456 / 550 / 575 Cross Reference, Interchangeable Parts Source Thread | Page 20 | FerrariChat
Discussion in '456/550/575' started by Cribbj, Jan 9, 2013.
  1. bay
    bay Formula 3
    Mar 13, 2011
    1,280
    Belgium
    Bernard
  2. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    14,255
    MO
    Omar
  3. Auraraptor
    Sep 25, 2002
    14,255
    MO
    Omar
    Is the UFI 3002300 a direct swap for the OEM 180935 in the 575 or 151562 for the 550/456?
    Also how is 180935 (575) different than 151562 (456M/550)? Do they cross swap? I would have imagined all three cars use the same air filter hence query
  4. NeoZ
    NeoZ Rookie
    Jan 20, 2023
    12
    Tbilisi, Georgia
    Giorgi Metepshishvili
    As I know these are from Japanese specs - right 173616 and left 175506 and EUR and US specs vere fitted with PN 165558 on both sides.
  5. Jaredsalinsky
    Jaredsalinsky Formula Junior
    Feb 8, 2023
    707
    tampa FL
    Jared salinsky
    Hey bud. You still have these wipers? I need new blades.. ty
  6. Aerosurfer
    Aerosurfer Formula 3
    1,971
    Indianapolis
    Nick
    Yup.. pm coming your way
  7. Jaredsalinsky
    Feb 8, 2023
    707
    tampa FL
    Jared salinsky
    All- I’m not sure if anyone else cares about the rear seat center hatch gas strut…. But I have found a replacement! It’s not IDENTICAL but I’ve confirmed it works. Hatch now stays open by itself as intended (I believe). Now I never had the pleasure of seeing how this rear hatch operates when new, so I can’t be sure it acts exactly the same way. But I’m happy (enough) with the results.
    note: in my pic of the new on I drilled 2 new holes in the eyelet end to try and adjust the geometry of the system..BUT…it did not work as the receiving holder on each end abuts the eyelet. SO..you have to use the original eyelet holes of the new strut. BUT IT WORKS ANYWAY!
    I used new (smaller) Clevis with cotter pins on each end (as opposed to original larger Clevis pins with C clip snap ring)
    tantumaude likes this.
  8. Ferrarienthusiast71
    Ferrarienthusiast71 Formula Junior
    721
    Charlie
    The Ferrari 612 radiator looks the same as a 550 radiator, am I right or wrong ?
  9. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,716
    Oslo
    Erik
    Where is it fitted?
  10. Jaredsalinsky
    Feb 8, 2023
    707
    tampa FL
    Jared salinsky
    hey there. As mine is a '95GT (not an M) it is fitted in the hatch between the rear seats. the strut frequently fails and the hatch won't stay open by itself. (this is a pet peeve of mine!) I'm not sure if the M cars have the same strut; or if they do it may not be the same as on the GT.
    hope this helps
    F456M likes this.
  11. Aerosurfer
    1,971
    Indianapolis
    Nick
    Wow... more parts I didnt know i needed (or not). Mine opens freely, so no piston on my car. Did you have the whole rear assembly out or can you just access it by removing the 2 screws in the bin? Learn something new all the time about this car.
    F456M likes this.
  12. Jaredsalinsky
    Feb 8, 2023
    707
    tampa FL
    Jared salinsky
    yeah I was able to access and fix just removing the inner bin. HOWEVER..now that i've removed the whole back seat to access audio/speaker wiring I realize it would have been a whooooole lot easier with everything removed...
    anyway...fun to try new stuff!
  13. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,716
    Oslo
    Erik
    OK! My M did not have a center compartment.
  14. stevepaa
    stevepaa Formula Junior
    Apr 5, 2006
    771
    san jose, ca
    steve
    seat height adjusting cable is NA from Ferrari
    Porsche sells it separately PN 996 521 609 00 for $30 got it in 2 days
    F456M, pkl03, Qavion and 2 others like this.
