458/488 Brake Recall | Page 31 | FerrariChat
Discussion in '458 Italia/488/F8' started by Hopeful, Oct 30, 2021.
  1. Snapshift
    Snapshift Formula Junior
    900
    Centralia IL
    Lyle D. Pahnke
    The software upgrade thrashed my instrument cluster. Dealer won’t admit any problems. Was messy. Do you have aftermarket video inputs? That is what they blamed my mission. Good luck.
  2. SD455TA
    SD455TA Formula Junior
    How long after you had the recall did your cluster go bad?
  3. hgoodwiniii
    hgoodwiniii Formula Junior
    279
    I was able to get my Green Wrench off by disconnecting the battery for a few minutes.
  4. Snapshift
    900
    Centralia IL
    Lyle D. Pahnke
    Immediately I guess it was at dealer for a few weeks then moved to an audio shop who noticed it wasn’t working.
  5. SD455TA
    OK, immediately. Why was it at the dealer for a few weeks then moved to an audio shop who noticed it wasn't working? Something stinks here. For the audio shop to notice it tells me 2 things, if the audio shop did notice the problem, the audio shop CAUSED the problem or something was caused at the dealer when it was there for 2 WEEKS (Why would you let your car stay there for 2 weeks?). With my recall, after I got my notice I took it in and their computer was down in Italy so I had to come back, no big deal. Came back a few weeks later and they performed the recall very quickly (recall was a joke anyway) and the car was perfect before and after the work was performed. No issues whatsoever. PS I am confused who the original poster of the complaint is. Saw someone named Jacksal and yourself.
    MANDALAY and docf like this.
  6. Jacksal
    Jacksal Rookie
    32
    My take with the recall was that I took the time and effort to bring in the car, but ended up with the green wrench and turn signal malfunction. Consequently, I have bring the car in for the second time.
    Turn signal malfunction seems like a mechanical breakdown coincidetally happened at that moment, but green wrench must be due to software update.
  7. SD455TA
    You didn't answer the question, "Why was your car at the dealership for 2 weeks?" Also, as you said a blown out cluster is a far cry from a green wrench and turn signal malfunction. But first, why was it there for 2 weeks. A lot can happen in 2 weeks, most of it NOT GOOD. And oh, that software update did not affect anything to trigger a green wrench But if it did, the tech would have seen that when he updated the software and corrected it which is simple to do.
    Challenge likes this.
  8. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,809
    Dallas Texas
    If you know you know
    Aftermarket software and/or hardware will absolutely cause a problem when performing the recall.
    Did you tell the Dealership that you had aftermarket bits on your Ferrari beforehand?
    Did you even know you had aftermarket items on your Ferrari?
    It's possible you didn't know, neither would they, doesn't make it their fault.
    In my personal experience over-seeing several hundred campaigns, the ones that go South are the ones where aftermarket items were not mentioned, overlooked, or otherwise installed on a Ferrari...
    Which in turn caused the cluster to " brick " during the software update.
    Green wrench, was the service due?
    S
    SD455TA, mdrums, 05F430F1 and 3 others like this.
  9. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,389
    AUSTRALIA
    ANGELO
    IMO im with you on this. Its stinks IMO because audio shop is in the sentence :(
    SD455TA and 05F430F1 like this.
  10. Snapshift
    900
    Centralia IL
    Lyle D. Pahnke
    The video upgrade had not been done yet when the brake recall stuff was done at the dealer. IF there had been any previous aftermarket stuff other than a stereo amp and pre amp, radar and laser installation done to the car, I was unaware of any additional aftermarket installations. The car was at the dealer for an inop HVAC plenum motor and controller, and brake recall and a new key attempt, but there was a 6 wk back log to get the parts. I am 90 miles away from the dealer, and I had an appointment at an audio shop for add on enhancements so I told the dealer to move the car to the audio shop in the interim while waiting for the parts from Italy. All parties agreed on the plan. The audio shop gets the car in pieces, no dash airbag lights on, glove box inop (missing ) and dash out. at that time he sent out the cluster for video input mods for front and rear camera and apple car play. Car went back to dealer after that for completion of the HVAC work and possibly the brake recall was done at that time. ( I don't know when for sure) Its a new dealer and a young workforce and I don't think they had ever seen a recall trash an instrument cluster.Dealer determined that glove box switch and airbag lights were all controlled through the cluster and they couldn't fix it and claimed nothing they did caused any of the apparent present problems. It got to be a messy situation with me in the middle and no one claiming any fault. We ultimately had a 3 way meeting and as gentlemen explained everything, had the cluster sent out for FAI for repairs and then sent back for a repeat video input setup as originally planned. We split 3 ways everyone's alleged overages and charges and it was worked out amicably with no one claiming fault. I don't know what in hell happened but I was without the car for 6 months but now it has been completed and I am able to drive it and enjoy it. It's all good with everyone now. Not a good situation to be in that's for sure. Sure don't want that type of ordeal ever again. I hope this clears up other's criticism of leaving it at the dealer etc etc. They weren't there and every situation is different.
