456 Radiator Temp Sensor | FerrariChat
Discussion in 'Technical Q&A' started by scowman, Nov 3, 2018.
  1. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,505
    Scottsdale AZ
    Stu Boogie
    1995 456 GT
    Does this control the main fan? Mine cycles on and off quickly. I'm thinking it should have a 10 degree spread.
  2. Ferrari_Doctor
    Feb 14, 2012
    24
    This is one of two temp sensors. The other located near the thermostat housing.
    You can do a simple ohm reading check with a multimeter if you have one available.
    30c - around 2000 OHMS
    50c - around 1000 OHMS
    90c - around 250 OHMS
    Be sure to check Coolant level etc.
    Be sure to also check that it is not your A/C cycling as the fan is used to control the pressure of the AC system. Best practise to turn AC off whilst checking cooling system fan operation
    Keep us updated
    Prit Singh and f355spider like this.
  3. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,505
    Scottsdale AZ
    Stu Boogie
    Thanks, Why the three phases and not two? Is that how it goes on high temp and shuts off at a lower temp?
  4. Ferrari_Doctor
    Feb 14, 2012
    24
    When you say phases do you mean the cooling fan speeds?
  5. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,505
    Scottsdale AZ
    Stu Boogie
    Yes, so there are three speeds plus off?
  6. Ferrari_Doctor
    Feb 14, 2012
    24
    I don’t know whether your confusing my tests for the 3 different temperatures for fan speeds. The 3 temperatures are irrelevant to how the system operates,
    You should have 2 fans speeds and off.
    Testing the sensor at 3 different temperatures will confirm the sensor is working correctly if the resistances are roughly the same as mentioned above.
