456 / 550 / 575 Cross Reference, Interchangeable Parts Source Thread | Page 3 | FerrariChat
Discussion in '456/550/575' started by Cribbj, Jan 9, 2013.
  1. Cribbj
    Cribbj Formula 3
    512TR & M, 456, 550 throttle body o-ring, Ferrari P/N: 142934
    McMaster P/N:9263K749,
    Generically: Viton Fluoroelastomer metric o-ring, 75mm ID, 3mm width
    (BTW, not much money to be saved by purchasing from McMaster as they're $4.41 each in a pack of 2. Daniel's price is $4.55 each. So McMaster would only be an alternate source)
  2. AndersJL
    AndersJL Formula Junior
    Apr 16, 2001
    376
    Sweden
    AL
    Thank you for a great thread !
  3. offshore
    offshore Rookie
    Oct 31, 2011
    6
    #53 offshore, Mar 9, 2013
    finally worked out how to attch a document, yes I'm slow!
    This is produced by manually cross seaching the Bosch catalogue for other makes and models that used the same Bosch parts as the 550. I have found this helpful in seraching the internet for other parts sources.
    Nigel
  4. Cribbj
    Cribbj Formula 3
    Right side TPS Ferrari P/N: 172750
    Bosch P/N: 0 280 122 004
    Left side TPS Ferrari P/N: 158170
    Bosch P/N: 0 280 122 005
    Note, these numbers and their sides are as per the Ferrari diagrams, however, I believe they're reversed. The sensor on my car's right bank is the Bosch 0 280 122 005, which is the expensive one (dual connector). The one on the left bank of the car is the cheaper one (single connector).
  5. bay
    bay Formula 3
    Mar 13, 2011
    1,280
    Belgium
    Bernard
  6. rmfurzeland
    rmfurzeland Formula Junior
    Jan 7, 2005
    560
    Houston, TX
    Ron Furzeland
    A lot of the relays are Bosch 0332019103, anyone have a good source?
    Thanks,
    Ron
    clauber likes this.
  7. Cribbj
    Cribbj Formula 3
    Is it Ferrari 157991, which is supposed to be a 30a relay for LH & RH radiator fans, but in reality, it's a 50a Bosch relay?
    Here's the cross I found to Tyco and they're available @ Waytek and others with the Tyco P/N:
    Bosch P/N: 0332019103
    Tyco P/N: V23234B0001X001
    HIGH CURRENT MINI RELAY 12V 50A SPST V23234B0001X001 - 75301
  8. rviani
    rviani Karting
    Jun 22, 2005
    81
    NJ
    Ron Viani
    The early 456's use a TEVES electrical / hydraulic brake booster system. I believe the 456 hydraulic accumulator and pressure switch are interchangable with parts supplied by AC Delco (#25528382 - accumulator) and #25533700 pressure switch) which are the parts most prone to failure. However I have not personally verified this.
  9. rmfurzeland
    Jan 7, 2005
    560
    Houston, TX
    Ron Furzeland
    #59 rmfurzeland, Apr 8, 2013
    Yes, Ferrari part number 157991. Bosch datasheets say good for 50A. Used for 550 radiator fan, a/c , headlights, etc. I understand Tyco took over the Bosch relay business some years ago.
    Thanks for Tyco equivalent and link, is the Tyco quality as good?
    Ron
  10. Cribbj
    Cribbj Formula 3
    Ron, I don't think the present Tyco products are as good as the "old" Bosch, but they're better quality than the "new" stuff that Bosch sell, if that makes sense?
  11. rmfurzeland
    Jan 7, 2005
    560
    Houston, TX
    Ron Furzeland
    John,
    Bought a bag of 5 relays from Tyco at $7 each. Seem to work fine. I replaced the hard working relays like dim and main beam lights, a/c and now I have a few spare e.g. for radiator fans if need be.
