458/488 Brake Recall | Page 15 | FerrariChat
Discussion in '458 Italia/488/F8' started by Hopeful, Oct 30, 2021.
  1. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    Unfortunately, I don’t. Silicone spray is extremely difficult to remove and requires a strong solvent. Maybe brake cleaner solvents suitable for carbon ceramic rotors will work. Silicone bonds tightly on a molecular level, so ordinary detergents don’t work. Because ordinary brake use generates heat, it seems likely that silicone contamination could get baked in, making it even more difficult. The best thing is not to get any on the braking surfaces to begin with, though as you note, you may be stuck with whatever a prior owner did.
  2. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    :shrug: Brake clean?
  3. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,465
    Tampa FL
    Non chlorinated brake clear should work and not hurt the rotors.
  4. Solid State
    Solid State F1 World Champ
    10,595
    Maximus Decimus Meridius
    That stuff in the green can does not clean well and leaves wet residue. This stuff cleans everything and evaporates quickly and completely. I buy 2 or 3 cans at a time. Sometimes on new steel rotors I'll use the house brand brake cleaner and then finish up with the good stuff. Will not hurt plastic either. I should stop posting this because its getting harder to find.
    https://shop.advanceautoparts.com/wcsstore/CVWEB/staticproductimage/N3225/large/7070074_crc_05103_pri_larg.jpg
  5. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    The link doesn’t go to a particular product. Is it this one?
  6. Solid State
    10,595
    of2worlds and Need4Spd like this.
  7. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,465
    Tampa FL
    I use non-chlorinated brake cleaner on gun that need a good scrubbing. It doesn’t hurt plastic of any other finish on the guns. I’ve never had a slimy residue left behind. I used it all the time to clean up my Porsche brakes after a track weekend while I’m washing the car. Again no residue left behind.
  8. Solid State
    10,595
    The good stuff many years ago was 1,1,1-Trichloroethane. Was used as an industrial solvent. Excellent when heated and under pressure to remove flux from PC boards during manufacturing. Now banned.
    The cheap stuff at the car parts places stayed wet and needed scrubbing. They started selling the non-chlorinated brake cleaner in a green label as well. I tried a couple cans of it and found that it did not completely evaporate either. You had to wipe it down or blow it off to fully dry it.
    When selecting chemicals of this type spray a bit into the cap and see how fast and complete it evaporates. I do this with silicone spray as well since they keep changing the formulations.
    mdrums likes this.
  9. elt360
    elt360 Karting
    Mar 27, 2013
    132
    uk
    paul elton
    Could we please keep this topic for the subject of brake failure recall.
    Could a mod move the cleaning of brake rotors to a separate thread. Thanks.
  10. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,465
    Tampa FL
    Welcome to the words of Internet forums…. it happens on all of them.
    docf, MANDALAY and Viperjoe like this.
  11. ZitroRasec
    ZitroRasec Rookie
    Sep 19, 2021
    15
    So Cal
    Cesar Ortiz
    Has anyone had Ferrari complete the recall on the car? Any insight you can share? Thanks!
  12. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,833
    Dallas Texas
    If you know you know
    The repair / solution has not been released yet.
    S
    020147 likes this.
  13. ZitroRasec
    ZitroRasec Rookie
    Sep 19, 2021
    15
    So Cal
    Cesar Ortiz
    Thank you!
  14. BigJay2050
    BigJay2050 F1 Veteran
    7,191
    I just picked up a 488; I wonder of Ferrari will send me a copy of the letter if the previous owner already received one. Anyone know how that works?
  15. BigJay2050
    7,191
    I thought the repair/solution was released, it was just a parts availability issue still at this point?
    Sargepug likes this.
  16. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    640
    Austin, TX
    I think they figured out what's needed but it will take time (especially in the current supply chain situation) to get enough new parts made and distributed.
    Somebody suggested drilling a hole in the existing cap for now, but I think that would allow the fluid to absorb moisture from the air so I'm not excited about that idea.
    SAFE4NOW likes this.
  17. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,906
    France
    My suggestion to you is to register your car on the Ferrari website ("MyFerrari") - It'll take a few days to have it verified and approved, but once done the site will show the details of your car including pending recalls.
    Need4Spd and Rexcat458 like this.
  18. BigJay2050
    7,191
    Already done and registered! I'll see if the recall shows there, thank you!
  19. pilotguy7
    pilotguy7 Rookie
    Mar 12, 2020
    5
    Alberta
    Rick
    Does anyone know if the flash that is part of the recall fix will affect a custom ecu tune for aftermarket exhaust?
    Sent from my SM-G960W using Tapatalk
  20. Giallo27
    Giallo27 Formula Junior
    Sep 21, 2020
    264
    JB
    Drilling a hole on the cap? What for? You’ll ruin the fluid within hours!
    Viperjoe likes this.
  21. r6elmo
    r6elmo Karting
    Sep 12, 2010
    104
    You would need to ask your tuner to be sure - There are many ECU modules that can be flashed - I don't think the flash they are doing for the brake recall relates to any type of engine based flash tuning, but I can't say for sure.
  22. beachedferrari
    beachedferrari Karting
    65
    Maryland
    Mike Ferrari
    My car is currently at the dealer for the braking issues which they think are related to the recall. We shall see.
    elt360 likes this.
  23. Solid State
    10,595
    I don't think asking a tuner is a sure thing. They aren't going to get any better answer than anyone else asking them especially if they start out saying they re-flash Ferrari ECUs for profit.
  24. Garbageman
    Garbageman Karting
    96
    Long Island
    Jimmy
    I just got my first Ferrari ! 2019 488S Bought it from a dealer. They said nothing about a recall on it. I'm curious if it's gonna show up when I register on the website ? I'm gonna do that today
    italiafan and Sargepug like this.
  25. italiafan
    italiafan F1 World Champ
    16,121
    Stickbones Swagglesmith
    Congrats! Post up some pix.
