456GTA trany leak | FerrariChat
456GTA trany leak
Discussion in '456/550/575' started by 456junkie, May 24, 2008.
  1. 456junkie
    456junkie Rookie
    May 23, 2008
    5
    anyone out there know how to fix the gear oil leak for a 456GTA? is it possible to fix or am i screwed? gear oil is leaking...trany has never had an issue other than this...i'm being told that i need a new transmission and the thought of paying $22k for a new one makes me want to shoot myself in the head.
  2. kidwhizz
    kidwhizz Karting
    Feb 16, 2008
    165
    #2 kidwhizz, May 24, 2008
    Very sorry to hear, not had anything like that myself - But how much mileage has it done out of curiousity and has it been used on a track, dont often hear this "real" situation often.
    Closest I did was to check the gear oil when car was warm and it was spot on what it should be. Not sure if it applies but did you over fill it at anytime?
    Also worth checking in the 456/550/575 Forum there is a thread where someone has posted a couple places in the States where they specialise. On www.eurospares.co.uk there is lot of useful diagrams - The gearbox assembly certainly has a lot of seals - maybe doing the simple checks first - 2nd opinions etc, and replacing seals.
    Also does it leak when stationary? Is there a pool under the car when you come and check in the morning?
    Worth posting your mileage/year or manufacture etc.
    I have posted the M 456 Gear box assembly on here FYI. As you can see it is for me anyways quite a few bits - but if you can locate the leak area it "may" assist in determining the seal or part which is defective - hopefully it is a simple or more cost effective than the figure you quote.
    Please keeps us all posted.
    kindest regards Aamir
  3. 456junkie
    456junkie Rookie
    May 23, 2008
    5
    Aamir...much appreciated for this! It is a 97 and has about 28k miles on it. Other than this issue, the car runs beautifully! Oh, the window regulator's are flawed, but mine seems to better than other 456's i've seen.
    The recent drip is a constant drip and yes it does pool after I drive it. I have never taken it to a track, and for the most part am pretty easy on it (except for the occassional 80MPH on ramp turn)
    It will drip for a good hour after I turn the car off, and the spot is the size of a grapefruit, right where the transimission meets the rear end. I just recently had the tranny taken apart and one of the seals replaced ($2100.00 at that) My mechanic is very knowledgable with Ferrari's (all he works on) but is having problems getting parts since the transmission is sealed and not serviceable??? (Ferrari is telling him this). Maybe I need to take it to someone who has dealt with this before (i'm in Orange County, CA)
    Reading a couple other comments on this site, I learned that this seems to be a major flaw with the 456GTA's, and a reason why they do not retain their value???
    Thanks for the info Aamir...i'll see what i can come up with before I shoot myself.
  4. kidwhizz
    kidwhizz Karting
    Feb 16, 2008
    165
    Hmmm... got me thinking I once had a oil leak not an issue when you ran the car all pressure and oil temp etc was good ... but after I parked up there was a small oil deposits under the Oil tank, It seems that I had gone over a road hump and a hairline crack had formed in the tank reservoir. It was quite an expensive part. So the clever guys used some "metal glue" they used on Aircrafts to stick on wings or something this sealed the unit - never had a leak since. Wondering if you have taken a Knock or something?
    Again - this is about the second time I have heard this for real - so Pahlease do not shoot yourself. ;)
    kind regards Aamir.
  5. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    You are told you need a new transmission because of an oil leak!! Farrrrkk off!!! :p:p
    It can only be a seal and I am sure it can be fixed. If they reckon they cannot get seals for it, then I call BS. Ferrari has seals made for them. They do not make their own seals in-house. Possibly be SKF seals me thinks. ;);)
    You need your mechanic to pin-point the oil leak, pull it apart, then see which seal is leaking and get the part number off it.
    If there is no part number available, then take the seal into a parts shop that specialises in seals and match one up. :):)
  6. Horsefly
    Horsefly F1 Veteran
    May 14, 2002
    6,929
    I think that the ominous 456 transmission has been mentioned before. Apparently Ferrari considers it a NON serviceable item! And they don't offer any internal parts.... I remember posting a thread about one that I saw on E-bay a few years back. That's when I learned that they were basically UNrepairable. Sounds like a Ferrari racket to me.
  7. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Surely it can be pulled apart and seals replaced?? Thats all we need here. Id be more worried if the transmission was worn/slipping. I doubt there would be something similar out there to exchange parts with. :(:(
    But a dirty old leaking seal can be replaced. I hope....... :):)
  8. kidwhizz
    kidwhizz Karting
    Feb 16, 2008
    165
    Totally agree with Pap on that one ;) and with the amount of posts he has I don't think Ferrari should even consider qustioning his judgement ;)
    It would be a sad situation if that renders the Sale of the 456 careful owner low mileage just" needing cost new gearbox. If I knew that this was the only thing wrong with it and I had cash to burn - this would be a great Buy ;) I would start with taking off all the seals and rubber off my wifes utensils and pressures cookers in the first instance ;).
