458/488 Brake Recall | Page 28 | FerrariChat
Discussion in '458 Italia/488/F8' started by Hopeful, Oct 30, 2021.
  1. watt
    watt Formula 3
    Jun 17, 2004
    2,191
    Northern Rocky Mountains
    Giuseppe T Hemingway
    Haha, Maybe and hopefully you're right but I've given you the downside case to hedge.
  2. watt
    watt Formula 3
    Jun 17, 2004
    2,191
    I have 3 500 mile road trips planned, then a 2000 mile one -- It's no fun worrying about brake failure. My first 250 miles are to a meeting i can't miss - thinking of going a day early in case I arrive on a flat bed.
    Alternatively I can take the RSQ8, but then what use is the Pista?
  3. Jarviper
    Jarviper Rookie
    Jul 18, 2021
    13
    Jeffrey Rose
    NHTSA received a complete pedal to the floor brake failure complaint on 9/5/22, from a 2017 Ferrari 488 owner who crashed at the Circuit of Americas on 9/4/22, who had the recall work completed and his brake reservoir was full of fluid and checked before the track event and after the track event according to the complaint.. Based on this NHTSA Complaint Number 1482908 I don't know if you should make the trip in your Ferrari or not. Have you had your recall completed by your dealership. I wonder if there have been other brake failures after the recall work was completed?
  4. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    #679 FerrariCognoscenti, Sep 8, 2022
    I’ve had that too as a result of brake fade and hard driving on track while using crappy OEM CCM rotors, OEM pads, and OEM brake fluid.
    This complaint doesn’t indicate anything other than someone was driving their Ferrari in extreme conditions without likely making any changes to increase necessary brake performance and they were inexperienced and couldn’t sense the brakes were fading until they disappeared.
    I mean honestly for all of us who track our cars who would ever file an NHTSA complaint!?!?! Sounds like someone just wants to get Ferrari NA to cover the likely six figure repair bill after insurance denied the claim for track use. This lacks a lot of legitimacy.
    The symptom of the Bosch brake cylinder failure is a hard pedal that won’t goto the floor. A pedal that goes straight to the floor means the driver cooked his brakes, boiled his brake fluid, and let it get so bad that he completely lost the brakes. This is driver error and not a fault of the car. If you feel your brakes fading on track then you slow and let them cool, and if bad enough you come into the pits and end your session early, then bleed your breaks in between sessions. This driver sounds very inexperienced.
    LVP488, Need4Spd and SD455TA like this.
  5. Hopeful
    Hopeful Karting
    May 31, 2019
    153
    Vero Beach, FL
    Tony M.
    My 488 has never been tracked and the pedal went straight to the floor driving 45 mph around town. The brake fluid has been changed annually by Ferrari and was only 3 or 4 months old when it happened. Ferrari reported it was a complete dump of brake fluid into the booster.
    I don't know whether or not the tracked car cooked his brakes but the pedal to the floor happens on non-tracked, well-maintained, non-abused cars as well.
    Coincid likes this.
  6. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,236
    Tampa FL
    Steve does “bricking” mean?
    As far as car mods, I only did Novitec springs and HRE wheels is stock 20” size. My dealer did the work but I’d think Ferrari would not cover a shock issue due to the springs which is understandable. I don’t believe the springs and wheels would effect anything else for car warranty do you?
    SAFE4NOW likes this.
  7. craze
    craze Formula 3
    1,157
    Melbourne
    Michael
    Bricking
    eg seized but electronically lol
  8. Viperjoe
    Viperjoe F1 Rookie
    Interesting question. Opinions welcome.
  9. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,804
    Dallas Texas
    If you know you know
    Bricking = turning the car into an immovable object, electronically. Aftermarket software or wired in components could / have caused problems with the download, corrupting the file. Cars with aftermarket items have had problems and to the best of my knowledge cars that are still stock have not had problems.
    Springs and wheels, could they affect a vehicles warranty? Lowering springs change vehicles suspension Dynamics, obviously that’s why owners do it. At the same time the vehicles electronics are not calibrated for the change. Which when hitting a irregularity in the roadway, where an original vehicle or may not have an issue, the lowered vehicle would translate or transmit the irregularity more harshly, causing the airbag or airbags to deploy. The airbag crash sensor is calibrated to the OEM ride. Not a warrantable repair.
    Wheels , also yes, we had a client who installed a set of aftermarket wheels with what I would consider to be in aggressive Aerodynamic design. Said client came in complaining of a high-pitched harmonic sound while driving under specific parameters. Said client was less than respectful in his insistence that the brakes were the cause, so much so that he called Ferrari who then instructed us to replace the brake pads and rotors all the way around… which we did. After doing so, the noise persisted. It turned out that the wheels were creating the sound, when we swapped OEM wheels back on the car the noise immediately stopped, we put the aftermarket wheels back on and the noise restarted immediately. The dealership ended up paying for the brakes because we assumed that in the clients conversation with Ferrari he would’ve disclosed he had aftermarket wheels, he did not and when we told them about the ultimate solution, they washed their hands of it as warranty clearly states that aftermarket items void said warranty … oh and the owner, he refused to pay for the brakes even though he’s the one who initially insisted that they were the cause and had called Ferrari to complain that we wouldn’t replace them…
    ( we did not believe the brakes were the cause )
    So, do they void the warranty, not necessarily, but as my two examples above demonstrate , they could…under unique circumstances.
