458/488 Brake Recall | Page 32 | FerrariChat
Discussion in '458 Italia/488/F8' started by Hopeful, Oct 30, 2021.
  1. up4speed
    up4speed F1 Rookie
    3,639
    Long Island, NY
    Chris
    I have a funny feeling that the light shut off because removing the battery cable reset the date and time. Did you set the clock after restoring power, and the wrench stayed off? If so, I wish I knew that. I spent $600 on my tool to clear that wrench!
  2. f355spider
    f355spider F1 World Champ
    18,033
    Intellect? Check your mirror.
  3. hgoodwiniii
    hgoodwiniii Formula Junior
    279
    I do not remember but my green wrench is on now. I'm waiting on some parts to make a repair so I will check once I have my car back on the road.
  4. Pantdino4
    Pantdino4 Karting
    Sep 17, 2015
    184
    Los Angeles
    Jim Oddie
    On May 26 I took delivery of my 2018 488GTB with 12K miles. The annual service had just been done the week before. On my first real drive in it the BRAKE warning light came on so I pulled into a parking lot. The brakes seemed fine but I wanted to be cautious. When I stopped in the lot the pedal went half way to the floor but I was able to pump it up with a few strokes. The next time it went to the floor with no resistance and there was a little hissing sound from the engine bay. The time after that there was still no resistance and a sound like an air bellows functioning was heard. Low Brake Fluid warning came on.
    Flatbedded car back to dealer and they are replacing the master cylinder and booster. If the seal between the master cyl and booster fails the brake fluid is sucked into the booster until there is no fluid in the cylinder reservoir or cylinder. Then you have zero brakes.
    You don't know what you are talking about
  5. SD455TA
    SD455TA Formula Junior
    While you may have suffered an anomaly, the fact remains that Ferrari did not do a recall to replace the master cylinder and booster and all it did was reset the software for the gauge and put a new cap on it. In fact, I have not heard one case where those parts were replaced. Perhaps your problem was separate from what was previously reported. I do not pretend to know what I am talking about, I simply observe and intuitively draw conclusions that are perhaps very accurate. GL with your problem. Things that are mechanical, as my mechanic would say, they can and do have problems.
    05F430F1 likes this.
  6. f355spider
    18,033
    Nice back pedal. The fact of the matter is the recall of the reservoir cap is to prevent failure of the master cylinder and booster. If they have already failed, then they will be replaced as part of the recall. The recall paperwork even states if a customer has had to replace theirs previously due to such a failure, Ferrari will reimburse for the work when provided the appropriate documentation.
  7. SD455TA
    Show proof that even one master/booster were replaced. If that were the case, people would be up in arms that "theirs" wasn't replaced. People as a rule have no idea about mechanical function. I am done with this topic.
  8. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
    I have learned over the years on here to always trust anything SD455 says. And he’s also correct on this topic.
  9. SD455TA
    Thank you, I have no ax to grind, only to say what I believe to be true. Can't lie as I would never want to remember them. You Sir, are very talented and I enjoy checking you out. Glad to have just checked in, have a great weekend.
  10. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Thank you buddy
  11. Hopeful
    Hopeful Karting
    May 31, 2019
    153
    Vero Beach, FL
    Tony M.
    10:28 08SEP21 16:36 24SEP21
    LINE OPCODE TECH TYPE HOURS LIST NET TOTAL
    A CUSTOMER STATES THE BRAKES DO NOT FUNCTION. LOW BRAKE FLUID LIGHT IS
    ON DASH
    CAUSE: E
    15FEZZ8 DEFAULT
    1458 WF (N/C)
    1 4900-1 SERVICE BRAKE FLUID D4 (N/C)
    1 244010 2EA BRAKE SERVO COMPL. WITH PUMP (N/C)
    FC: PART#: 4900-1 COUNT: 1
    CLAIM TYPE:
    AUTH CODE:
    PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE A: 0.00
    No fluid found in reservoir, scanned in and checked for codes, none
    found. Checked for leaks, no external leaks found, removed luggage
    compartment and checked booster, found fluid in booster. Removed and
    replaced booster/master servo assembly. Checked labor tree on labor op
    for booster and found bleeding not included. Performed brake bleed
    multiple times using DEIS to get all air out of system. Checked
    operation of brakes, noted that brake light was illuminated all the
    time. Removed brake switch and pulled plunger to perform length
    calibration due to booster replacement. Brake lights operated normally.
    Test drove vehicle and scanned out. No further issues noted at this
    time.
    B CUSTOMER REQUEST ROADSIDE ASSISTANCE - VEHICLE TOWED TO DEALER
    11FEZ008 DEFAULT
    999 WF (N/C)
    PARTS: 0.00 LABOR: 0.00 OTHER: 0.00 TOTAL LINE B: 0.00
  12. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,388
    AUSTRALIA
    ANGELO
    IMO you were one of the unlucky few that this happened to.
    Fact is that when Ferrari did the alarm settings it is obvious they didn't have the right trigger value to warn you that the fluid level is below the minimum amount that would not create issues.
