456m GTA Automatic transmission light on | FerrariChat
Discussion in '456/550/575' started by 736973, Dec 28, 2008.
  1. 736973
    736973 Karting
    Nov 25, 2007
    75
    my 456 M GTA Automatic transmission light came on and off last night, but what I have recently experienced was that when I step on the gas, the car doesn't really go, is like a manual transmission with no clutch, anyone knowwhat is going on with my car? thanks
  2. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Can you tell us more about the car? Mileage/most recent transmission service and more description on car behavior specifics? I'd sure be interested because there are a lot of threads wondering about potential auto tranny maladies.
  3. 736973
    736973 Karting
    Nov 25, 2007
    75
    1999, 30000kms, did servicing at 25000kms, it drives, but when u step on the gas hard, it doesn"t really respones........
  4. kosmo
    kosmo Formula 3
    Oct 19, 2008
    1,569
    BIg D
    could it be the torque converter?
  5. 736973
    736973 Karting
    Nov 25, 2007
    75
    no idea, what else could it be ???
  6. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Did you check the transmission fluid level?
  7. deanhalter
    deanhalter Formula Junior
    Dec 27, 2008
    357
    Norco, CA
    Dean Halter
    If the car goes as it should at light throttle settings, but seems to lack response when pushed, the clutch is likely slipping. This is not good. The oil pressure in the transmission system (provided by a pump inside the unit) is used to keep pressure on the clutch pack when the car is in gear, bleeding this pressure off when shifting occurs. Check the rear of the car under the bumper for oil residue and check the transmission fluid level as directed earlier. No oil = no oil pressure. If the level is low there is likely a leak and it will end up at the back of the car. If the oil level is normal, is it discolored? Does it smell? If the clutch is slipping it is wearing and can put particles in the oil and heat it to the point where it will become "burnt."
    Don't know if these are computer controlled but I would be surprised if they aren't. I would check for any electrical connections to and from the transmission. Unplug them, clean them with an electrical contact cleaner spray and reconnect.
    It goes without saying that you should be VERY easy on the car until this is resolved...
  8. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    I realize that it's the holiday season, but I sure am curious. There's always been talk about something going wrong with the auto tranny but never any documented cases.
  9. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,667
    South East
    Jimmie
  10. SonomaRik
    SonomaRik F1 Veteran
    thinking an OBD would help
  11. 736973
    736973 Karting
    Nov 25, 2007
    75
    everyone, thanks for your help, I am just wondering if my transmission really does break down, what can I do, what is the cheapest way to get my car going again...............................
  12. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    Check out the thread with the search function. Depends on what a "break down" is, but there have been lots of "what if" discussions on the board, most expressing high anxiety over the question of whether and who can do a full rebuild.
  13. Ryton456
    Ryton456 Rookie
    Apr 24, 2007
    6
    I've got a '97 model 456 that had a similar problem.
    When driving normally there was a sudden but slight jolt and the auto box warning light came on.
    After stopping the car and restarting the light went out but it happened again until after a few miles the car was acting as if it was either stuck in 1st or out of gear all together as the engine would rev but no drive.
    When it was investigated by the local Ferrari dealer it was diagnosed as solenoid failure in the box, preventing selection of the gears.
    After a £7500 rebuild it worked perfectly!
  14. Modificata
    Modificata F1 Rookie
    Apr 27, 2003
    2,654
    Hampton, England
    Andy Rasool
    Crikey!
  15. fatbillybob
    Aug 10, 2002
    29,022
    socal
    #15 fatbillybob, Jan 8, 2009
    Rumors are that these autoboxes are about 1/3 to 1/2 the value of these cars! GM 4L80T are also rumored to be the guts of these boxes. No volume shop which does GM boxes will help you here but you may be able to find a low volume guy who races or small race shop that does 4L80's to experiment with your box to first see if the guts are indeed 4L80 and if he can fix it. It is wise to do it now before you have a grenaded box. You could have some simple solinoid out to need of total rebuild. There are so few of these cars that no one really has torn into one of these or at least reports are non-existent as far as I know. I have no experience with 456A boxes but I sure would like to get my hands on one to play with. Then, if it is 4L80 I'd like to wire it for paddles like the C6 vettes, reprogram the computer and have 90% of a Ferrari F1 shifter in a bullet proof slushbox in no need of an SD2/3. C6 vette guys have their 6 speed autoboxes shifting at 100ms speeds, blipping throttle etc...about the speed of the 360F1. If this could be done the value of the 456A would jump.
    I should qualify my statements with saying why not investigate whether the F dealer can get any computer diagnostics from the gearbox before you guess at what is wrong. If they tell you funny things that don't make sense look elsewhere.
  16. lindseyp
    lindseyp Karting
    Nov 19, 2008
    55
    Tokyo
    Thanks. I've already been in touch with Adrian there. One option for me is to send my transmission to him for an overhaul. Logistically not ideal as we're in different hemispheres, but not impossible and certainly cheaper than getting a new one.
  17. kosmo
    kosmo Formula 3
    Oct 19, 2008
    1,569
    BIg D
    what did the local dealer say?