    rw99 and SAFE4NOW like this.
  11. SAFE4NOW
    SAFE4NOW F1 Veteran
    Sponsor Owner
    Aug 25, 2004
    5,809
    Dallas Texas
    Thank you for your fair & balanced outline of events.
    IMO best possible outcome for all parties..
    Thank you for sharing,
    S
    Snapshift likes this.
  12. SD455TA
    OMG, let me say that again, OMG, you poor guy, thats just not right on so many fronts. Now your story put the Fear of God in me. Wish you well and many many happy miles ahead.
  13. Snapshift
    900
    Centralia IL
    Lyle D. Pahnke
    What are you going to do? they have the car and it was in pieces. It's all behind me now. Thanks for the well wishes. It has been a long 6 mos, but is all good now.
  14. SD455TA
    You deserve 10X the enjoyment any of us get in our rides. WTF....on the HVAC plenum and controller.....oh that just sounds so freaking bad. I see a picture I think of your car on your avatar?, you're a good owner. I do like Snapshift as a name also
  15. Mickeyblueeyes
    Feb 8, 2024
    41
    Is there any update on this?
    Has anyone who has had the new cap since the recall experienced issues with brake failure like those previously described on this and various other threads?
  16. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    632
    Austin, TX
    Most people never experienced brake failure before the fix so I wouldn't expect much news
    SAFE4NOW likes this.
  17. Gh21631
    Gh21631 F1 Veteran
    9,011
    East
    A friend of mine had a massive failure and almost died in a Challenge car and has suit filed. Similar issue, brakes went soft, pedal to the floor and he is lucky to be alive. Ferrari refuses to take resonsibility so the suit goes on. Problem for Ferrari is he is not the only one but they do a good job of keeping it under the radar.
    of2worlds likes this.
  18. Mickeyblueeyes
    Feb 8, 2024
    41
    Soft brakes and pedal to the floor sounds like a completely different issue to the complaints which were of hard pedal and brakes not working. Seems impossible to get consistent or reliable info about this potential issue!
  19. Gh21631
    Gh21631 F1 Veteran
    9,011
    East
    It is all related to some extent. For what its worth you don't have this issue with other exotics, certainly not with the race versions. There is flaw somewhere in the design, I couldn't tell you what though.
  20. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,259
    Tampa FL
    I forgot all about the brake recall. I had mine done at around 6k miles. I now have 9k miles and brake are always fine no issues.
    Mickeyblueeyes likes this.
  21. of2worlds
    of2worlds F1 World Champ
    17,625
    ON
    CH
    Here is one that was post #312 here, the pond story quoted above...
  22. Mickeyblueeyes
    Feb 8, 2024
    41
    That post was more than two years ago and prior to most cars having had the recall take place, so doesn't really answer my question.
  23. SD455TA
    It was obvious from the beginning to me that the whole thing was total BS brought about by a few that had a problem that they most likely brought on themselves. Challenge car for example......well what the hell do think that guy was doing to his brakes and is lucky he didn't die. Nobody really ever catelogued a failure other than complaining of one. I never saw any concrete evidence of one but there are always some apples in the bushel that create this stuff. But, I went throught the motions and had my cap replaced....total joke.
  24. f355spider
    f355spider F1 World Champ
    18,033
    LOL
  25. SD455TA
    sure didn't take you long to show your intellect. There has not been ONE posting of ANY brake problems after this debacle went away and it was a total farce. Why is that, no one has complained. In fact, they didn't complain even when this was in full tilt joke. Just a couple of dufuss'es that don't know how to use brakes, especially that guy in the Challenge car that should have known better.....the brakes in my Speciale are PERFECT...always have been and I suspect always will be. Adios.
