456M GTA Torque Tube Removal | FerrariChat
Discussion in '456/550/575' started by leadingedge, Dec 5, 2018.
  1. leadingedge
    leadingedge Rookie
    Jun 16, 2015
    3
    Has anyone removed the torque tube to replace the bearings, or had it done, if so, about how long did it take/ what was charged for labor? Did the entire transmission need to be removed to do so?
    Trying to get an idea if it's something worth doing myself or taking to a shop/ dealer...
    Thanks!!
  2. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,307
    OnTheSerpentMound
    Aaron
    It's a reasonable bit of graft. Disconnect transaxle and move it rearward and you can get the TT out but you may have the inner nylon/plastic sleeve hang up on the output shaft so will require fiddling to clear. As for the bearings, they're a proprietary Ferrari item, so you're stuck buying from them directly or Superformance in the UK. Watch transaxle once disconnected from TT and mounts, it's a heavy sonofabitch so make sure it's well supported before jockeying it back.
