456GT Weird startup issue | FerrariChat
Discussion in '456/550/575' started by tbjo1, May 6, 2023.
  1. tbjo1
    tbjo1 Rookie
    Nov 27, 2021
    45
    Oslo, Norway
    Torstein B
    I've got this recurring problem that sometimes when I try to start the engine on my 94' 456GT, it doesn't turn over. The electricity works fine, but the start engine doesn't kick in. The only think that works is waiting. Sometimes for a minute, sometimes for 10. In the end it always starts up easily, if I just wait long enough.
    I guess the character of the issue indicates an electrical problem, a block of some sort.
    As far as I've gathered the issue only happens when the car has already been driven that day, leading me to believe its a heating issue, that the car might be too warm, or at least thinking it is too warm, and therefore not allowing me to start.
    Has anybody else experienced this issue?
  2. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    I would start with a battery and or charging issue. Easy to have diagnosed at local autoparts store. Or multimeter if you have one and know how to use it.
    Then starter motor and electrical lines between battery and starter motor.
  3. tbjo1
    tbjo1 Rookie
    Nov 27, 2021
    45
    Oslo, Norway
    Torstein B
    Thanks for that @scowman I'll definitely look into that! I've got it scheduled in for a check up on the 22nd..
    However I did mention it to them before and they were clueless. And it just really doesn't feel like a problem with the battery. First of all the battery is brand new as well as the dynamo. Also all the other electrical systems start up without any problem when the key is turned in the ignition. And once the starter motor eventually does kick in, it does so with total ease and no further problems.
  4. fatbillybob
    Aug 10, 2002
    28,997
    socal
    You got a new starter? Why? What Lead up to getting new one? How long this no start situation?
    tbjo1 and scowman like this.
  5. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    Check cable connections at battery. alternator and starter since they were replaced. Suspect starter relay next. Never replaced that so I do not know where it is. FBB is on correct path. Why the new starter? Any other work done? Were parts new or rebuilt? Suspect rebuilt parts.
  6. Qavion
    Qavion F1 World Champ
    14,284
    Ian Riddell
    Assuming there is no immobiliser system fitted to your car, the circuit will be fairly basic. There may not even be a starter relay.
    I guess the only way to find out is by doing continuity checks between the ignition and the starter motor.
  7. Qavion
    14,284
    Ian Riddell
    Note that the 456M has both a starter relay and battery charger start inhibit relay. The 456M start inhibit relay is mounted in a relay socket with a built-in fuse (above the main relay panel, I believe).
    One of these:
    I think only the 456GTA (non-M) car has this type of fuse/micro relay holder. The gated car doesn't have these.
    I'd imagine these are to inhibit start if the automatic gearbox is not set up properly for start.
    Anyway, look at the base of the steering column shroud. There will be a connector with some large gauge wires on it. Disconnect the connector and (most-likely) there will be a white wire. This will be the starter wire. Do continuity checks between this and the small connector on the starter. If there is continuity, there is no relay in the system.
  8. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    I did not think about immobilizer as my car does not have that but yes, it could be related to an anti-theft circuit if equipped.
  9. Qavion
    14,284
    Ian Riddell
    Aftermarket immobilisers are probably one of the main causes of no starts on old cars. There may be an aftermarket start relay fitted.
  10. tazandjan
    39,167
    Ian- The Zivan charger was optional, so that relay may only be on those with that option.
    Qavion likes this.
  11. Qavion
    14,284
    Ian Riddell
    Here's a closeup of these type relays (on the 456M):
    The weird thing is, the fuses next to these relays aren't necessarily related to those relays. e.g. the rear cabin cigar lighter fuse is in the same holder as the RH inertia relay.
    Sorry for the thread creep.
    tbjo1 likes this.
  12. tbjo1
    tbjo1 Rookie
    Nov 27, 2021
    45
    Oslo, Norway
    Torstein B
    I got a new dynamo last summer as there were some issues with the old one, electrical systems switching off.. I can't remember right now what was the problem with it, but my mechanic put in a new one. But this start up issue was present before and also after this new dynamo..
