456 Gas Leak Odor | FerrariChat
456 Gas Leak Odor
Discussion in '456/550/575' started by Consolr, May 2, 2009.
  1. Consolr
    Consolr Karting
    Jun 12, 2008
    100
    Chicago
    Scott MacK
    I was getting a gas odor in the car for awhile when I was driving it. Usually occurred after a long drive, and then the odor came around after I slowed down, at an idle or around a cloverleaf. I could never see visible leaks. Recently, I filled up at a service station after a long drive and saw a very small puddle of gas from around the firewall area. Then it seemed to go away. My mechanic can't find it now. Ideas?
  2. volvowest
    volvowest Rookie
    Oct 27, 2006
    18
    Alpharetta GA
    Gil West
    I had a similar problem with my 575. The dealer replaced a fuel tank seal and all is well. They said it was a common problem.
  3. ross
    ross Three Time F1 World Champ
    Mar 25, 2002
    36,246
    houston/geneva
    Ross
    the big plastic plug on the gas tank where the lines come in and out, is probably cracked. time and money consuming repair. if at all possible replace the stock plastic part with a re-make made of teflon to insure it doesnt happen again.
    other possibility, is that there is a crack in the pipe between the fuel filler collar, and the tank itself. cheap fix is to wrap that pipe with some aluminum tape.
  4. borist
    borist Guest
    Had the identical problem couple of years ago and the dealer fixed it, no charge.
  5. ross
    Mar 25, 2002
    36,246
    houston/geneva
    Ross
    thats interesting. do you happen to have a copy of that recall notice?
  6. Consolr
    Consolr Karting
    Jun 12, 2008
    100
    Chicago
    Scott MacK
    My "dealer" did a smoke test on the gas tank and apparently detected the leak and tried to fix it. It's better but not perfect. I will talk to him again with these suggestions.
