456m bellhousing timing mark question | FerrariChat
Discussion in '456/550/575' started by gte4925, Jan 4, 2024.
  1. gte4925
    gte4925 Rookie
    May 12, 2023
    3
    Alex L
    Hi all, does anyone know what to line up the flywheel timing marks against? There is no pointer or mark that I can see when looking through the bellhousing cut out.
  2. Rifledriver
    37,087
    Have a picture? I am unaware of any flywheel timing mark.
    I just thumbed through the manual and see no mention of a flywheel timing mark.
  3. gte4925
    gte4925 Rookie
    May 12, 2023
    3
    Alex L
    They are stamped into the top of the flywheel and can be seen through the a cast square opening on the drivers side top of the bellhousing.
  4. Rifledriver
    37,087
    Have a picture? Factory says nothing about them.
  5. tazandjan
    39,160
    Somebody put a Daytona engine in a 456M?
  6. Rifledriver
    37,087
    #6 Rifledriver, Jan 7, 2024
    Daytona timing marks were on the bottom.
    I was just looking at pictures of 456 blocks. There is no hole I can see in the top rear of the block or the bell housing.
    There are holes about 30 degrees from the top in the bell housing but those are not for timing.
  7. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,944
    The Cold North
    Tom
    Brian is correct..there are no marks on the flywheel. To find TDC use a dial indicator or piston stop.
  8. tazandjan
    39,160
    Brian- Yup, spent a bit of time lying under mine while the wife ran her up to 5000rpm.
  9. Rifledriver
    37,087
    Takes a little getting used to.
  10. tazandjan
    39,160
    Affirmative, a bit noisy down there with things going round really quickly. Too old (lazy?) for that now. Plus, my Daytona was $5000 and a $10,600 Dino. A bit more now.
