456 Door Gaskets | FerrariChat
456 Door Gaskets
Discussion in '456/550/575' started by KeithS, Apr 1, 2018.
  1. KeithS
    KeithS Karting
    154
    Paradise Valley, AZ
    Keith Stephens
    The door/window gaskets are different between the 456 and 456M. Can the 456 gasket be made to work on the M and will it seal the window? Thanks.
    Keith
  2. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,183
    Brisbane, Australia
    Gezim
    Can you not get an ‘M’ gasket? I’ve just replaced the drivers side gasket on the 456 and it seals perfectly. The major advantage is the cushioning of the door as it closes. It sounds much better when it shuts now. The window sealing problem is the electric window problem.
    Do you have a gap between the glass and the rubber?
  3. KeithS
    KeithS Karting
    154
    Paradise Valley, AZ
    Keith Stephens
    My gaskets are split on the rear edge top to bottom of the window. Several years ago, for a fix I had them covered in upholstry cloth. This looked and worked fine. The window pins have been repaired and the window sealed reasonably well. But with the recent body and interior work the gaskets were recovered. They look great but the seal is not good. It is time to replace them. I have been able to locate 456 gaskets but "M" style seem to be unavailable.
    There are slight differences in the gaskets and door detail, but the door opening and frame are the same. So my question... can the 456 gasket be made to work on the M and will it seal the window?
    Keith
  4. papou
    papou Formula 3
    1,577
    plantation Fla
    daniel ross
    You’ll find one at Eurospares.UK.
  5. tazandjan
    38,083
    Keith- I would get the F1 Imports fix done on the windows first and then replace the door gaskets if you still need them. Just the gasket is not going to fix a window gap problem.
    http://f1imports.com/specialties
  6. KeithS
    KeithS Karting
    154
    Paradise Valley, AZ
    Keith Stephens
    Yes, the gaskets are listed online but they do not have them.
    This has been done.
    Thanks ffor the replies. All help appreciated.
    Keith
  7. Phillip B
    Phillip B Rookie
    Sep 6, 2019
    2
    Phillip Benton
    Hi, I have been looking for a 456M Drivers Side door gasket now for 3 years. We have tried everyone - no availability. We tried Ferrari and they said they will not manufacture anymore until demand rises. Is there anyone out there that can either make a new gasket or modify a gasket from another model to fit a 456M?
  8. arkferrari
    arkferrari Karting
    211
    Hot Springs, AR
    B.F. Mitchell
    Lubbock Gasket and Supply was able to fabricate an "unavailable" transmission gasket for me after an exhaustive search. I found them very easy to work with and the gasket they produced was top quality. Contact them and see if they can help. You will probably need to provide them a template.
  9. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
    The gasket does not fix the gap problem. It will always be there - more or less - even after adjusting the window. A new gasket is expensive. Mine was split and I repaired it with a special Locktite glue.
  10. Phillip B
    Phillip B Rookie
    Sep 6, 2019
    2
    Phillip Benton
    Thanks, let me try them
  11. AUSWOODS
    AUSWOODS Rookie
    May 2, 2019
    21
    Richard Woods
    Has anyone had any luck with Gaskets fir 456 m. Mine are tired and in spite of bulking them out with various bits of tubing still not sealing when going 100kmh +
  12. papou
    papou Formula 3
    1,577
    plantation Fla
    daniel ross
    Got mine from Eurospares..
  13. AUSWOODS
    AUSWOODS Rookie
    May 2, 2019
    21
    Richard Woods
    Was hoping to find a lot better than £1826 each.
  14. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,178
    Austin, TX USA
    Greg
    Check Reoriginals in Houston TX. Used them years ago for 308 door/engine lid gaskets.
  15. Fennicus
    Fennicus Formula Junior
    Apr 10, 2015
    592
    Helsinki, Finland
    Pekka T.
    Whoa! I’m glad I got mine (456GT) when they were ca. £350 GBP each (+VAT & shipping) as I thought that was expensive, never mind the two weeks of work it took to install them as the ceiing had to be removed and of course while you’re there, every piece of leather cleaned and serviced. :)
    Cheers!
  16. AUSWOODS
    AUSWOODS Rookie
    May 2, 2019
    21
    Richard Woods
    Thanks for all the replies still no luck - Does anyone have a photo or drawing of the profile maybe I can find a way of matching ?
  17. franschman
    franschman Formula Junior
    Dec 18, 2017
    350
    Holland
    Bart
    The seal is one continuous loop, all around the door opening, with every section of that opening having a different rubber profile with cast pieces in between in some places. These are all glued together to form a loop.
    Most fragile is the upper aft corner, where a steel strip is inserted in the rubber to hold the window at high speed. This is where mine are worn, to the extend of the steel coming out of the rubber.
    I've been messing with these rubbers for a week now (evening jobs), but still not satisfied. I had them out for a paint job and, while at it, might as well repair the rubber and try to get a perfect fit.
  18. AUSWOODS
    AUSWOODS Rookie
    May 2, 2019
    21
    Richard Woods
    Thanks yes my corners and inset bespoke bits ok. Was thinking if I could find profile of main lengths I could reuse corners and bespoke bits but replace old with new on the rest
  19. franschman
    Dec 18, 2017
    350
    Holland
    Bart
    apart from the bottom half the profiles are quite complicated. I wouldn't know any generic profile that would fit. Actually wouldn't at all be surprised if Ferrari had these profiles made specifically for this model.
  20. TimS
    TimS Rookie
    Aug 23, 2020
    20
    Tim Shearman
    Just posting in the, probably vain, hope that someone knows of somewhere with a left hand 456M door seal - the current one is in bits so the car is unusable, they’re still unavailable from Ferrari and Eurospares don’t have any used ones for the “M” either. Many thanks!​
  21. Rifledriver
    34,117
    Austin TX
    Ferrari has nothing to do with parts for that age of car. That was handed over to Maranello Classic parts years ago. I'd get in touch with them directly and see how many sets would need to be on order to get them to make some more.
  22. TimS
    TimS Rookie
    Aug 23, 2020
    20
    Tim Shearman
    Thank you. I’ve already contacted them and they said they’d see if their procurement people could help - I’ll ask that question next, Many thanks
