458 20" wheels on a 612 | FerrariChat
Discussion in '612/599' started by RegW, Jun 24, 2018.
  1. RegW
    RegW Karting
    Aug 8, 2017
    62
    London
  2. 360Marnix
    360Marnix Formula Junior
    Jan 4, 2017
    490
    Holland
    Love it
    Verstuurd vanaf mijn G3121 met Tapatalk
  3. tazandjan
    38,051
    Most of the late 114.3 mm x 5 bolt pattern wheels are pretty much interchangeable with similar or compatible offsets unless they are too wide. Gives owners a wide choice of what they would like to fit.
    Ferrari OEM Wheel Sizes
    5 X 114.3 mm Bolt Pattern
    612
    Five Spoke F 18”, R 19”, 5 X 114.3 mm
    Front 8J X 18 ET 43.5 mm , R 10J X 19 ET 51.1 mm
    Five Spoke Modulars 19”, 5 X 114.3 mm
    Front 8J X 19 ET 43.5 mm, Rear 10J X 19 ET 51.1 mm
    Challenge Monolithic 20”, 5 X 114.3 mm
    Front 8J X 20 ET 43.5 mm, Rear 10J X 20 ET 51.1 mm
    599/HGTE/SA Aperta
    Five Spoke F 19”, R 20”, 5 X 114.3 mm
    Front 8J X 19 ET 43.5 mm, Rear 11J X 20 ET 63.8 mm
    Front 8J X 20 ET 43.5 mm, Rear 11J X 20 ET 63.8 mm
    HGTE/SA Aperta Five Spoke 20”, 5 X 114.3 mm
    Front 8.5J X 20 ET 40 mm, Rear 11J X 20 ET 63.8 mm
    599 GTO
    Five V/Ten Spoke 20”, 5 X 114.3 mm
    Front 9.5J x 20” ET 38.1 mm, Rear 11.5J x 20” ET 63.8 mm
    California/California T
    Pentagram Forged, 5 Spoke 19”, 5 X 114.3 mm.
    Front 8J X 19 ET 44 mm, Rear 10J X 19 ET 52.5 mm
    V Spoke Forged, 5 Spoke 20”, 5 X 114.3 mm
    Front 8J X 20 ET 44 mm, Rear 10J X 20 ET 52.5 mm
    458
    Five/Ten Spoke 20”, 5 X 114.3 mm
    Front 8.5J X 20 ET 46.5mm, Rear 10.5J X 20 ET 58.5 mm
    458 Speciale/Aperta
    Front 9J X 20 ET 44.7 mm, Rear 11J X 20 ET 48.4 mm
    FF
    Front 8.5J X 20 ET 46.5, Rear 10.5J X 20 ET 53.4 mm
    F12
    Front 9.5J X 20 ET 48.4 mm, Rear 11.5J X 20 ET 71.6 mm
    F12 TDF
    Front 10J X 20 ET 48.4 mm, Rear 11.5J X 20 ET 57.3 mm
    488
    Front 9J X 20 ET 44.7, Rear 11J X 20 ET 38.5 mm
    GTC4 Lusso
    Front 8.5J X 20 ET 46.5 mm, Rear 10.5J X 20 ET 43.6 mm
    812 Superfast
    Front 10J X 20 ET TBD, Rear 11.5J X 20 ET TBD
    Portofino
  4. Exoticar Auto
    Exoticar Auto F1 Rookie
    2,990
    Tampa Bay FL.
    Exoticar Auto
  5. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    195
    Madrid, Spain
    F3RN
    Taz, you re an infinite source of F knowledge!
  6. tazandjan
    38,051
    Chris (Exoticar) helped me put that list together.
    florisevers likes this.
  7. florisevers
    florisevers Rookie
    Nov 19, 2021
    9
    Hong Kong
    Floris Evers
    Hi!
    Fresh 612 owner here (just put down a deposit).
    Are these 458 wheels a direct replacement for the 612?
