456M Radiator Repair Info... | FerrariChat
Discussion in '456/550/575' started by Mirek, Feb 2, 2021.
  1. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
    My 456M popped a small leak right about a month after the car overheated (due to a fan becoming unplugged). Car has been at Blackhorse here in LA for a while now and I am told that the radiator was super dirty but that should not have caused the radiator to crack right ? Pics below.
    It would hit a HIGH temp (image) and then drop back down, each time spraying JUST enough coolant that you could see a bit when opening the hood. When I dropped it off it was steaming up through the hood though.
    Question, anything I should have replaced or inspected while the radiator is out? I am told they are going to weld it up and clean it. Should I request Carl flush it out (or anything like) that to prevent future problems ? Or look at new fans ?
    Thanks for any help or direction guys !
  2. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    710
    Toronto
    Ryan
    Lots of crap collects between the radiator and the AC condenser. Need to clean it out every once in a while. Might be worthwhile replacing the fans if they are original. I put new fans in my 550 last year and noticed significantly better cooling.
  3. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
    Thanks for the input.
    I wonder if that is why my fans used to kick on and off all the time. Once the radiator is repaired I cannot see another weak link. All of the hoses have been replaced and fans operate correctly. Hope hope.
  4. fridolin_pt
    fridolin_pt Karting
    Mar 25, 2008
    162
    Germany NRW
    Fritz
    The Radiator is a weak spot in the 456M. I have replaced it completely as repairs did not last long.
  5. franschman
    franschman Formula Junior
    Dec 18, 2017
    362
    Holland
    Bart
    #5 franschman, Feb 3, 2021
    One of the real weak spots in the fan arrangment is the connectors to the actual fans.
    They are identical to the connectors used in my Lancia kappa, which has overheated only once (while towing a 2 ton trailer on the hottest day of the year, in heavy traffic), when the fans didn't kick in because of poor contact inside the connector. The connector had actually burnt away, creating a short which triggered the fuse.
    When I got my 456 and noted these connectors, I opened them up and sure enough, they were burnt inside and about to fail. So I upgraded these connectors to one gauge heavier.
    F456M, Fennicus, Mirek and 1 other person like this.
  6. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
    That is funny. The first overheating incident was because my fans did not come on.....due to an issue with the connection as well. They said it had become unplugged (?).
    Hopefully that does not occur again (since it was addressed) but I will certainly bring this up with the shop specifically and thank you.
  7. Fennicus
    Fennicus Formula Junior
    Apr 10, 2015
    593
    Helsinki, Finland
    Pekka T.
    Hi,
    I just noticed a similar issue with the A/C fan resistor. The main connector had burned the connector to the black wire and toasted something in the Davia unit which is now NLA! (Although a similar later resistor was used in 355, 550 and possibly also other models than 456/456M)
    Funny thing, the original one I had spared works ok now, I have cleaned and fixed the connectors. I think I’ll have someone repair the one I bought 3 years ago, some components (caps / resistors) probably just got fried thanks to the poor connectors. :-o
    Cheers!
    Mirek likes this.
  8. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    You can NEVER get too much cooling.
    Mirek likes this.
  9. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
    Oddly enough the shop called and asked if there was anything else they should look besides the overheating radiator and and I requested they check “the electrical connections to the fans.”
    Thanks for that heads up !
    F456M likes this.
  10. henryr
    henryr Two Time F1 World Champ
    22,415
    Atlanta
    Juan Sánchez Villa-L
    dump it and buy a ron davis
    the have done numerous. works way better than factory
  11. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
    I would prefer to and I did get quote from Ron D. and do run a RD in my 700hp C5 but the lead time was 6 weeks or so and the shop I am at (Blackhorse) is a top-notch Ferrari shop and said It was not necessary at this time so I will punt on that for now.
  12. henryr
    22,415
    Atlanta
    we put a RD in my moms 456s made a huge diff
  13. Davidspop
    Davidspop Formula Junior
    Dec 23, 2019
    401
    Lance Malcolm
    That just struck me funny..."my mom's 456....".....
    Anybody have a link to Ron Davis radiators? I may do this as a preventative along with the connectors!
  14. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
    Yea my biggest automotive fear is overheating...and here we are !
    As a youth, I had high mileage 4th gen F cars which were prone to overheating and was always scary. I really really hope this does not re-occur, I kinda wish the shop had me order the RD.
    This forum is pretty great in helping me sort this machine.
  15. Mirek
    Mirek Formula 3
    1,494
    Los Angeles, CA
    Mirek
    Good call !
    Blackhorse had to take apart the fusebox, re-solder the connections to the fans and clean them. Picking it up today !!!
    franschman likes this.
  16. tazandjan
    39,186
    rondavisradiators.com