    On the recall Ferrari has changed to reservoir cap and recalibrated the setting to a lower figure. This to prevent what you have experience. In other words an alarm and take to dealer but still have fully functioning breaks.
    Does this mean that there are issues with the master cylinder ? I dont know however Ferrari has addressed it with the resetting.
    You my friend has bought a second hand car. Were you aware of this issue? Did you check this recall was done ?
    IMO no you dont know or else you would have done the recall ? And not gone through this drama.
    BUYER BE WARE buying second hand cars.
  13. MANDALAY
    May 23, 2013
    14,388
    AUSTRALIA
    ANGELO
    I think Ferrari replaces them provided the owner is still alive and didnt die from the brake failure. Most likely because the booster is full of oil. One here one there I dont believe they will refrain from changing it. Every car , no way as it would cost MILLIONS.
  14. MANDALAY
    May 23, 2013
    14,388
    AUSTRALIA
    ANGELO
    As I said most likely your booster was full oil fluid. It was and replaced.
    Cars that just has the recall done they would have been check and if good , a cap change , a software update and your good to go. No need for a whole master brake and booster replaced.
    So tell me Hopeful , second hand car ? Probably is . If not did you do the recall ?
  15. MANDALAY
    May 23, 2013
    14,388
    AUSTRALIA
    ANGELO
    The real issue is that there could be a few master cylinders that are faulty , hey its a man made part. The low level was set up too low from Ferrari. Most likely a Bosch recommendation. Obviously the level was too low. A few brake failures and lets reset the level. Thats the fix
    The cap was just a salesman response.
    You ever cleaned out a booster full of brake Fluid ? I bet you haven't. Easier to replace the parts.
  16. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,977
    St. Louis, MO
    Eric
    Got a brief warning this evening and turned off. Brake fluid low. Tow to dealer.
    I drove home. No squishy pedal or anything weird.
    of2worlds likes this.
  17. MANDALAY
    May 23, 2013
    14,388
    AUSTRALIA
    ANGELO
    With the recall that's what Ferrari did. Change the cap, well i believe that was BS but more importantly increase the level at where the car would inform you, you have lost brake fluid.
    The setting that was originally on the car seemed to be too low creating issues like no brakes.
    Just filling the reservoir without looking deep into it would be a mistake.
    You need to find out if you have an issue. You post likely have a faulty actuator that is leaking and the fluid filling up in the booster :(
    Get them to check.
    Your car would be out of Warrantee however if you need replacements I would argue the point given that Ferrari cited an issue of great concern and had a recall.
    IMO there are a couple of faulty items , thats life . However to replace all of them it would have cost millions. Best approach change the cap ( BS ) and lower the level at which you would get a warning. That way so as to avoid any crash because of no brakes.
    Given that Ferrari had a recall on this it would be remiss of everyone not checking regularly. If the level is moving, you have an issue.
  18. f355spider
    18,033
    In the USA, it is a full on recall. Recalls do not expire. Any issue with the brake master cylinder/booster will be covered, both parts and labor.
    Eric C and MANDALAY like this.
  19. Mrpseudonym
    Mrpseudonym Formula Junior
    586
    Sydney, Australia
    What does this statement mean? Are cars being recalled again with a different solution?
  20. f355spider
    18,033
    No, they are currently replacing the reservoir cap and software, but the recall also states any master cylinder/booster failure related to this will be covered under the recall. And previously replaced master cylinder/boosters will be reimbursed as well with proper documentation.
    MANDALAY and Mrpseudonym like this.
  21. Mrpseudonym
    586
    Sydney, Australia
    Given this happened well over a year ago and is a mandatory safety recall, I would have thought all cars would now have had the new reservoir cap replaced as part of an annual service. Anything that is being done now to cars would surely be different?
  22. MANDALAY
    May 23, 2013
    14,388
    AUSTRALIA
    ANGELO
    Why would they be. The car if you know it isnt your standard car. Most likely never had the recall done.
    Ferrari knows there is an issue with some of them. But rather than replace all the units its a change by fail attitude.
    mdrums likes this.
  23. f355spider
    18,033
    Many owners do not use the dealer service network. Some owners may not be aware of the recall. Some, for whatever reason, may chose not to have the recall performed.
    mdrums and MANDALAY like this.
  24. mdrums
    mdrums F1 Rookie
    Jun 11, 2006
    3,259
    Tampa FL
    Most of the 488-F8 owners I see and speak with at a few car events never know about this recall. They are the 2-3-4-5-6-7th owner and get service done at an independent shop rather than our local Ferrari dealer and it never comes up. Ferrari for sure is not researching and tracking down owners. Ferrari really could careless about this.
    MANDALAY likes this.
  25. f355spider
    18,033
    I would disagree that Ferrari could care less. Though I have not used my local dealership service department in a few years, they specifically called and emailed me to remind me of the recall and requested I schedule an appointment for what they promised would be a relatively brief time. This was a couple years ago I believe, and it was a quick process...I was in and out in 30 or 40 minutes. But on the 430 Scuderia no software updates are required. Just the cap and a brief inspection.
