456 suspension diagnosis. Pressure accumulator (cells, spheres) 2nd opinion please | FerrariChat
Discussion in '456/550/575' started by skl63, Sep 28, 2009.
  1. skl63
    skl63 Karting
    Dec 13, 2007
    227
    Melbourne, Australia
    Scott
    Hi,
    Our 97 456GTA is very (very) harsh riding and makes everything rattle. Switch on dash does little if anything. It is almost as if the rear shocks are locked solid.
    Anyway, I have been to a suspension specialist (works on road and race cars, inc. F-cars) who has suggested rebuilding all four shocks and replacing the pressure accumulators. This I am unsure about, because after speaking with Ferrari Australia, they tell me they have never had to supply a set, nor even price them. Has anyone here had to replace an accumulator?
    The suspension guy suggested that he believed the accumulators look to be the same as those on either a Citroen or a Benz, which sell for about $100 as opposed to Ferrari at about $1400. Any thoughts.
    He also suggested replacing F & R lower control arm rubber bushes, steering rack ends (ball joints nearest the rack, but not the tie rod ends).
    Alarmingly, we also discovered that one of the front Red shocker actuators is actually missing, so will probably try one of Dave's modified Corvette actuators.
    Any advice from the wise men out there?
    Scott
  2. SonomaRik
    SonomaRik F1 Veteran
    6,884
    Sonoma, CA
    #2 SonomaRik, Sep 28, 2009
    Typically when they lock down, the indicator light goes on: looks like a side profile of the car with tiny up carrots "^" under each tire, something like the attached
    Doesn't mean you don't have a lock down, but typically in these cars that is the symbol to see.
    Shocks are not a bid deal to rebuild. Check out the '456 car site thead' http://ferrarichat.com/forum/showthread.php?t=218347 in this section and follow some of the links on 456 shocks.
  3. skl63
    skl63 Karting
    Dec 13, 2007
    227
    Scott
    Has anyone had an accumulator fail and is there a way to test them?
    BTW, thanks for the feedback Rick, but the light does not come on, which is also curious given the missing actuator.
  4. tazandjan
    38,083
    #4 tazandjan, Sep 29, 2009
    skl- No service parts on the accumulators so replacing them is the only option if they need replacing. They are pretty simple and are just cylinders with a membrane inside to dampen out variations/pulses in hydraulic pressure from the pump and reservoir. If a cheaper one will fit, no reason not to use it since the Cotroen was much more hydraulic intense than your 456.
    Did your technician bleed the system to make sure there was no air in the lines or components? That would seem to be the first step. Making sure the fluid tank shared with the power steering is operating properly would seem to be the next step.
    The shocks can be easily rebuilt and the pros here recommend Delta Vee: http://www.deltavee.net/parts.htm
    Dave's actuators are indeed the best way to fix, and in your case, replace actuators. That missing one means you are missing some parts needed to do the conversion, however.
    Taz
    Terry Phillips
  5. jbornwina
    jbornwina Rookie
    Mar 15, 2008
    43
    Overton
    Jeremy Ebdon
    A citroen dealer would be able to test the spheres provided they are of the same thread. Citroen spheres are able to be overhauled by specialists I believe - a company called Pleiades (google it) in the UK may be able to help
  6. Rifledriver
    34,119
    Austin TX
    Lots of people recharge bad accumulators.
    When the suspension light is on it is often in response to a "Locked" actuator. That does not equate a locked shock. It only means an actuator has failed and reset to a predetermined, midway position.
    Your symptoms can be explained by a bad accumlator. It doesn't really matter if it has never happened before. We see new things break every week. Every mechanical device will fail sooner or later. I do however get a warning light when they decide to throw in a suggestion to rebuild every component in the steering and suspension. It might need it but it still rings an alarm bell.
  7. Dave 456
    Dave 456 Formula 3
    Nov 15, 2007
    1,317
    Sydney, Australia
    Dave Simons
    #7 Dave 456, Sep 29, 2009
    Scott,
    Be careful with the Citroen sphere/accumulator idea, the working fluid may not be compatible as they do not use power steering fluid. How ever I'd guess that a Cit specialist could test it for you - I'm sure that there would be someone in Melbourne. There is certainly an outfit in Sydney that can rebuild spheres. If the diaphragm is damaged, its going to be a problem. Since Ferrari often use other manufacturers parts, or very close, the M-B idea might be a good one.
    I don't understand about the harsh ride though - I normally use mine in intermediate as I find the soft setting a bit wallowy - there is a noticable difference in the shock settings. Also, and I'm happy to be corrected, the accumulators are part of the self levelling system; with the accumulators not functioning, I think the shockers would still work normally. Are you sure that the springs are standard? maybe someone thought they'd be clever and make an "improvement"..
  8. Rifledriver
    34,119
    Austin TX
    The pressure in the accumulator provides the "Give" in the shocks. Without it they are rock hard. It has no self levelling function.
