458/488 Brake Recall | Page 11 | FerrariChat
Discussion in '458 Italia/488/F8' started by Hopeful, Oct 30, 2021.
  1. rw99
    rw99 Karting
    Jan 1, 2019
    130
    SF Bay Area
    Rich
    Good point. Along these lines, I’m very curious to know what other vehicles use the same Bosch parts…
  2. Sargepug
    Sargepug Formula Junior
    Mar 23, 2020
    888
    NYC
    IMO, our cars are too "young" especially the 488s, to have seal issues. Hence you point of asking a 328 guy, that's easily of age for seal issues....
  3. Sargepug
    Mar 23, 2020
    888
    NYC
    Let's not forget our deal old friend "COVID", throwing the wrench in timing....
  4. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,854
    Dallas Texas
    If you know you know
    FWIW, and the official notification will go out next week:
    " The repair consists of replacing the brake fluid reservoir cap and updating the software in your vehicle to provide for a different warning message if your vehicle should lose sufficient brake fluid. The replacement part is not yet available; we will contact you again when the replacement part is in dealer stock. The time needed for the repair and software update is estimated to be approximately 2 hours. "
    S
    Sargepug, 3POINT8, rw99 and 2 others like this.
  5. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,155
    Todd
    how anti-climatic
    this recall is a total dud
  6. SVCalifornia
    SVCalifornia F1 Rookie
    2,583
    Silicon Valley
    Keith
    Sounds like the analysis is, a tighter cap to prevent loss of fluid and a more informative error message to warn you if we happen to see an issue…. Nothing really wrong here!
    Think that’s gonna fly??
    SV
  7. Mrpseudonym
    Mrpseudonym Formula Junior
    619
    Sydney, Australia
    And 2 hours to do that?
  8. todd cloud
    Jun 21, 2019
    1,155
    Todd
    Sounds like they are fixing the canary, not the coal mine
    elt360 and rw99 like this.
  9. ilko
    ilko Karting
    Aug 20, 2008
    155
    Interesting... If the above is true then Ferrari is claiming brake fluid leaks through the cap. Which certainly hasn't been the case for those of us who have been affected by this failure. The whole problem for us has been that we experienced an internal leak. You can quite easily confirm whether the cap leaks or not.
    The other issue is whether the software update only involves the brake system warning or whether it's a more comprehensive update. As a MY2010 owner I wouldn't want to lose the awesome exhaust sound, pops, and burbles that other MY2010-11 owners have experienced with a factory ECU update...
  10. todd cloud
    Jun 21, 2019
    1,155
    Todd
    right now the software lights up the dash with a low brake fluid warning when 52% of the fluid is gone
    presumably, with the software update the dash light will come on much, much sooner?
    an improved canary, no doubt, but the internal leak (the coal mine) has not been solved?
    the cap thing is silly
    elt360 and Viperjoe like this.
  11. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    I also have the same concern with my 2010 458. If all the upgrade does is change a warning light, then I will forgo doing the recall until I sell my car many years in the future as the risk of an ECU upgrade and losing my exhaust sound is too much, but I’ll get the upgraded cap.
  12. italiafan
    italiafan F1 World Champ
    16,121
    Stickbones Swagglesmith
    I thought the complaint was that the brake pedal went hard as a rock and couldn’t be depressed? Wouldn’t a lack of fluid cause a soft pedal going to the floor?
    DougF likes this.
  13. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,590
    Austin TX
    Unless the booster failed, then you have no ability to push and have an impact(or a very slight one). If the pedal is soft, the booster is working and your brake fluid is boiled or low...
    hgoodwiniii likes this.
  14. italiafan
    16,121
    That’s what I thought the complaint was...hard pedal, failed booster. Low fluid doesn’t sound like the culprit.
  15. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,590
    Austin TX
    But, why did the booster fail? I think the issue is brake fluid leaks through the master cylinder and erodes the seal at the booster and renders it flaccid and unable to provide boost. Or maybe it leaks through the lid (via cracks/poor seal?) on the brake fluid reservoir, down the sides and leading into the booster...just speculation, but a new lid is apparently being recommended...
  16. italiafan
    16,121
    Exactly, so how would a filler cap remotely address the issue?
  17. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,854
    Dallas Texas
    Maybe I missed it, but where did anyone officially investigating this recall state that it was an internal failure?
    Steve
  18. italiafan
    16,121
    Nobody official that I am aware of. I just thought the complaint was a brick hard pedal and thus no braking.
    elt360 likes this.
  19. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,626
    Tampa FL
    Go do some searching on rennlist the Porsche forum in the 997 and 991 GT3 forums search Ice Mode. Porsche brakes had an issue mostly at the track that we called Ice Mode under hard braking. I haven’t been on Rennlist much in a couple years and I never experienced Ice Mode but I have friends at the track that did but it was a very rare occurrence. I do not remember the fix but the later 991 GT3’s never complained about this issue.
  20. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,590
    Austin TX
    Sargepug and italiafan like this.
  21. JTSE30
    JTSE30 F1 Rookie
    Oct 1, 2004
    3,590
    Austin TX
    #271 JTSE30, Dec 24, 2021
    I thought ice mode was more related to lack of engine provided vacuum under high throttle applications (engine creates the vacuum used by the brake booster in nearly all cars with some other cars having a separately powered booster like the Buick Grand National), the 458 brake failures are not on track during WOT or close to it...anyway, some speculations here (not just a Porsche thing)
    http://www.the370z.com/brakes-suspension/136512-new-thoughts-ice-mode-possible-solution.html
    mdrums likes this.
  22. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    Maybe the new cap states "Fluid MUST be checked before each operation" thus alleviating them of liability?
    italiafan likes this.
  23. Viperjoe
    Viperjoe F1 Rookie
    Unless I missed something, it seems the F8 is not involved in this issue. Is that correct?
  24. italiafan
    16,121
    LOL
  25. ilko
    ilko Karting
    Aug 20, 2008
    155
    That's not how it works. Fluid doesn't just find its way in the booster.
