Thanks for the info. Yes, I think I should move towards the 21st century and get familiar with on-board diagnostics now that I'm running two 90s cars with electronic fuel injection as classics.
I thought it was just me... but I don't get it either. Maybe I am just not fully understanding how the FPR operates but how in the world would a failed FPR diaphragm/ broken FPR inject oil into the crankcase?
It would not directly inject fuel into the crankcase of course, but when the pressure of the fuel system gets too high (failing FPR, maybe blocking the dump into the return line), the injectors will inject too much fuel into the cilinders. In theory this can be so much, that the fuel does not ignite, and drip down the walls, past the rings and into the crankcase. But only on one bank. A camera can check if the broken-FPR -bank has cleaner cilinders and plugs, as the raw fuel must have cleaned them a bit, compared to the good bank. But I would certainly look into the oil pressure valve.
I would have thought you would be getting much more serious problems than fuel in the oil if you’re getting to the point of hydraulically locking the cylinders full of fuel. Sent from my iPhone using FerrariChat
What I imagined was that if the regulator diaphragm had ruptured, extra fuel would get into the inlet manifold, where it would be in bulk liquid form, rather than as an aerosol, and so would end up as described above, going down the cylinder walls into the oil.
When doing a compression test of an engine, if a cylinder has less pressure, a next step is inserting a teaspoon full of oil into that cylinder through the plughole, and test again. When the test now gives a higher compression, the rings have play which the oil temporarly has filled up. This suggests that oil normally seals , or is part of the sealing system of the rings. Excess fuel diludes and washes away that oil, and creating a leak for the fuel to pass. See the fuel as a penetrating fluid, opening up the acces to the crankcase underneath the pistons. As the fuel pressure only exists with the engine running, the injectors can only inject too much with the engine running.(when shut down, the remaining fuel pressure is not enough to fill the combustion rooms) And that means that the excess raw fuel is not only going past the rings, but also past the opening exhaust valves , which by the way is bad for the cats. Hydraulocking with fuel therefore is not likely. With water/coolant this is much more of a danger, as that does not dilude and wash away the oil, and then the fluid is trapped more. In my opinion, and I am not a mechanic, if the O2 sensors (especially the post cat ones) are behaving normally now, no real harm is done to the cats. And if the long term fuel trim value is ok, more or less the same as the other bank, I would not worry about this. It is a 20-25 year old car, and sensors and check valves etc do get older and sometimes are at the end of their lifespan.
Mine's a 1994 car, so 27 years old now, in fact. Yes, I completely agree with you, Robbe; that is my thinking too. I'm waiting to hear from the mechanic the results of his various checks, and will update this thread when I get them.
The compressions have now been checked and are somewhat low on the bank that suffered the fuel wash. The mechanic is recommending that we try first, before thinking of opening up the engine, to run the engine as is, once the fuel pressure regulators have been fixed, and see whether the rings might bed back in in those cylinders. He is thinking to try some oil additive that is supposed to aid the ring seating process.
I haven't given you an update because there isn't one to give, yet. The car remains with the mechanic in Madrid, who has been waiting for replacement fuel pressure regulators to arrive. These may have arrived by now; I haven't spoken to him this week yet. There also remains the problem I had with engaging some gears after running for a while. The mechanic is going to look into that issue too once the car is running again. He has told me that from my description he thinks that it might be a simple thing, or might indicate some deeper problem within the gearbox. I need to go to Madrid (about 400 km from me) for other business in the next few days, and I'll try to schedule things to go and see the mechanic to find out more then, and will let you know. Meanwhile Bart, franschman from this forum, put me on to a replacement window ECU at a good price, which I have bought over Ebay and is coming from Modena. Thanks, Bart! So at least I'll be able to fix that issue once the mechanical issues have been sorted. This window issue is of course minor compared to the mechanical questions, but I would not be able to pass annual vehicle inspection here with a car where one of the windows doesn't go up and down.
A small update: these are the compressions from the bank of the engine unaffected by the fuel regulator problem: Image Unavailable, Please Login and these are the compressions from the affected side initially: Image Unavailable, Please Login as you can see, they are not good. These are the compressions on this bank after installing new regulators and running the engine for a while: Image Unavailable, Please Login The compressions have already improved quite a lot. So, we are cautiously optimistic that if we run the engine more the rings will bed back in and the compressions will come back to somewhere reasonable.
Do you know how this was measured? Cold or warm engine? How many strokes? I did a test on my 550, cold, and with 5 strokes I get to 10-11 bar on all cylinders (148-160 psi) Not to say my engine is what it should be, but it gives an idea of what you can expect. A bit like your other bank, except the nr 1 at 13.
NGK instructions are to never remove the spark plugs when the engine is hot, as the threads of the head can get damaged due to metal expansion from heat. Just ignore?
Damaging the thread is a real risk and can result in very expensive damage! (a ruined thread can be fixed with a special helicoil, but this reduces plug cooling so much that a plug with 1 or 2 heatratings higher should be used for that cylinder.) While working on an engine I always coat the plug thread liberally with copaslip and only lightly tighten the plugs. If the plug feels stuck, just leave to cool, never mind what you were doing. In the pitlane of a racetrack this can lead to conflicting interests and I ruined a head once while trying to change a plug quickly... When done, remove excess grease and tighten to the specified torque.
To reply to the earlier question of Robbe, I don't know how he did the testing, but I'm going to meet up with the mechanic on Monday and should be able to tell you more after that.