    Regards,
    Ron
  12. Mehl
    Mehl Rookie
    Jan 26, 2011
    27
    Left Headlight Motor 174159 (about 320€) = BoschNr 0 390 206 414 = Right Headlight Motor Volvo 480 (used about 28€)
    Right Headlight Motor 173965 (about 320€) = BoschNr 0 390 206 413 = Left Headlight Motor Volvo 480 (used about 35€)
    polystrate likes this.
  13. tazandjan
    39,362
    John- The good Tyco relays work fine. The old Siemens relays had some serious problems, like the first one used for early F1 pump relays.
  14. 12659
    12659 Formula Junior
    Oct 6, 2005
    349
    Seattle WA. USA
    mark
    egr valve F-part # 148494, gm part #605862360.
  15. bay
    bay Formula 3
    Mar 13, 2011
    1,280
    Belgium
    Bernard
    Alternative Manufacture References:
    Silca : GT 6RDP
    Silca : GT 6RP
    HD : K4P
    HD Hook : K4P
    HD Hook : PT007
    Orion : FAKP
    Orion : LAKP
    Errebi : NE45P3
    Errebi : NE45P7
    CEA : F3P
    CEA : F3P3
    CB Hook : P11
    CB Hook : P86
    CB Hook : P87
    Curtis : FT-46P
  16. mcypert
    mcypert Formula Junior
    Jun 7, 2012
    369
    Houston, Texas
    Mark Cypert
    #66 mcypert, May 28, 2013
    Not that this is very useful, but...
    Ferrari part # 183758 seems to be interchangeable w/ Ferrari # 226484 (I think the latter is sold in Europe, I got it cheap here on Ebay). I installed the 226484 in a 95 456 GT.... works just like the original and, specs tested identically. Anybody know if there's a difference?
    And, based on the above, one can speculate that any 456/550/575 thermostat will work in any of these cars, even though there are different part #'s???? This might be useful to non-USA owners... Thermostat prices vary widely....
  17. bay
    bay Formula 3
    Mar 13, 2011
    1,280
    Belgium
    Bernard
    THERMOSTAT Part No. 226484. Superceded From Part No. 183758.
    http://www.superformance.co.uk/a-v12m/cooling.htm
  18. mcypert
    Jun 7, 2012
    369
    Houston, Texas
    Mark Cypert
    #68 mcypert, May 29, 2013
  19. bay
    bay Formula 3
    Mar 13, 2011
    1,280
    Belgium
    Bernard
  20. mcypert
    Jun 7, 2012
    369
    Houston, Texas
    Mark Cypert
    #70 mcypert, May 29, 2013
    Yes, Bernard:
    Eurospares is even more confusing. You can get a 183758 or pay 3 times the price for a 226484? Hum? Guess I can say I have the updated $350USD thermostat in my car. :)
  21. TZ 750
    TZ 750 Formula Junior
    Jul 18, 2009
    912
    My tire pressure sensor readings are getting a little wonky.....
    Is there an alternative to the (no surprise here) expensive
    Ferrari units ?
    I am planning on a trye change soon, and it's easier to
    swap out the sensors when the tyres are off.
    Thanks, Scott
  22. TZ 750
    Jul 18, 2009
    912
    Bump.........
  23. tazandjan
    39,362
    Assuming your 575M is a US version, you need Huf Beru RDE004 315 MHz sensors in dark brown (earlier generations were dark gray). Available from TireRack or Amazon. Last time I checked they were $105 each through Amazon and their subcontractor. You can buy the valve rebuild kits, too, which I recommend.
  24. TZ 750
    Jul 18, 2009
    912
    Thank you, Terry !
  25. Wheels1
    Wheels1 F1 Rookie
    Oct 23, 2007
    3,593
    Grant
    #75 Wheels1, Jun 22, 2013
    Bosch fuel pumps for 456 and possibly 550 can be replaced with one of these which is identical and seems to be more readily available. As sold by Eurospares for the 456 but half the price on e-bay.
    Bovien likes this.
