458/488 Brake Recall | Page 17 | FerrariChat
Discussion in '458 Italia/488/F8' started by Hopeful, Oct 30, 2021.
  1. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,921
    France
    Just looked at MyFerrari website - the recall campaign is initiated in France with starting date of March 8th (I did not get mail notification yet).
  2. elt360
    elt360 Karting
    Mar 27, 2013
    132
    uk
    paul elton
    It was announced world wide on that date.
  3. 020147
    020147 F1 Rookie
    4,610
    Midwest
    A big thank you for this post @SAFE4NOW! My 488 brake recall was performed today by my dealer.
    SAFE4NOW and Need4Spd like this.
  4. Scout123
    Scout123 Formula Junior
    Nov 1, 2017
    575
    I received my letter in the mail yesterday stating that the replacement parts are at the dealerships now and I can make my appointment.
  5. 430jm
    430jm Formula Junior
    Jun 11, 2017
    449
    Atlanta
    Many on here were condemning Ferrari and accusing them of doing nothing…
  6. Bad Boys 1
    Bad Boys 1 Karting
    Mar 22, 2020
    90
    Michael M
    I think its nonsense..
    maybe, if you never had an issue this may prevent something further down the road , but if your car
    has a hard peddle now ...I seriously doubt this will be the fix.
    If fluid has already leaked into the booster this will not cure the problem.
    only replacement of booster and seals accompanied by cap replacement
    MANDALAY and Island Guy like this.
  7. up4speed
    up4speed F1 Rookie
    3,695
    Long Island, NY
    Chris
    I don't think that the recall is intended to fix any car that already had a problem. I think it is designed to prevent a future incident.
    The funny part is that I'm convinced that Ferrari is not sure that it is a 100% solution to the problem. If they were, there would be no need to change the software to give a much more panicked message in the event of low brake fluid.
    SD455TA and elt360 like this.
  8. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,651
    AUSTRALIA
    ANGELO
    So its all about the cap ?
  9. elt360
    elt360 Karting
    Mar 27, 2013
    132
    uk
    paul elton
    Ferrari I believe have come to the conclusion that the brake fluid reservoir was pressurising and that build up of pressure was enough to force fluid passed the master cylinder seals into the booster.
    So the replacement cap must have a pressure relieve valve in it to dissipate the build up of pressure.
    The replacement cap is only about £2 so I think I will buy another cap and cut it open to see what the pressure relief valve looks like.
    Need4Spd, mdrums and MANDALAY like this.
  10. Sargepug
    Sargepug Formula Junior
    Mar 23, 2020
    888
    NYC
    Mine is being picked up and going in for the recall on 3/22....
  11. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    Contacted my dealer over the weekend - They got back to me today and said parts were trickling in and I have an appointment on Tuesday to take it in - Have not checked mail but assume I will have a letter as well. Will report back on how it goes.
    Cheers :)
  12. MANDALAY
    May 23, 2013
    14,651
    AUSTRALIA
    ANGELO
    IMO Ferrari is talking BS.
    The brake master cylinder is designed with 2 pistons incase one would fail you will still have braking of 2 wheels. The cap has nothing to do with release pressure ? Well its news to me as other cars dont have pressure relief.
    If brake fluid is going into the brake booster the only way that happens if the seal is compromised. See the video
    IMO the cap is just a good excuse to get your car in the workshop so the tech can reset the value when the waring light comes on.
    It could be set at 50% right now. They will just go lower say 20% and a not so threatening warning will come on.
    The real problem is brake master cylinder in its ability to hold the brake fluid from squishing through. Changing both items on all the affected cars would cost MILIIONS. However the problem could be just a few vehicles.
    Ild bet that if a car with these so called upgrades has the level signal go of Ferrari will see if there is any brake fluid in the brake booster and if there is you know they will tell you it needs replacing.
    Interesting that cars still not covered by warrantee are paying for a fluid change as a part of the cap replacement.
