456M - What valve guides and where to buy them? | FerrariChat
Discussion in '456/550/575' started by henri66, Aug 26, 2013.
  1. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Previously Maranello
    Hi guys,
    We are suffering in our Dec 98 456 MGT some oil consumption and fume since we bought it two years ago. Valve guide has been the issue.
    After topping up the oil reservoir with 1+ liter every 1000 kms, we have finally decided to cure the issue.
    With the help of a fantastic ferrari owner and skilled mechanic, we have remove the 2 heads and also dismantel all parts.
    The intake and exhaust valves looks OK, the intake guides also (a doubt on maybe two intake ones).
    But the Exhausts valve are really "floating" in the guides for most of them, without mentionning that the valve seal is most of the time loose.
    I will post some picture, but around the guide, the burnt oil is also VERY present.
    Now my question to all of you my friends is: what reference to buy? Knowing the original bronze/copper ones were a POS.....
    Do we go for replacement OEM ones?
    Do we try to find someone turning some good ones with a different material?
    I am based in France but can consider any viable option, ie quality and cost.
    Thanks for your help.
    Henri
  2. SonomaRik
    SonomaRik F1 Veteran
    SN?
    thought the M's were not prone to this so you must have an early build model.
    But to answer your question: Yes, after market or the upgreaded OEM guides are needed and obviously NOT the same ones that were part of the original build.
    Not only that, but aftermarket are less expensive, by far, and better: even having them custom made would be less expensive and better IMO.
    Will wait for Taz to give the specs.
    r
  3. philfrench
    philfrench Karting
    Jan 3, 2012
    104
    France
    Hello i m a south french owner since 3 years of a 456 M .
    I bought it at 50 mkm ,after 3000 km i had to change all the valve guides with the new factory one .48 sintered steel factory guides :1720 euros july 2011 Ferrari Gauduel plus hoses gaskets aso about 11000euros for a perfect work with machining the two heads.
    Ferrari Pozzi told me that it was frequent even with the 456 M but they are numberless producted.He recomanded the new valve seals and to do the first 1500 km slowly to let oil do the work.
    Now i have done 67mkm sometimes very fast (in germany!) and i did the two gas 'bombs'from Oscaro ( BMW parts) and ...flatbed because bad alternator at 65mkm Change it before ...My advice!
    Thats said it s a very fast highway car with good sound (Novalary muflers) and beautiful shape...but you have to look after everything (next new motor mounts and change your fuel filters to check rubber disolving case ( use 98 octane only without ethanol )They are ok from now.
    Enjoy and if you want to contact PM me i ll be happy to speak french better than my poor english!...
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,666
    South East
    Jimmie
    There's a very similar thread a few weeks ago from a UK owner which will give some ideas maybe - scroll down & it should appear
  5. tazandjan
    39,170
    #5 tazandjan, Aug 26, 2013
  6. henri66
    henri66 Karting
    Oct 10, 2006
    109
    I have to double check for the S/N but as I wrote earlier from Dec 98
    Where can I find after market ones?
    I have found nicksforzaferrari in the US. No one in Europe yet. Any leash?
  7. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Bonjour Philippe :)
    Do you have the part number for the guides they have fitted?
    When you say machining you mean drilling the old guides off but also flattening the head joint face?
    Thanks for the tip!!!
    What is the gas bomb? (Even in French)?
    New motor mount??? Why??? Is the rubber getting too stiff or starting to fail? I have access now as the exhaust collector are out. Maybe worth thinking about it right now.
    >Enjoy and if you want to contact PM me i ll be happy to speak french better than my poor english!...[
    Your English is perfect. I will French PM you.
  8. henri66
    henri66 Karting
    Oct 10, 2006
    109
  9. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Hi terry,
    I have that document. I was just wondering about steel OEM or after market ones.
    Your opinion?
  10. greyboxer
    Dec 8, 2004
    12,666
    South East
    Jimmie
  11. future328driver
    future328driver Formula 3
    Dec 10, 2001
    1,838
    Dallas, Texas
    Ken Thomas
    I am looking at a 456M to purchase that needs to have the valve guides done. According to the indepdent Ferrari mechanic I consulted with, there are no aftermarket sintered steel valve guides for the 456 (unlike several aftermarket options on the 355). So, OEM sintered steel guides are the only option.
    If anyone knows of an aftermarket supplier, I would like the contact info.