  15. Remko
    Remko Rookie
    Sep 24, 2019
    22
    Remko Alexander vlot
    The 456 m also has these on the EU and US spec cars. The pre-M models indeed had them only in JPN!, Still searching for them though... Who knows where to buy and maybe which car-brand also used these...?
  16. Lionworks Auto
    Lionworks Auto Formula 3
    Oct 16, 2013
    1,023
    Worthington OH
    Ed
    Holy crap - it’s like you heard me crying my blues today! Literally have a fried connection at the main fan and was trying to figure out how to get a new oem line installed. Now I can skip it all with better results and install this brilliant kit! Just bought on Ricambi and thank you!!
  17. Aerosurfer
    1,971
    Indianapolis
    Nick
    Awsome to hear and thank you! You will like it. Nothing from stock gets removed, just redirected. So If you have actual fried or damaged parts PM me and i can put a package together of spare components to replace whats there already so everything is safe and secure.
    I would also check the conditions of the plastic plugs in your fuse box for damage too.
    Timmo likes this.
  18. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,555
    Scottsdale AZ
    Stu Boogie
    1995 456 GT Starter Solenoid
    Has anyone found a cross reference or alternate for the 456 GT starter solenoid? From research is seems the starter is a 110 series, part number 0 001 110 108 and the solenoid is a 0 331 303 032 532. It may also be compatible with the Testa Rossa.
    The starter I can get rebuilt locally but the solenoid is a replacement part and I cannot find one. Maybe I could send the solenoid away for repair but would rather just source a new one.
    Of course, Ferrari does not seem to sell solenoids separately.
    EuroSpares wants $1,200 for new starter + solenoid.
    https://www.eurospares.com/Parts/137269/Ferrari
    SPUK has an aftermarket set up for about $600. Shipping is going to be high due to weight...
  19. kinnie
    kinnie Formula Junior
    Nov 21, 2003
    325
    Belgium - Aarschot
    Kinnie Van Gelder
    I assume you are talking about
    63913800 or 63913900
    https://www.ferrariparts.co.uk/part/ferrari/63913800
    I assume they are the same as from a Peugeot 406 coupe
    I haven't tested them, So do not know the connectors will fit...
    Some partnrs i found :
    6556H8
    6556H7
    00008920E8 CDE SIEGE ELECT GAUCHE
    0000892145 CDE SIEGE ELECT DROIT
    Here a link to a peugeot forum :
    http://www.coupe406.com/Forum/viewtopic.php?t=22266
    Full workshop manual from peugeot, again i do not know it's all the same but this seems à lot like à 456M seat.
    http://www.coupe406.com/documents/Tutoriels/Procedures/Dossier406EleveSiege.pdf
    bay likes this.
  20. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,716
    Oslo
    Erik
    The Peugeot 406 Coupe is actually designed by Lorenzo Ramasciotto at Pininfarina, the same guy who designed the 550 Maranello. :)
  21. Donatas
    Donatas Rookie
    Nov 14, 2018
    21
    Donatas
    Hi, have you found something cheaper?
    scowman likes this.
  22. Aerosurfer
    1,971
    Indianapolis
    Nick
    Adding to the available batteries, i put this AGM group 48 battery in my car last month. Ordered off Amazon, came well packed and fully charged. Looks to be Clone of other AGM batteries.
    Weize Platinum AGM Battery BCI Group 48-12v 70ah H6 Size 48 Automotive Battery, 120RC, 760CCA, 36 Months Warranty https://a.co/d/iAw1PSJ
  23. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,555
    Scottsdale AZ
    Stu Boogie
    I wish, but no.
  24. tazandjan
    39,415
    Replacement belts for the Superamerica roof carrier. Courtesy of Sir Paul, whose belts wore out.
    Megadyne RPP Gold 450 GLD5
    Auraraptor likes this.
  25. Aerosurfer
    1,971
    Indianapolis
    Nick
    C-Ray62, Timmo and Auraraptor like this.