    The above examples are just my first hand experience YMMV.
    Steve
  10. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,236
    Tampa FL
    Thanks for this reply…. Much appreciated. Ive been thinking really hard about getting the car back to stock…remove the Novitec springs and sell the car.
  11. SD455TA
    SD455TA Formula Junior
    Please SELL IT already, get those springs out of there and DO IT. Adios.
  12. ilko
    ilko Karting
    Aug 20, 2008
    155
    "Pedal to the floor" is a different issue than a malfunctioning master cylinder. When my brakes failed the booster wasn't working. Pedal felt normal, but the car was barely stopping. That's due to the master cylinder failure and fluid leaking into the booster.
  13. dpwracing
    dpwracing Rookie
    Aug 28, 2022
    13
    Dan Wilson
    Ugh, worrisome thread.
    I just got a 488 which looks like had the recall service done (found the insert in my warranty booklet).
    On a cool morning last weekend I had to get some heat in the brakes to get them to work decently. Even after getting some heat into them they were kind of wooden. Wondering if a pad change would help.
  14. SD455TA
    How does hell no on the pad change work for you?, it should, that ain't gonna do it. Don't look for a problem that doesn't exist. I know about brake line failures and no pedal, this is not one of those, so you have nothing to worry about. I think that this problem was created by people who hadn't a clue about anything and/or misused their vehicles. My brakes on my 2015 Speciale Aperta are FLAWLESS!,
  15. Giallo27
    Giallo27 Formula Junior
    Sep 21, 2020
    264
    JB
    I guess that this statement is too daring. Problems are there, brakes are supposed to be utilized by everyone, not just those above average.
    CCM brakes are pure ice when cold, on the open road it is very difficult to heat them up; I’ve felt several times it’s wooden touch and is scary the least, if you are aware in advance you’ll keep pushing harder and harder until real grip shows up but I insist, what if my mother takes the pony for a ride? Shall Ferrari put a disclaimer sticker on the window?
    Enviado desde mi iPhone utilizando FerrariChat
  16. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,691
    France
    I'm not subtle enough to experience that - it could be that I'm completely insensitive, or that the issue has to do with improper bedding.
    Rexcat458 and SD455TA like this.
  17. michaelo
    michaelo Formula Junior
    382
    Tn.
    Michael O.
    Had the brake recall done today at the new dealership in Nashville, Tn.
    First of all, the dealership is impressive.
    The service manager, Colt, the technicians and sales people couldn’t have been cooler.
    Great experience.
  18. Mrpseudonym
    Mrpseudonym Formula Junior
    585
    Sydney, Australia
    What a perfect name for a Service Manager in Nashville!
    michaelo likes this.
  19. VelocityTexas
    VelocityTexas Formula Junior
    318
    North Texas
    Bryan
    Dropped off today at Boardwalk. I was told 2 to 2 1/2 hour job.
  20. Solid State
    Solid State F1 World Champ
    10,448
    Maximus Decimus Meridius
    Assuming the brakes are functioning normally just compare to any normal car. When I drive the F12 the brakes are stellar. No need to add all that heat to get them to bite.
  21. Coincid
    Coincid F1 Rookie
    Dec 9, 2014
    3,605
    Canada
    According to a National Highway Traffic Safety Administration recall filing, a total of 23,555 Ferrari models sold in the US, almost every car its sold since 2005, with a potentially faulty brake fluid reservoir cap that may not vent pressure adequately. This can lead to a vacuum in the reservoir, potentially causing brake fluid to leak. If the brake fluid reservoir runs dry, this can lead to total brake failure.
    Ferrari has been aware of this issue for many years. Claims by an individual who is unhinged and bereft of any sense of civility, that this is a non issue and caused by people who haven't got a clue or misused their cars is patently absurd.
    StealthFox, Tony91505 and mdrums like this.
  22. Coincid
    Coincid F1 Rookie
    Dec 9, 2014
    3,605
    Canada
    I am surprised the NHTSA did not consult with SD455 , who is clearly the world's foremost expert on anything Ferrari, before issuing the recall. According to the esteemed 455, if a Ferrari suffers total or partial brake failure, or rock hard wooden pedal, the fault resides with the moronic Ferrari owner or the inept service contractor. His car has been flawless therefore proving that Ferrari is blameless.
    dpwracing, Hopeful and Tony91505 like this.
  23. john.b
    john.b Rookie
    Sep 22, 2022
    14
    Miami, FL
    john bloom
    very interesting thank you for this !
  24. SD455TA
    Never pretended to be sir. Also, that sample size you cite is very very small in the scheme of things. A lot of room for improper conclusions.
  25. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,236
    Tampa FL
    Maybe I missed this…but is this brake recall for Ferrari’s in Europe, and other parts of the world too?
