News
456M Engine out procedure
Discussion in '456/550/575' started by stekkefun4, Feb 7, 2018.
  1. stekkefun4
    stekkefun4 Formula 3
    2,022
    Belgium - Europe
    I've been searching this section on an engine out procedure on a 456M and can't seem to find one. I need to take out the engine for a rebuild. I've also searched the interwebs and looked at the workshop manual, but no concrete plan.
  2. asgor
    asgor Formula Junior
    Sep 8, 2016
    294
    Virginia, USA
    Dude, here are the steps:
    1) Take car to shop
    2) Mechanic takes the engine out
    3) Write cheque to shop
    No, really: as an amateur, spare-time, Sunday-afternoon mechanic (hey, I can do oil changes and a few other things!) I can't even begin to imagine what's involved with taking the V12 lump out of its cradle. I admire those who can pull it off on their own :eek:
    rubenpadron and Laserguru like this.
  3. stekkefun4
    2,022
    Belgium - Europe
    LOL, that would have been an option, but no, I have it in my garage and I'm dismantling it. I have already removed everything that surrounds the engine, but have arrived at a point that I either take my time to find a guide, or do it like I think it goes: deconnecting the driveshaft and clutch and removing 2 bolts with which the engine itself appears to be attached to the chassis.
  4. Cribbj
    Cribbj Formula 3
    1,895
    Houston
    Do you have a lift or are you doing this with the car supported on jack stands?.
    I've done an engine out on my 550, and so has another Houston owner, and it's not "that" bad. In fact the worst part (for me) was getting the transaxle moved back. For me, removing the heads from the 550 with the engine in situ was more of a PITA than pulling the whole engine.
    The procedure for the 550 was generally:
    1. Disconnect everything (oversimplification, I know) (don't forget the engine mounts themselves!)
    2. Remove exhaust manifolds & exhaust system
    3. Remove torque tube mounts at bell housing, remove shifter linkage from transaxle, remove transaxle mounting bolts, and axle half shaft bolts, and slide the whole torque tube/transaxle assembly to the rear about 10cm, or until the splined drive shaft is free from the engine. Both torque tube & transaxle must be well supported when you do this! Mind the braided oil hoses from the transaxle to the oil cooler
    4. Remove hood/bonnet from car
    5. Lift engine out
    The point where you'll probably have the most interference is getting the engine out past the cross member. I found that pulling the engine out at a slight angle where the front was elevated more than the rear seemed to help.
    The 550 and 575 workshop manuals are worth obtaining and looking at, as they give fairly good, detailed procedures on how to do all this.
  5. stekkefun4
    2,022
    Belgium - Europe
    Thanks for your input.
    I could also go for the alternative: get the engine out by working from top to bottom, one part at the time until only the crankcase remains to be taken out.
  6. Cribbj
    Cribbj Formula 3
    1,895
    Houston
    Well, I'd suggest getting the intake manifold off, and the radiator, etc. out of the way, but getting the heads off in situ is a royal PITA. Those last outboard nuts on each head are nearly impossible to get to. On the 550, they're nearly recessed behind the firewall......
  7. fatbillybob
    fatbillybob F1 World Champ
    Owner Consultant
    Aug 10, 2002
    15,959
    socal
    I have not had to remove the driveline of either of my 550's but it looks just like the modern corvettes with engine, torquetube, and transaxle. I find this design particularly easy to work on and it is faster to remove the whole driveline enmasse and lift the chassis off the driveline and roll it out. This is similar to how we take the subassemblies out fo the 348/355 Ferraris. I welded this rolling driveline holder for my corvette racecar out of simple 1" square tubing. I don't know if this helps you but may give you ideas. Personally, I would be looking at dropping the whole enchillada. That also gives you easy access to get to all the other while you were in theres.
  8. stekkefun4
    2,022
    Belgium - Europe
    That's an option too, but I have to take the limited height of my ceiling into account (2m 20cm). I think the preferred method is by detaching the drive shaft.
  9. tazandjan
    tazandjan Two Time F1 World Champ
    Owner Lifetime Rossa
    29,337
    Albuquerque, NM
    To get the driveshaft off, like John said, you have to disconnect the half shafts, remove part of the exhaust system, and slide the transaxle back or remove it, just like you do to change a clutch.
  10. stekkefun4
    2,022
    Belgium - Europe
    Thanks, I'll have to do it that way because dropping the engine out of the car doesn't work. It cannot drop out of the frame. It's a PITA to reach the underside of the engine mounts to fix the bottom side of the bolt to loosen it from the top though ...
  11. franschman
    franschman Karting
    Dec 18, 2017
    56
    Holland
    Bart Boosman
    For an engine out (throught the top), do you actually need to remove the exhaust manifolds while the engine is still in the car?
  12. stekkefun4
    2,022
    Belgium - Europe
  13. Cribbj
    Cribbj Formula 3
    1,895
    Houston
    I think pulling the engine as you did is probably easier than pulling the heads with the engine in situ. I think if I ever have to do head work again, I'll just pull the engine :)
