456GT engine and transmission box oil capacity??? | FerrariChat
Discussion in '456/550/575' started by nFiniteGPU, Oct 12, 2009.
  1. nFiniteGPU
    nFiniteGPU Rookie
    Jun 7, 2009
    26
    Hello guys,
    Does any one knows what is the engine and gearbox oil capacity i'm about to change oil on it.
  2. tazandjan
    39,182
    456 GT 10.0 liters/10.5 qts engine, 5.0 liters/5.25 qts transaxle
    456M's tranaxle held an extra liter of 75W-90.
    Have the 456 GT OM in soft copy if you need one.
    Taz
    Terry Phillips
  3. nFiniteGPU
    nFiniteGPU Rookie
    Jun 7, 2009
    26
    #3 nFiniteGPU, Oct 12, 2009
    What do you reckon about 5W-50 oil for engine?Considering i'm living in area of hot temperatures.
  4. tazandjan
    39,182
    I would stick with a good 5W-40 or 0W-40 fully synthetic, as recommended. I run Valvoline 5W-40 fully synthetic in mine, and Mobil 1 5W-40 European Formula, Redline 5W-40, and Royal Purple 5W-40 are all good choices.
    The trend now is to lighter weight oils because the synthetics are so good the heavier weight oils are not needed on modern engines.
    Make sure and change out your coolant every 2-3 years.
    Taz
    Terry Phillips
  5. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    +1. Same here. FWIW, I was stuck in a fair amount of stop-and-go traffic in 90 degree + weather this summer and the oil temp never got to the 12 o'clock position. I see no need for a 50w oil.
  6. nFiniteGPU
    nFiniteGPU Rookie
    Jun 7, 2009
    26
    Thanks guys i will got for Mobil 1 5W-50.
  7. Dave 456
    Dave 456 Formula 3
    Nov 15, 2007
    1,317
    Sydney, Australia
    Dave Simons
    Terry, I made it 12 litres, including filters & oil cooler. I usually put in 10 litres, then warm up to check level - as per the OM, then add the remaining to get the level right. PITA, because I can only buy the oil in 5 litre containers - so I need 3!
    For the gearbox, add 1/2 litre if you want to flush the oil cooler & lines- this for a non-M model.
  8. tazandjan
    39,182
    Dave- Funny you should mention that. My 575M took 12.5 qts to fill the last oil change and calls for 10.5. Almost sounds like the fill is to the minumum mark.
    Taz
    Terry Phillips
  9. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    LOL, Well, I guess that shows how much weight my comments carry!
    When measuring the oil level be sure to do it:
    1. after the car has been brought up to operating temperature; and
    2. IMMEDIATELY after shutting off the engine.
  10. tazandjan
    39,182
    Allan- I was wishfully thinking it might have been a typo.
    Taz
    Terry Phillips
  11. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    If the subject matter was telecommunications law, I might have been offended, but I can't hold myself out as an expert mechanic, let alone of Ferraris, only an "informed consumer." So I can't be upset if my advice is blown off. BTW, The largest engine I've ever stripped down and put back together was a .35 c.i. two stroke model aircraft engine.
