456M screech on start up | FerrariChat
Discussion in '456/550/575' started by KeithS, Aug 1, 2019.
  1. KeithS
    KeithS Karting
    154
    Paradise Valley, AZ
    Keith Stephens
    My car is 1999 456M, 6 speed, 73,000 miles, major service 2/2017, tension bearings and motor mounts upgraded to 575 models. I am in Phoenix, AZ.
    At cold start the car has developed a very loud screech on that usually last for only a few seconds. Lately the screech has lasted longer, maybe 30 seconds, and becomes louder with increase in rpm. On restart there is no screech. It sounds to me like a bearing going dry. Accessory belts have been adjusted and the screech occurs with the AC off.
    Any thoughts or suggestions appreciated.
    Keith
  2. Joey4420
    Joey4420 Rookie
    Apr 6, 2018
    41
    Hamilton, Ohio
    Joey Shreve
    Have you tried using a mechanics stethoscope to listen as it is started?
  3. AVIMAX
    AVIMAX Formula Junior
    Aug 5, 2014
    714
    Toronto
    Ryan
    My 550 developed a screech on startup. Initially it was only once in a while, but got worse. It was my clutch release bearing.
    Joey4420 likes this.
  4. KeithS
    KeithS Karting
    154
    Paradise Valley, AZ
    Keith Stephens
    Keith
  5. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,197
    CA & DC
    Alternator / water pump maybe?
  6. killer58
    killer58 Formula 3
    Jun 30, 2010
    1,197
    CA & DC
    Alternator / Water Pump maybe ??
  7. tazandjan
    39,316
    Get a piece of hose and try to locate the source at start-up. Unless the temperature is below 59 F, there is a good chance the AC compressor is on regardless of the setting. At least it is in a 575M.
  8. bergxu
    bergxu Formula 3
    Aug 16, 2005
    1,307
    OnTheSerpentMound
    Aaron
    Does it seem that the noise is emanating from the front of the engine? I’d remove the belts from all of the ancillaries and fire it up just briefly and see if the noise goes away. That’ll narrow it down quite a bit at least. Obviously don’t run it for more than 10-15 seconds since you won’t have water circulation. But before firing it up, spin all pulleys and see if you hear and/or feel anything abnormal.