    What I have written is my view. I have built several cars from ground up and never have i seen such a thing as this. IMO its a Placebo.
    Viperjoe likes this.
  13. MANDALAY
    May 23, 2013
    14,651
    AUSTRALIA
    ANGELO
    There is no way a cap change will fix a car that has this problem, Yeh Ferrari have done nothing. Just like their sticky parts.
    Viperjoe and Tony91505 like this.
  14. todd cloud
    todd cloud Formula 3
    Jun 21, 2019
    1,088
    Todd
    great video
    Il Tifoso and MANDALAY like this.
  15. MANDALAY
    May 23, 2013
    14,651
    AUSTRALIA
    ANGELO
    I believe you are following Ferrari's direction. How about cutting one of those caps and pointing to some sort of relief value for us ?
    I can not believe there is a value. What pressure ? In the plastic bottle ? Rubbish.
    The brake fluid on some cars that have a faulty seal is what I reckon is the cause, hence why the brake fluid in the brake booster.
    The real fix is changing the whole set up with a non faulty brake master cylinder and booster.
    OH BTW if the cap has a value can I assume Ferrari has no issue with Brake Fluid being squirted out ?
  16. 430jm
    Jun 11, 2017
    449
    Atlanta
    I’m confident here in the US they wouldn’t try garbage. And the dealer knows I’m a litigation attorney.
  17. MANDALAY
    May 23, 2013
    14,651
    AUSTRALIA
    ANGELO
    Curious have you bought any of the Ferraris with sticky parts ? Did you get them to replace all of them ?
    Im sure many attorney's have bought one of those. Somehow I have never seen a post that said Ferrari replaced all my sticky parts which in time will be sticky again.
    Ash Patel and 430jm like this.
  18. up4speed
    up4speed F1 Rookie
    3,695
    Long Island, NY
    Chris
    Is there another part# for that cap? I looked up 000810768, and nothing comes up.
  19. elt360
    elt360 Karting
    Mar 27, 2013
    132
    uk
    paul elton
    Drop the 3 zero's the part number is 810768.
  20. elt360
    elt360 Karting
    Mar 27, 2013
    132
    uk
    paul elton
    There seems to be some scepticism on here about the cap fix. Don't forget this is a Bosch fix as Ferrari buys the master cylinder from them.
    So where does this leave us.
    10000 or so cars are to receive the modified cap so it won't be long before the problem reoccurs on just one car if fitting the new cap did not solve the problem and hopefully if that happens we here about in the press and subsequently on places like this forum.
    TIME WILL TELL.
    MANDALAY likes this.
  21. 430jm
    Jun 11, 2017
    449
    Atlanta
    I agree with you on sticky parts. I just don’t think it’s the same as a warranty recall under federal law. They should’ve done something about the sticky parts along time ago, or at least make sure that they’re not happening on more current models.
    docf likes this.
  22. Sargepug
    Mar 23, 2020
    888
    NYC
    Don't forget about the software update in conjunction w/ the cap. Hopefully that gives a much earlier warning of failure? Who knows....
    elt360 likes this.
  23. Scout123
    Nov 1, 2017
    575
    I spoke to the service department in St. Louis today, and confirm they have the parts and software ready to go. He also said they just received the inserts they were supposed to stick into the owners manual. Not sure what’s on that. My guess, extra warning about being sensitive to brake fluid being low, and probably full explanation on how to use emergency parking brake is brakes fail.
    SAFE4NOW and MANDALAY like this.
  24. Shorn355
    Shorn355 F1 Veteran
    6,859
    Colorado
    Scott
    I will get my owners manual sticker on Tuesday and will post unless someone beats me to it :)
    SAFE4NOW likes this.
  25. bball16
    bball16 F1 Rookie
    4,134
    NY LI FtL
    Recall done today at my dealer. Dropped the car off at 9 and picked it up at 3. Done. Brakes feel great and no side issues.
    up4speed, Rexcat458 and Shorn355 like this.
