Suggested that the above titled thread be added to this forum from the Technical Forum. Basically, '97 GTA having issues with overheating at idle due to cooling fans not operating. Lost about 1 gal of coolant due to overheat. Replaced the coolant, think the system has been blead, checked fuses, relays, wiring and all look to be fine. While the bleed process was in place, turned on AC and the engine cooling fans immediately fired and kept the engine @ normal operational temp. The link from the other thread with comments/suggestions: 456GTA Cooling Fans | FerrariChat Appreciate your help in diagnosing, parts sourcing if needed, or any WAG that will get this issue resolved. Regards, DJ
Quick off top of my head - make sure your fuse panel is ok. If not replaced, I would recommend talking with Guido