    They look amazing
    Thanks,
    Floris
  8. florisevers
    florisevers Rookie
    Nov 19, 2021
    9
    Hong Kong
    Floris Evers
    Great overview Terry.
    So if I understand correctly, I can fit Portofino wheels to a 612? Offsets are very similar.
    thanks, Floris
  9. 360Marnix
    Jan 4, 2017
    490
    Holland
    I had them on my 612. It looks great! Image Unavailable, Please Login
    Verstuurd vanaf mijn J9210 met Tapatalk
  10. Stackhouse
    Stackhouse F1 Rookie
    Feb 14, 2004
    4,714
    IN YOUR TRUNK
    CT.. AKA Pimp Daddy
    What about Roma wheels on a 612? Would be curious to see that combo.
  11. tazandjan
    38,051
    Floris- Affirmative, should be fine.
  12. florisevers
    florisevers Rookie
    Nov 19, 2021
    9
    Hong Kong
    Floris Evers
    Yes, that indeed looks very nice!
  13. florisevers
    florisevers Rookie
    Nov 19, 2021
    9
    Hong Kong
    Floris Evers
  14. 360Marnix
    Jan 4, 2017
    490
    Holland
    Not an 612 option, but Ik am pretty sure the wheels are OEM Ferrari
  15. florisevers
    florisevers Rookie
    Nov 19, 2021
    9
    Hong Kong
    Floris Evers
    Thanks. I just found them for sale on EBay Germany and noticed they are 19”. They look like 20” if you ask me.
    Would you happen to know if the double 5 spokes wheels from the 812 would fit on the 612? The offset is quite different and the wheels can have max 295 tires at the rears (which is possible on a 11.5J wheel), but I’m wondering if the offset will cause an issue.
  16. tazandjan
    38,051
    Rears would probably be fine since the 599 11" rear wheels work and so do 12-12.5" NF2s, and you can fit larger than 295/35 tires back there, but the fronts are a full 2" wider. A fit check would likely be the only way to tell if you get rubbing at full lock, especially since you will need wider front tires to match.
    812 Superfast/812 GTS
  17. JLF
    JLF Formula 3
    1,646
    I think those are Novitec aftermarket wheels.
  18. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Newport Coast, California
    Ron H
    #18 RonH, Nov 22, 2021
  19. tazandjan
    38,051
    JLF- Affirmative, they are Novitec NF2s. Had a set on my 575M. Pretty, but very heavy, especially the 12-12.5" rears.
    JLF likes this.
  20. Azzurhyp
    Azzurhyp Karting
    59
    I tried to fit F12 wheels on my 612 - the front wheel looked absolutely gorgeous. But the back wheel would not fit as it was too wide by what seemed like 1 inch. I could have used spacers, but the rear wheel would have stood out from the side of the car. It's a real shame as the F12 5 spoke wheel seems to have been designed for the 612, but that 11.5" width binds on the inside body panel forward of the lower suspension mount.
    I have seen pictures of the FF wheels on the 612 - that may be my next attempt. What @florisevers posted above are, in fact, Novitec wheels. http://www.novitecuk.com/prod-612.html
    Those 458 wheels look fantastic...may have to explore those, too.
  21. Exoticar Auto
    2,990
    Tampa Bay FL.
    Exoticar Auto
  22. Azzurhyp
    Azzurhyp Karting
    59
    @Exoticar Auto - are those 612 Novitec wheels still available? And are they about $10K a set?
  23. 180 Out
    180 Out Formula 3
    Jan 4, 2012
    1,210
    San Leandro, CA
    Bill Henley
    #24 180 Out, Feb 5, 2022
    I bought this ‘05 just last week, with 21” aftermarket rims. They seem to fit just fine, including the rears with 355/25 ZR 21 Pilot Sports. From the rear it looks kind of like those mini-tubbed Pro Street Camaros from the 80s. The fronts are 255/35.
