458 - 458 Italia - Check Engine P0412 | FerrariChat
458 458 Italia - Check Engine P0412
Discussion in '458 Italia/488/F8' started by F485, Jun 11, 2024 at 7:12 AM.
  1. F485
    F485 Karting
    Oct 23, 2017
    168
    Abu Dhabi, UAE
    Fahad F458
  2. F485
    F485 Karting
    Oct 23, 2017
    168
    Abu Dhabi, UAE
    Fahad F458
    Don't know if this is the right subreddit for this question but hoping someone has ran into this issue in the past. I have a 458 Italia that keeps throwing a check engine light for P0412 - Secondary Air Switching Valve "A" Circuit.
    I am able to activate the air pump and it turns on and blows, no broken lines or anything like that. I tried to activate the switching valve but it gets no response to activate. Checked voltage and that is ok, replaced the valve and still having the same issue.
    Car on cold start will not start the air pump like it should. possible bad air pump? i don't suspect a fuse or relay if I'm able to activate it with a scan tool. So i'm going back and forth if it's the pump or ECU from bank 2.
    Hopefully someone has had this issue before and was able to fix it or has a repair from the dealership that showed the correction. Thanks in advance!
    the above is similar what asking for, any had same issue code earlier?