    Joking aside - the 456Junkie indicates that the Mechanic has already done a seal, i'd say do it again pretty please.
    No offence - Any pics of the car and said Oil Leak? some are getting sceptical of the post.
    kindest regards Aamir.
  9. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Thats what I would do. :D:D
  10. Pranucci
    Pranucci Formula 3
    1,127
    Carpinteria, CA
    Sorry to hear about the leak.
    My question is why did you have the seal replaced the first time? Was it for a leak? Since it seems that parts aren't available, did your mechanic
    'make ' a seal fit? I remember seeing other posts that have named the manufacturer of the box. Was it GM?
  11. wetpet
    wetpet F1 World Champ
    10,210
    good luck
  12. dkabab
    dkabab Formula Junior
    Oct 27, 2007
    941
    Adelaide, Australia
    David
    #12 dkabab, May 25, 2008
    i remember reading something on the 456 auto trans, it was made by a company in America i think, it was designed similar to a standard american common box, sorry i dont remember the detials, but this whole topic has been covered before, might be in the 456 forums
    EDIT: heres the topic you should read
    http://www.ferrarichat.com/forum/showthread.php?t=118551
  13. DM18
    DM18 F1 Rookie
    Apr 29, 2005
    4,725
    Hong Kong
    Would it make more sense for this interesting thread to be under the 456 section where there might be more expertise and more other 456 owners who will benefit from the experience?
  14. 456junkie
    456junkie Rookie
    May 23, 2008
    5
    Originally, there was a smaller leak (in the same spot as the newer "bigger" leak - right where the trans meets with the rear end). You could smell the leak as it got hot. I was concerned that there could be a fire hazard so i had my mechanic take a look at it. We decided that a seal was probably the problem and the area that was the problem, seemed "fixable" (this was the first attempt). He consulted a few people that indeed this area had a seal that was available. When he took the unit apart, the central seal was noticeably fatigued (i saw it myself). We replaced it and for a few weeks, no leak.
    Now we are at the second attempt, and this is where he is getting the unserviceable BS feedback.
    This is why we are stumped. He did not break into the meat of the transmission, just the end part of it (sorry, I'm not a mechanic and don't know the mechanical terminology). It is just this area that poses the problem. I guess the meat of the tranny that is deemed "unfixable" by Ferrari?
    Since it is just gear oil leaking (again, the transmission is mechanically fine and works great-no slipping or crunching at all) can i use this "metal glue" to fix the leak if possible? Just wondering if there maybe something more at issue further inside the transmission.
    thanks.
    (i've attached a picture of my car...car in the shop so i dont have picture of leak)
  15. kidwhizz
    kidwhizz Karting
    Feb 16, 2008
    165
    Metal Glue - around the seal ....Hmm I am not sure if that will work - the area where it was used was in my instance was a hairline crack in a metal assembly. time try all things e.g. fabricate or get a hold of a bigger "fatter" Seal - see if the holds the oil in.
    Really sad to hear that this is still an issue. Again, ref overfilling etc. any issues there?
  16. PAP 348
    Dec 10, 2005
    100,220
    Pap
    If he replaced the seal once, do it again. :D:D
    A seal is a seal. There are thousands of them out there. Pull it apart again, remove the seal and get one matched up at your local seal shop (SKF?) and throw it back in there. ;);)
  17. oss117
    oss117 F1 Rookie
    Jan 26, 2006
    4,185
    Plantation, Florida
    Alfredo
    #17 oss117, May 27, 2008
    If the transmission is working fine, but is leaking some oil, then whomever is suggesting you to replace the transmission is giving you plain BS and is trying to take you for a ride.
    If the leak is from the same spot as before, then your mechanic did not do a proper job the first time and unless he offers you to do it over again at no extra cost to you, it may be a good idea to go somewhere else.
    There is nothing magic or arcane about an automatic transmission and much less it is "sealed and non serviceable".
    As the saying goes "if there is a will there is a way" and you need to find an independent that is willing to use his brain to fix your leak.
    It may be more than a seal or a gasket (i.e. the seat may be dirty or the surfaces may be slightly damaged) but it cannot be impossible to fix, but please do not use metal glue or anything like that.
  18. f40car
    f40car Karting
    Jul 25, 2006
    63
    NJ
    ZZ
    #18 f40car, May 31, 2008
    it's just a seal, and in most cases you will just need to re-torque it.
    when replacing the seal, was it torqued per spec?
    who told u 22K for a new tranny because of fluid leak? crazy.
  19. ihassan
    ihassan Rookie
    Jul 8, 2007
    23
    Southern California
    I don''t know who your mechanic is. However, if you are in the orange county area, you might want to get in touch with Joe at Concourse Automotive in La Mirada or La Habra. I can't remember the city. He seems quite knowledgeable and helpful.
    Good Luck
  20. Bavarian Motorist
    Bavarian Motorist Formula Junior
    Apr 10, 2007
    943
    Westchester/NYC
    I always thought it was more of the fact that it's an automatic.
