456M - AC pressure (cooling fan) | FerrariChat
Discussion in '456/550/575' started by Jan456, Mar 19, 2020.
  1. Jan456
    Jan456 Karting
    Oct 1, 2008
    145
    the Netherlands
    Jan Scholte
    Hi,
    I replaced the AC-compressor on my 456M last year and after that a brilliant summer with a cool cabin and cooling fans that were triggered properly keeping the engine temp low :).
    Now starting the car after the winter sleep is the AC-system not waking up :(. Meaning no cool air and the cooling fans are not triggered. I assume the AC-pressure is too low. Of course I can refill it at the dealer, but wonder if there is a weak spot in the AC system that cause a leakage? As I replaced the AC-compressor last year do I expect a leakage somewhere else.
    Appreciate your help, best regards Jan
  2. Rifledriver
    37,106
    If you were not losing freon before and you are now with a new compressor? That would be the first place I'd look.
    Also the service ports. I have had so many Schrader valves go bad and leak when charging I just replace them 100% of the time now.
    In any event this needs to be a philosophical discussion. There is no reason or justification for not testing the system for leaks. It is far to easy to be avoided in lieu of free advice that is vastly overpriced. A/C should be leak tested every time you touch it.
    Qavion likes this.
  3. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    Exactly. When you had the pump replaced, they should have added UV dye for leak detection. If so, a UV light and yellow glasses will help find the leak. Better still, just take it to a professional. They’ll isolate your fault pretty quickly, the 456 A/C system is very basic.
  4. Jan456
    Jan456 Karting
    Oct 1, 2008
    145
    the Netherlands
    Jan Scholte
    Thanks guys for the response! Got feedback from the dealer, the 1y old compressor is the reason...., will be replaced under warranty.
    best regards, Jan
    Qavion likes this.