  13. tbjo1
    tbjo1 Rookie
    Nov 27, 2021
    45
    Oslo, Norway
    Torstein B
    There is a theft alarm fitted, noticeable by a red light blinking in the dash when on. To be very honest I didn't even realise it was aftermarket. It's activated by a remote key locking the door and activating the alarm. Could this be causing it?
  14. Qavion
    14,284
    Ian Riddell
    The OEM immobiliser is only found on the cars with Motronic 5.2 engine management systems. I thought the 456's only switched to the 5.2 system later in production.
    Do you recognise any of these components?
    ... especially the Ferrari key fob. You should have two black fobs and one red Master fob.
    tbjo1 likes this.
  15. Qavion
    14,284
    Ian Riddell
    The Immobiliser on the 456M is wired into the starter relay. I'm not sure about the 456GT. I'm also not sure what part of the system would be sensitive to heat.
    tbjo1 likes this.
  16. tbjo1
    tbjo1 Rookie
    Nov 27, 2021
    45
    Oslo, Norway
    Torstein B
    Thanks all!! @Qavion Here is the key fob I'm using to open and lock the doors. Clearly aftermarket I realise now, it's a DEFA alarm system.. So this could be the culprit I guess?
    Qavion likes this.
  17. fatbillybob
    Aug 10, 2002
    28,997
    socal
    Very possible
    Qavion likes this.
  18. Qavion
    14,284
    Ian Riddell
    #18 Qavion, May 9, 2023
    You would have to find some kind of manual or schematic for the DEFA alarm to see how it interfaces with your car. It looks like DEFA is still in business, but I doubt they would have old manuals hanging around(?). You can only ask.
    https://www.defa.com/defa-security-tracking/
    Looks like it's an Norwegian company.
    Or, if you can find a central ECU, try Googling the part number. Also look for non-OEM wiring coming from the ignition or relay panel. Does it have a flashing LED? Maybe you could trace the wiring for that to an ECU?
    You may only need a new start relay (if it has one) ... not a whole alarm system.
    tbjo1 likes this.
  19. Qavion
    14,284
    Ian Riddell
    Note that your DEFA system may only be an alarm system, not an immobiliser. i.e. it may only have glass breakage sensors, jacking (level) sensors and forced entry detection on the doors.
    That means we will have to look elsewhere for a solution.
    tbjo1 likes this.
  20. scowman
    scowman F1 Rookie
    Mar 25, 2014
    2,550
    Scottsdale AZ
    Stu Boogie
    If it were mine I would strip it out and repair any wires. They probably used line taps but I have seen ugly hacks for security aftermarket installs.
  21. tbjo1
    tbjo1 Rookie
    Nov 27, 2021
    45
    Oslo, Norway
    Torstein B
    I'll definitely get in touch with DEFA. It being a Norwegian company actually makes it easier as that's where I'm located. It does have a flashing red light, picture attached. You can see it in between the switches. Again - I thought this was original, it does look quite neat :)
    Qavion likes this.
  22. tbjo1
    tbjo1 Rookie
    Nov 27, 2021
    45
    Oslo, Norway
    Torstein B
    Hmm yes maybe. I'll know more after getting in touch with DEFA hopefully... I'll keep you all posted, and thanks again!!
  23. Qavion
    14,284
    Ian Riddell
    Yep, that's why I mentioned it.
    Just a wild guess, but I'd say you're in Oslo :D
    I'll have to start thinking about "plan B" if your alarm is just an alarm.
    Unfortunately, the probably may be hard to identify as the car recovers so quickly.
    By the time you've set up your test equipment, the problem may have already gone.
  24. tbjo1
    tbjo1 Rookie
    Nov 27, 2021
    45
    Oslo, Norway
    Torstein B
    Turns out the alarm system indeed has a connection to the ignition. I emailed DEFA and they quickly called me back, and sent me the diagram for the alarm. It is possible to wire around the start up block, and use the alarm without it. I'll try that first and we'll see what happens. I'll keep you posted!
    Qavion likes this.
