456GT Center Console Removal | FerrariChat
Discussion in '456/550/575' started by renn20, Sep 9, 2021.
  1. renn20
    renn20 Karting
    Aug 21, 2019
    78
    SoCal
    KL
    Hi,
    Im about to remove my center console to fix the after-market radio wiring madness. There are wires going into the trunk via the center tunnel. also, some live wires going into the glove box.
    Been studying the parts diagram. Looks like they are just bolts but I find it hard to access. Before I call in the world's strongest person. Anyone has tips on removing the radio shroud, center console all the way to the back seats?
  2. Davidspop
    Davidspop Formula Junior
    Dec 23, 2019
    401
    Lance Malcolm
    I had to pull the back seat backs and bottoms, remove the rear console then you can access the screws under there... that and removing the shifter console area and ashtray (screw under there I believe) and take out the front gauge package (six gauges across the top) and it should lift right out. I did not take mine out completely when I installed my radio conversion... was able to get wires all sorted with the outer console in place.
  3. Jaredsalinsky
    Jaredsalinsky Formula Junior
    Feb 8, 2023
    685
    tampa FL
    Jared salinsky
    hey guys - reviving old thread. I'm about to do this to revamp my stereo stuff. any tips to removing the tranny tunnel trim? back seats and back center compartment?
    and what stereo stuff did you end up using?
    thanks
    jay
  4. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Can you let me know how the tire routing to the trunk works? I am going to run a sub cable from the head to the amp.
  5. Jaredsalinsky
    Feb 8, 2023
    685
    tampa FL
    Jared salinsky
    what do you mean by 'tire routing'? I'll try to find out exactly where my PO ran the cables for my system and let you know - i'm pretty sure he went from: battery/breaker (through fire wall with existing wire harness) along the right rocker panel under the passenger door, over the right rear wheel well (under the right rear seat) and into a LARGE capacitor sitting in the cubby in the upper right side of the trunk. then wires go down to 2 amps where the spare tire was. All the wires go from the amps to a digital processor next to the disc changer; THEN all the wires run back to the head unit in the glove box; I believe they run back to the front of the car under the tranny tunnel trim.
    i'll try to get pics this wknd
  6. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Sorry wire routing. Need N.A. route from stereo head unit to amp. I think the original head unit cable runs that route.
  7. Jaredsalinsky
    Feb 8, 2023
    685
    tampa FL
    Jared salinsky
    So I’m gonna run the wires for the stereo this wknd. I’m still trying to figure the simplest way to ‘gently lift’ the center tunnel without fully removing the gauge cluster and shifter console. I’ll let you know how it goes…
    Also any tips on removing the rear corner console (with arm rest) would be appreciated. I removed the 2 bolts/ 1 screw and it didn’t budge. Am I missing something?
    ty
  8. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Why not repurpose the stereo wiring harness currently in there? Cut and splice.
  9. Jaredsalinsky
    Feb 8, 2023
    685
    tampa FL
    Jared salinsky
    That is the plan for powering the unit. But theres a few ‘extensions’ to run- USB, antenna etc
  10. Ferrarienthusiast71
    Ferrarienthusiast71 Formula Junior
    721
    Charlie
  11. Jaredsalinsky
    Feb 8, 2023
    685
    tampa FL
    Jared salinsky
    Hey sorry for the lack i’ll follow up. Yes, it all turned out very very well. I ended up putting in a retro sound stereo which is period-correct look with modern technology. I did reuse some of the wiring, but I also rewired a lot of it myself. I kept the speakers that were in the doors and in the back because they were good and not cracking with decent sound. I hid my USB port in the ashtray and I put the microphone down left under the driver console. In the process of wiring, the stereo, I actually got rid of a lot of unnecessary stuff, including finding and removing a bad parasitic draw. Interestingly, I used a thermal radar thing connected to iPhone to see the hot relay. I’ll try to load up some pictures in the next couple of days of the hot relay and the radio and wiring
    Qavion likes this.
  12. Ferrarienthusiast71
    721
    Charlie
    Thanks for the update jared
  13. Jaredsalinsky
    Feb 8, 2023
    685
    tampa FL
    Jared salinsky
    Qavion likes this.
  14. Qavion
    Qavion F1 World Champ
    14,277
    Ian Riddell
    So did you identify it?
    Looks like an extra relay.
    The one with the red dot on it is the interior lights timer (21 in the parts manual).
    Maybe on your car, 21 and 22 are swapped over?
    22 is a "buzzer relay", although on US cars it's quite different. Euro car modules are more relay-like.
  15. Jaredsalinsky
    Feb 8, 2023
    685
    tampa FL
    Jared salinsky
    Yes, so the brightly lit up one is the extra relay, which was always stuck powered on and which of course was removed. What you can’t see just out of view in the picture to the left is where the buzzer relay would be, but that had been removed by a previous owner. No loss to me. Yes, the one with the red dot is the lights timer and that works fine.
    Highly recommend one of the thermal Flir, iPhone accessories. Very inexpensive and very helpful.
    Qavion likes this.
  16. Qavion
    14,277
    Ian Riddell
    Thanks for the tip, Jared, but I couldn't find any FLIR version below U$300 (postage not included). That's $500 Australian dollars :confused:
  17. Jaredsalinsky
    Feb 8, 2023
    685
    tampa FL
    Jared salinsky
    Qavion likes this.
  18. Qavion
    14,277
    Ian Riddell
    Considering the number of melting connectors people are finding on their relay panels, perhaps this will be a good investment for V12 owners.
    71veedub and Jaredsalinsky like this.
