456 / 550 / 575 Cross Reference, Interchangeable Parts Source Thread | Page 9 | FerrariChat
Discussion in '456/550/575' started by Cribbj, Jan 9, 2013.
  1. JazzyO
    JazzyO F1 World Champ
    Jan 14, 2007
    12,161
    The Netherlands
    Onno
    No the hood is not longer (I mean - think of the engineering that would go behind such a statement, it would mean everything would be different, fenders, chassis length possibly, place of radiator etc). It has the same basic shape. The only thing I can think of is that the air intake might have changed a little, but I've never noticed any differences.
    Here is a visual comparison.
    http://www.sportscarbible.com/_images/ferrari/ferrari-550-maranello-575-m/ferrari-550-maranello-575-m-xl/ferrari-550-maranello-575-m-xp1190283scb.jpg
    Onno
  2. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,473
    456GT: Sway Bar Bushing (26mm ID) same as Jeep Cherokee/Dodge Dakota.
  3. Mr. V
    Mr. V Formula 3
    Oct 23, 2004
    1,247
    Portland, Oregon
    What year(s) Jeep or Dodge?
  4. dencap
    dencap Karting
    Sep 29, 2013
    127
    SF Bay Area, CA
    Dennis Caponigro
    456 Owners Caution.
    The equivalent alternator to the stock Ferrari... NiponDenso listed as for a "John Deere Marine Engine" is not a total Plug and Play replacement...some modification was required.
    1)The small alternator mounting flange is threaded, and the hole not large enough to accommodate the tension pin, that rides in the curved slot, and needed to be drilled out.
    2) The pulley installed on the alternator is slightly wider in diameter and width. Not an apparent issue. The grooves of the drive pulley and A/C compressor pulley guide the belt in the exact center of the alternator pulley, with a slight gap on either side.
    Installed the unit last night with the minor drill out modification and all worked well.
    A big savings over Ferrari ($840.00 vs $113 delivered brand new)
    Dennis
  5. 360modena2003
    Jul 11, 2009
    2,473
    Offered as: Jeep Cherokee XJ 26mm 1984-2001
  6. 360modena2003
    Jul 11, 2009
    2,473
    #206 360modena2003, Nov 12, 2015
  7. VetroresinaNL
    VetroresinaNL Formula 3
    1,917
    The Netherlands
    Vetroresina
    Hello, my 456GT (EU version) is factory equipped with (German) ATE (Teves) brake system, for this system I am looking a complete set of brake pads for the front (incl. indicators). As the Ferrari prices are over the top, I am looking for an alternative. I am based in Europe.
    Many thanks!
  8. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,837
    Burradoo... Actually
    Graeme
  9. ///Mink
    ///Mink Formula Junior
    824
    Fair Oaks, CA
    Tom Mink
    #209 ///Mink, Nov 23, 2015
    The power steering reservoir (Ferrari 170877) is a standard ZF part, used on many cars including BMW. Ferrari is ~$100, BMW is ~$30. This is for a genuine ZF part. BMW part number 32416851218. The reservoir has a non-replaceable filter in it so you don't want a used one.
  10. VetroresinaNL
    1,917
    The Netherlands
    Vetroresina
  11. cls
    cls Formula 3
    Jun 12, 2007
    1,663
    Los Angeles/Montreal
    Chris
    Kiekert Part #4A5962115
    Also used in the Audio 100, 90, 80, A8, S8
    The moulded electrical connection is different, but it's just two spade connections.
  12. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Has anyone come up with a substitute or fix for the 550 airbag module? Thank you.
  13. ixlr8
    ixlr8 Formula Junior
    Aug 24, 2015
    362
    Eastern Shore- Virginia
    Jim
    Somebody had an issue with the airbag module in a 456. Apparently nobody in the US will touch it, not even the manufacturer and folks listed a few places in Europe that would rebuild/repair them. I can't find that thread now.
  14. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Thanks Jim, I'll check into that. If you happen to come up with any more information, please let me know. Thank you again.
  15. Rifledriver
    37,395
    At this time Ferrari is not offering a replacement and the manufacturer, TRW says there is no substitute.
    Repair or rebuilding is not recognized as a correct repair so there would be real liability issues for anyone taking that approach.
  16. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Hmm, yes, lawyers. Thank you.
    How many lawyers does it take to shingle a roof?
  17. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    It depends how thinly you slice them........
  18. wildegroot
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Right. Funny that you guys have the same joke!
  19. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    Lawyers are universally hated. 😂😂
  20. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,837
    Graeme
  21. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,837
    Graeme
    #221 au-yt, Jan 7, 2016
    A little digging around looking for oil filters for my 456 and starting with an eBay listing which may be correct and I say may as it shows two filters and next to it is Ferrari boxes..
    http://www.ebay.com.au/itm/161883160346_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
    Identifies the following UFI number 23 284 00
    Lead me to find this
    FERRARI 206166 Oil Filter
    Has this info...
    Manufacturer FERRARI
    Number 206166
    Description Oil Filter
    Bypass Valve Opening Pressure [bar] 1,6
    Outer Diameter [mm] 76
    Inner Diameter 1 [mm] 61
    Outer Diameter 1 [mm] 78
    Height [mm] 75,5
    Thread Size M 20 X 1.5
    Outer Diameter 2 [mm] 71
    Cross numbers FERRARI 141383
    FERRARI 151323
    FERRARI 206166
    PURFLUX LS786
    FERRARI 206166 can be used in car models
    FERRARI
    FERRARI 456 GT/GTA 1993-2004
    FERRARI 5__ MARANELLO 1996
    FERRARI 206166 Analogous Parts
    Part Number Description
    FERRARI 141383 Oil Filter
    FERRARI 151323 Oil Filter
    UFI 23.284.00 Oil Filter
    Other car parts with the number "206166"
    TOPRAN 206 166 Shaft Seal, manual transmission
    [email protected] © 2014 InfoPart.org - FERRARI Online Car Parts Catalogs.
  22. andrew121
    andrew121 Rookie
    Jan 9, 2016
    4
    Ipswich Suffolk UK
    Andrew H-S
    While sorting my various issues discovered the following.
    Headlights for 456 GT very nearly the same, but interchangable with those fitted to Volvo FL4, FL6, FLC, Volvo- Plaxton coach and Marshall Dustcart.
    All have the same Hella base unit, fixings etc.
    The truck versions have a parking light installed which is not fitted to the F variety, but the big difference is that the F kind have a tiny little horse moulded into the corner of the lens. This results in a cost differential of over £400. Of course if a little horse logo that you can't see matters that much to you .........
    I acquired a pair of beautiful replacements from my local truck breakers for £35 ea (inc VaT)
    The added bonus of these lights is that they can be easily converted from left to right traffic by simply removing the dip beam assembly and rotating it to its alternative position.
    Check out Hella 1DL 005 600 09. This is the left light unit I think the right one ends 08.
  23. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,837
    Graeme
    I have this reference for the 456 wheel colour as PPG 226650 can someone confirm please.
  24. tazandjan
    39,419
    Graeme- If you want silver, it is Argento Metalizzato, PPG 36520. The gray wheels appear to be Grigio Silverstone.
  25. au-yt
    au-yt F1 Veteran
    Aug 13, 2006
    5,837
    Graeme
    Thanks Terry, Yes it's silver I am not sure where I got the colour reference I posted, I googled it an searched Fchat hence the question.
    I have two wheels with gutter rash and want to get that sorted at the same time as new rubber.
