456 price trends | Page 33 | FerrariChat
456 price trends
Discussion in '456/550/575' started by ross, Jan 26, 2020.
  1. Jaredsalinsky
    Jaredsalinsky Formula Junior
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    tell us more about the experimental/test wheels?! I ended up putting 18" 575 wheels on - looks fantastic
    I also finished up the 'experimental' sport/racing seat 'upgrade' - feels and smells wonderful, (although not nearly as cushy as the native seats, and no electircs)
    Last thing is small tasteful wing on the rear - sort of adds some nice contour to the rear of the otherwise slightly modest 456 butt!
    pics to follow!!
    Ferrari55whoa likes this.
  2. Aerosurfer
    Aerosurfer Formula 3
    1,822
    Indianapolis
    Nick
    Can't tease like that... pics!
    Uberpower and Ferrari55whoa like this.
  3. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    13,886
    MO
    Omar
    #803 Auraraptor, Jan 14, 2025
    Picks will come tomorrow. The horrible weather in STL thrown everything off.
    Short teaser is they are factory/OEM modular front wheels rebuild to fix all the design weakness of the OEM design.
    Spec is 19x9 ET 39.65, forged barrel+lips. Matched finish to OEM 19in modulars. OE supplier hardware (aka Italian-sourced titanium outer bolts from same supplier as OZ). Wheel value in same location. Inner barrel clearance to permit HGTC brakes. Final weight is a half pound less than the original 19x8.5 ET43.65 spec.
    My specs were calculated to preserve steering balance/braking balance/scrub radius/etc while still giving the visual result of having a 10mm spacer on the front.
    Pending how these test wheels go, next will be redesigned rear wheels that give visual stance of 25mm spacers but both forgo the need for spacers and preserving the steering balance of an FHP suspension setup car. (What's the point of getting FHP only to dial out the neutral steering balance with excessive rear spacers...)
  4. Mirek
    Mirek Formula 3
    1,471
    Los Angeles, CA
    Mirek
    18 inch OEM Modular’s are the dream (mine anyway).
    One day, after Fabio’s headers perhaps…
  5. Auraraptor
    Sep 25, 2002
    13,886
    MO
    Omar
    Fronts are rebarrled oem; close up to show hardware
    Rears are take offs of my 575.
  6. Ferrari55whoa
    Ferrari55whoa F1 Rookie
    3,322
    Los Gatos, CA
    Eric
    Jaredsalinsky and Auraraptor like this.
  7. Auraraptor
    Sep 25, 2002
    13,886
    MO
    Omar
    Should add, I need to find a collar to fill the gap around the valve stem. That and wash/clean the car. Getting her home was more important (report of more snow this weekend here...ugh). While I wait for the snow to melt/go away, I will keep an eye on the air pressure in the fronts.
    So far seems ok. Glad I redux'ed the whole fuel system. No fuel smell! As expected the rubber under pumps was completely disintegrated. I can't comment if my running hot issue has been fixed with my new water pump as its in the teens (Fahrenheit)/sub zero (Celcius) here so that will be a spring/summer check.
    The keen eyed will notice my adapted front wheels outer edge sits about 10mm more than standard 575 wheels (or 16mm more than standard 456 wheels). Likewise, the car has FHP ride height (adapted from the Euro Spec 550 and 575 FHP ride heights), custom Fabio exhaust pipes. Through the driver side window you can make out the 575 steering wheel as well.
  8. Jaredsalinsky
    Feb 8, 2023
    666
    tampa FL
    Jared salinsky
    well...that looks fantastic...
  9. Mirek
    Mirek Formula 3
    1,471
    Los Angeles, CA
    Mirek
    I also explored adding the 575 wheel it looks great in there.
    Those wheels are perfect, I need a matching set.
    Great job on that car.
    Auraraptor likes this.
