458 Bluetooth won't pair with phone | FerrariChat
Discussion in '458 Italia/488/F8' started by horsmanp, Nov 16, 2012.
  1. horsmanp
    horsmanp Formula Junior
    Mar 8, 2005
    306
    AZ
    Patrick Horsman
    #1 horsmanp, Nov 16, 2012
    Just got my 458 and can't get Bluetooth to pair. Go to phone menu and it says pair new phone but its in yellow and won't let u select it. I move the control nob down I rotate the control nob hold it depressed nothing will let me select it. Have tried in park and not in park.
    What is the trick here?
    The pic below is the screen I see. It will not let me select pair new phone.
  2. fastmover
    fastmover Formula Junior
    Mar 9, 2009
    530
    NA
    Does it persist if you turn the car off and then turn it on again?
  3. 2k7997tt
    2k7997tt Formula Junior
    Oct 23, 2007
    768
    Westlake Village, CA
    John M.
    Is it frozen?
    Ask dealer if it is safe to disconnect the battery and then reconnect? This may reset the computer.
  4. Entropy
    Entropy Formula 3
    Jul 10, 2008
    2,149
    #4 Entropy, Nov 17, 2012
    a few "usual" tricks (BTW - disconnecting battery will likely not help)
    Power down the Infotainment system (hold left-most button until it's powered off. Turn car off. Turn back on to Position 2 but do not START engine.
    Clear any/all old Bluetooth pairings in the car
    Clear all bluetooth pairings on the phone. (BTW - make sure all phone software updates are there if you can do that).
    Try again. Get the car into Pairing mode first, then make your phone discoverable.
    Helpful hints - make sure your phone is not accidentally paired a another car nearby; so far all of our cars have had the Bluetooth ID "Ferrari" (whereas BMW uses a specific ID to your car), so if you pair to multiple cars, can create issues. Also make sure nothing else is paired to the car even accidentally.
    I will be taking mine out shortly, I'll scroll through and double check. I do not believe there is a reset option on the menu. My car would not enable pairing while engine was running (safety?). Same with FF.
    hope this helps
    Ash Patel likes this.
  5. forgeahead
    forgeahead F1 Rookie
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    Good info. Try shutting off your phone and turning it back on.
  6. MM3.9GT3
    MM3.9GT3 Karting
    Some 2013 models have this issue. The dealer has to contact the factory and get a software fix.
  7. fastmover
    Mar 9, 2009
    530
    NA
    If it's not working yet take it back to the dealer and get them to do it for you.
  8. horsmanp
    Mar 8, 2005
    306
    AZ
    Patrick Horsman
    Called dealer they tried to walk me through it and then said something is wrong.
  9. javaruke
    javaruke Rookie
    Sep 14, 2012
    19
    Colorado
    I had the same problem with my recently delivered 458. I felt silly for not being able to get it to work.
    The solution was that the dealer had not "unlocked" the Bluetooth function - dealer prep issue. It is shipped in this mode to avoid issues/tampering while in transit.
    It took them about 15 minutes to get it corrected.
    Sent from my iPad using Tapatalk HD
  10. SCHUMS2000
    SCHUMS2000 Rookie
    Apr 25, 2017
    5
    Anybody found the solution? I have the same problem with the bluetooth in my 458. Impossible to use the pairing
  11. Ash Patel
    Ash Patel Formula Junior
    Dec 12, 2015
    538
    Stockholm, Sweden
    Not sure if this is any help but I recently had the same issue in one of my other cars, all off the sudden the car could not find my iphone and I could not pair it. Then after I upgraded the iphone iOS software (there was an upgrade pending on the phone) it all worked as before again.
    So if you have an iphone maybe try to upgrade to the latest iOS and then see if the car finds your phone?
  12. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,117
    Mel
    Or try a Samsung, just as test …
  13. Melvok
    Jul 25, 2008
    14,117
    Mel
    Any news ?
  14. SCHUMS2000
    SCHUMS2000 Rookie
    Apr 25, 2017
    5
    Still the issue...still in yellow. My dealer will check the car in mid july
  15. SCHUMS2000
    SCHUMS2000 Rookie
    Apr 25, 2017
    5
    Too bad horsmanp don t answer. He may have the solution...
  16. jumbolino
    jumbolino Rookie
    Sep 18, 2005
    3
    Dubai
    Hans Juergen Grosser
    NO IT DOES NOT HELP
  17. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,096
    Menlo Park, CA
    Paul Chua
    Jeez, no need to shout.
  18. kiryu
    kiryu Formula Junior
    Mar 28, 2016
    407
    Los Angeles
    The battery died on my 458 once, completely out of juice. I put a new battery in and I lost bluetooth function forever. Tried powering down, clearing out all old phones, upgrading software etc. and it doesnt help. Brought it down the dealer to have them look at it while doing the airbag recall. They charge me $800 for looking to it and they found there's no signal from bluetooth module in the radio, even though everything else works (navi, ipod, radio etc.). They say I need a 25k radio, or am probably better off getting some aftermarket stuff done. They referred me to a radio guy who can take the radio out and patch in some bluetooth functions etc. but I never got to it coz of the hassle
  19. daflk
    daflk Formula Junior
    Jan 27, 2013
    257
    Hong Kong
    Same, anyone find how to fix the Bluetooth module without repacking the whole unit?
  20. Rohin07
    Rohin07 Rookie
    Mar 9, 2018
    2
    Kolkata, India
    Rohin Raj Sureka
    Hi Guys
    Have been facing this same exact issue with my 2012 458 Spider lately.
    Incase anyone has managed to solve it. Would request to please share.
  21. kiryu
    Mar 28, 2016
    407
    Los Angeles
    need to rebuild radio. have to take the unit out and ship it to a decker radio guy for rebuild. Came back working like new. About $900 excluding shipping etc.