  9. Dave 456
    Dave 456 Formula 3
    Nov 15, 2007
    1,317
    Sydney, Australia
    Dave Simons
    I stand corrected! What does provide the self levelling function - is it entirely within the shock?
  10. Rifledriver
    34,119
    Austin TX
    #10 Rifledriver, Sep 30, 2009
    The shock is a hydraulic ram that raises and lowers by a pump filling it to greater and lesser degrees with fluid in response to a height sensing device.
    Neither the spring, the shock or the accumulator pressure support the car by themselves. It is a joint effort. The shock and the spring provide support. The spring and accumulator provide give or spring rate.
  11. kosmo
    kosmo Formula 3
    Oct 19, 2008
    1,569
    BIg D
    Taz are the accumulator item #54?
    Rik your pic reminds me of the Oscar Meyer Weiner Truck!
  12. tazandjan
    38,083
    Kosmo- Affirmative, #54 @~$600 each. Seems like someone like Delta Vee could make some money refurbishing those as well as shocks. If not too expensive, might make sense to swap them out as the shocks are rebuilt.
    Brian- Does synthetic ATF extend the lives on those accumulators?
    Taz
    Terry Phillips
  13. spiderscott
    spiderscott Formula 3
    1,654
    Ratarossa HQ UK
    Ratarossa
  14. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,305
    OnTheSerpentMound
    Aaron
    Ok guys, the accumulators on the 456 cannot be recharged like a Citroën sphere. The Citroën sphere can be disassembled and serviced whereas the 456 sphere is sealed. It's the same as a BMW part, used on the X5 SUV and very similar to the ones used on Mercedes wagons of 1980s era. Just buy the spheres from AutohausAZ or the like. Look them up for a BMW X5. Only thing you'll have to do is add a fender washer on the mounting bracket as one of the holes is larger than the original Ferrari sphere bracket was.
    Once they're changed, fire up the car and add ATF to the power steering circuit as needed to bring the fluid to level. Take the car for a drive and check/correct fluid again.
    One thing is to be careful when cracking the 11mm fitting on the old accumulator. Crack it loose just a bit at first and let the pressure bleed off before undoing the line further. And when you go to refit that line to the new accumulator, leave the accumulator loose in the bracket so you have some wiggle to make sure you don't cross thread that line, it's easy to do.
  15. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,510
    Scottsdale AZ
    Stu Boogie
    It does fit the 456 BTW
  16. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,510
    Scottsdale AZ
    Stu Boogie
    #17 scowman, Nov 10, 2018
    Can’t believe he set the box on the 355. That looks like a testarossa in primer gray on the right. Can’t ID the red one in the driveway...
    spiderscott likes this.
  17. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
    I think my other cars were:
    Testarossa Spider .....see my full build on here over in Testarossa forum
    355 Spider
    308 GTS
    Auraraptor likes this.
  18. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
  19. spiderscott
    1,654
    Ratarossa HQ UK
    Ratarossa
    or this for fun .....
  20. Mr Mezzanotte
    Mr Mezzanotte Formula Junior
    Aug 22, 2006
    632
    Febi Bilstein 07520 - quick note, to save people time in watching the video :)
  21. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,510
    Scottsdale AZ
    Stu Boogie
    I bought two on amazon a few years back but they are NLA there now.
    This is the cross reference.
    Febi-Bilstein Accumulator; 1991-1993 BMW M5; 1988 BMW M6; 1993 BMW 525iT; 1993 BMW 525iT; 1993 BMW 525iT; 1989-1995 BMW 525i; 1989-1993 BMW 535i; 1988-1989 BMW 635CSi; 1988-1992 BMW 735iL; 1988-1992 BMW 735i; 1993-1994 BMW 740iL; 1993-1994 BMW 740i; 1988-
    Manufacturer ‎Febi
    Brand ‎Bilstein
    Item Weight ‎3.76 pounds
    Package Dimensions ‎7.5 x 5 x 4.5 inches
    Item model number ‎W0133-1606445-FEB
    Manufacturer Part Number ‎W01331606445FEB
  22. Mr Mezzanotte
    Aug 22, 2006
    632
  23. mominayal
    mominayal Karting
    Feb 2, 2017
    116
    Indiana
    I was told by my mechanic that pelican and other sites that claim in stock actually don’t have in stock and there is a national back order. Now that was over a month ago when I was looking. I ended up having to spend double and get these
    https://rebuildmastertech.com/ferrari-456-456m-1992-2004-oe-new-suspension-accumulator-158693/?gclid=CjwKCAjw9J2iBhBPEiwAErwpeVIIuRZF3O8XLB5NwPD6khwS6bw-MhHOHGLgm_A8dmHfYTa7SwYlVRoCDZgQAvD_BwE
    They have been installed and are perfect. She rides perfect and completely transformed.
