact the arm is inverted, I also found the OEM wiper is mounted not quite equidistant to each side, so despite being a 24" blade it will hit the side when mounted with these... so instead i simply changed the wiper. A 24"/600mm insert will fit, just assure its 8mm wide to fit snugly into the arms
    Mirek likes this.
  8. Aerosurfer
    1,969
    Indianapolis
    Nick
    And since i have an unused pair of each, if anyone needs to service their wipers, im happy to sell and ship out the setup i used, both new.
    1 609 wiper assembly with spraybar
    1 24" wiper insert
  9. Dal308
    Dal308 Karting
    Nov 4, 2014
    132
    Coppell, TX
    Dude
    The BMW part number 37-21-1-132-043 accumulator for the rear suspension of the 456 and M seem to be discontinued and the remaining stocks in the US as far as I can tell are gone. Also the Febi/Bilstein and Meyle third-party replacements. Corteco part number 80001410 functionally seems to work, but the brackets are wrong. There is no bracket for the tip, and there is a 90-degree bend in the main bracket that doesn't need to be there.
    Lionworks Auto likes this.
  10. Aerosurfer
    1,969
    Indianapolis
    Nick
    The 90s Mercedes-Benz w140 S-Class also used a similar setup with accumulators. Part num er 1403280515. They are still plenty available and reasonably priced. They may be worth someone to check an order and see if the fitment can be adapted. From FCPEURO.COM and installed on my old car
    MaurizioAM likes this.
  11. seastronj
    seastronj Rookie
    Aug 10, 2018
    38
    Lethbridge Alberta
    Clayton Strong
    First off this post is awesome. I've been on the hunt for a 3.8 bar 55psi fuel pressure regulator for 01 456mgt.
    I looked at the corvette reference on the first posted photo but it comes up as an anti theft part.
    Any help would be greatly appreciated.
    Clayton (owner and operator)
  12. lopena
    lopena Formula Junior
    769
    If you need a gas cap tether for your Maranello, go to Pelican Parts and order part #955-044-200-05-OEM for $8.75…it’s an exact replacement. Ferrari tethers cost up to $50 on ebay.
    Alan
    N.J.
    MRY likes this.
  13. lopena
    769
    If your Maranello needs front hood struts go to www.liftsupportsdepot.com and order struts # PM3874. Cost is a very reasonable $24.95 each and they are a direct, snap-in replacement.
    Alan
    N.J.
    Qavion and MRY like this.
  14. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,715
    Oslo
    Erik
    I need to replace the hand brake pads. Anyone know which car this could be bought for? I need it nooooow!!! (Yesterday!) My car did not pass the inspection.... Thanks alot.
    Erik
  15. tazandjan
    39,412
    #440 tazandjan, Oct 19, 2022
    Erik- Did not pass it because the handbrake did not work well enough or did not pass it because the pads were worn? Never heard of an inspector checking parking brake pads.
    F456M likes this.
  16. tazandjan
    39,412
    Erik- In that case, adjust the star wheel first on the parking brake and then adjust the cable.
  17. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,715
    Oslo
    Erik
    Hi Terry. Everything on the car must work satisfactory. No major leaks and good tires. They even inspect the chassis number and seat belts. Testing the brakes, light adjustment, exhaust, lights you name it.
    I now need to replace a wheel bearing front right side and fix the parking brake. I believe a friend of mine forgot to take off the parking brake when he was helping me pocjuing the car in ahotel garage. He have never driven a Ferrari before and I should never have let him drive the car while I was not with him in the car..... I doubt it will help to adjust it. I have three years ago re-adjusted the cable and it became better, but now I believe it is time to change it all.
  18. Aerosurfer
    1,969
    Indianapolis
    Nick
    Auraraptor likes this.
  19. Timmo
    Timmo Formula Junior
    Aug 26, 2017
    733
    Continental Europe
    Does anyone know why the usual parts catalogues list 2 different part numbers for the upstream lambda sensors on the 550?
    RH FRONT LAMBDA FEELER : 162462
    LH FRONT LAMBDA FEELER : 169953
    Interestingly both of these part numbers point to the same Bosch part number : 0 258 003 819
    F456M likes this.
  20. red leather
    red leather Rookie
    Jun 15, 2014
    7
    France
    Hello,
    I just replaced my wiper pump (OE 61535400 on Eurospares) on my 97' Ferrari 456 GT, by an Amazon product : OTUAYAUTO 066011A Windshield Washer Pump - Replacement for 1986-2019 Peterbilt 330, 335, 370 series- Washer Fluid Pump (link here : https://www.amazon.com/dp/B083HYKN5W?psc=1&ref=ppx_yo2ov_dt_b_product_details).
    It fits perfectly, works perfectly, and is much less expensive than the original one (more than $400 here in France :eek:...) and only $13 for the one above.
    I hope it can be interesting for someone who need to replace his pump.
    Florian
    Patrick F, F456M and Aerosurfer like this.
  21. franschman
    franschman Formula Junior
    Dec 18, 2017
    362
    Holland
    Bart
    #446 franschman, Nov 27, 2022
    This is what it looks like on my car:
  22. Aerosurfer
    1,969
    Indianapolis
    Nick
    If anyone need to replace the rubber boots on any of the various connectors around the car, I can say this ebay vendor offers a suitable alternative replacement. Not sure about longevity, and not crazy over China parts, but it does the job. And it is quite close to stock looking.
    Vendor: glhk05
    https://www.ebay.com/itm/195331594234?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=Gzhs68M9QEu&sssrc=2349624&ssuid=_LKYa4nlQie&var=&widget_ver=artemis&media=COPY
    Anthony 360 F1 and Ferrari55whoa like this.
  23. Ferrari55whoa
    Ferrari55whoa F1 Rookie
    3,488
    Los Gatos, CA
    Eric
    This thread is all solid gold
    NeoZ likes this.
  24. NeoZ
    NeoZ Rookie
    Jan 20, 2023
    12
    Tbilisi, Georgia
    Giorgi Metepshishvili
    Hello,
    I'm new here and liked this thread too much :) its very usefull info, I just wonder have someone collected this info in excel sheet? Does this type of file exists?
    Thank you in advance.
  25. asgor
    Sep 8, 2016
    720
    Virginia, USA
    I owned a 456 until about two years ago and during my 5-year ownership I created a spreadsheet to keep track of the knowledge in this forum. The file I am attaching is up-to-date as to about the middle of 2020 and anyone is quite welcome to use it as a starting point if they so choose.
    scowman, Patrick F, renn20 and 3 others like this.