  12. tazandjan
    39,170
    Aftermarket bronze guides will work fine and last a long, long time. The ones used in late model Ferraris like the F355, 456, 456M, and 550 had a very high copper content in some batches, so wore quickly. CHE Precision is the only aftermarket maker I have on my list, but there must be others out there.
    The recommended sintered steel replacement guides from Ferrari are the same as the 575M and 612 guides, and I do not know any manufacturer of SS guides.
    You guys need to ask a pro or a machine shop who they recommend, and there are not that many here.
    Try these guys and see what they recommend. The bottom one is an FChatter and the top one is the machine shop Brian Crall uses.
    Lesco Automotive Machine
    3000 McMillan Ave.
    San Luis Obispo, CA 93401
    (805) 596-0400
    Fax (805) 596-0205
    Lesco Custom Performance & Race Engines
    E-Mail: [email protected]
    Machine Shop, Race Engines
    S&R Exotic Motorworks
    853 State Road 101 South
    Liberty, Indiana 47353
    765.458.5900
    765.277.2848 cell
    http://www.srexotics.com/
    [email protected]
    Engine Rebuilding, Machine Shop
  13. Cribbj
    Cribbj Formula 3
    #13 Cribbj, Aug 26, 2013
    Here's a page from Superformance UK's website, but suggest you check & double check with them that they'll fit the 456, and get some return assurance in case they don't:
  14. 2000 456M
    2000 456M F1 World Champ
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    When my engine was done, I had the aftermarket bronze guides. They were the way to go along with the 48 custom ground and fitted Manley valves. You can get details from Craig Nelson (his F-chat handle is Monza 456, even though he now has a 430 Scuderia Spyder), owner of The Jag Shop in Portland.
  15. tazandjan
    39,170
    John- Those are the OEM Ferrari sintered steel guides and will fit everything from the 456 through the 612. Still way more expensive than good bronze valve guides.
  16. Cribbj
    Cribbj Formula 3
    Taz, yes they appear to be the new style OEM guides. I say appear only because one of Superformance's strengths is offering reverse engineered parts.
    Hence these guides would need to be checked & double checked against the worn guides when they're removed.
  17. philfrench
    philfrench Karting
    Jan 3, 2012
    104
    France
    En peu de temps si tu veux je te tel et te done une mine de renseignements numeros de pieces double d une facture Pozzi avec toutes les ref plus trois ans de compilations sur Fchat ....et surtout mes avatars
    Je suis dispo a l heure qui t arrange pour te dire tout cela
    A bientot
    Philippe
  18. bay
    bay Formula 3
    Mar 13, 2011
    1,274
    Belgium
    Bernard
    Bonjour Philippe , curieux également de connaitre tous les éléments de cette opération !
  19. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Hi terry,
    i sent anote to CHE Precision requesting a quote. Thanks.
  20. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Prices looks crazy when you have to order 48.....
  21. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Thanks for the tip. I have questions 2 shops already. I keep yours in my back pocket.
  22. future328driver
    Dec 10, 2001
    1,838
    Dallas, Texas
    Ken Thomas
    Does driving with worn valve guides create any major damage to the engine? I am looking at a 456M with good compression on 11 of 12 cylinders (218 to 238), but one cylinder is low (about 185). Exhaust valve leakage on the low cylinder is about 44%. The well-respected mechanic who did the PPI said the car can be driven several thousand miles without much issue other than probably some increasing smoke.
    The offer price on the car is reasonable and I would have money left over to do a valve job within the next 6 months or so.
    I could have the work done over the winter, but would like to enjoy the car until winter comes.
    Thanks for any advice/guidance.
  23. 2000 456M
    Sep 29, 2007
    12,600
    Portland, OR
    Allan
    I'll let the expert wrenches give specifics, but when the valves and/or guides go bad, the car will start throwing codes and telling you to stop immediately and not drive further. I'm pretty sure there will be consequences.
  24. henri66
    henri66 Karting
    Oct 10, 2006
    109
    We drove ours for 2 years with 2 cylinders with 15% leak and no mechanical issue. No dashboard warning, a lot of fume, 1+ liter of oil for 1000kms.
    But the engine was really running perfectly.
  25. philfrench
    philfrench Karting
    Jan 3, 2012
    104
    France
    I think that exessive burnt oil in the catalysor make abnormal wear at last.
    In fact the bad guidance of worn valve guide create a little wearing of the valve seats :excessive play of the valve guide create vibrations at high rev.
    At last it makes valve seals pop up .....and smoke like a steam train. ....
    My experience..
    Regards Phil
