458 OBD error code question | FerrariChat
Discussion in 'Technical Q&A' started by Drson, Apr 28, 2019.
  1. Drson
    Drson Karting
    Mar 18, 2018
    126
    Southeast
    John Galt
    Does anyone know what OBD error code P1303 for a 458 means?
  2. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,387
    The Cold North
    Tom
    Misfire cylinder cylinder 3
  3. gobble
    gobble Formula 3
    Owner Regional Sponsor
    Jan 29, 2010
    1,647
    Milwaukee, WI
    Ferrarifobs.com
    How does P1303 differ from P0303?
  4. tbakowsky
    Sep 18, 2002
    19,387
    The Cold North
    Tom
    Just depends how the scan tool and protocol interprets the fault..they are the same fault.
  5. gobble
    gobble Formula 3
    Jan 29, 2010
    1,647
    Milwaukee, WI
    Ferrarifobs.com
  6. Drson
    Drson Karting
    Mar 18, 2018
    126
    Southeast
    John Galt
    Thanks for the information...
  7. Frank white
    Frank white Rookie
    Dec 11, 2019
    3
    Frank leatardo white
    Hey did you get anywhere with the P1303 code on your vehicle, the same code just came up on my 19 488. Any input would be appreciated.
  8. gobble
    gobble Formula 3
    Jan 29, 2010
    1,647
    Milwaukee, WI
    Ferrarifobs.com
    Mine ended up being a fouled spark plug likely from old gas. I switched plugs between cylinders 3 and 4 and the misfire moved. I replaced all the plugs and haven’t had a problem since.
  9. Kainedogg
    Kainedogg Rookie
    Jan 5, 2008
    36
    ALDIE, VA
    How difficult were the plugs to replace?
  10. gobble
    gobble Formula 3
    Jan 29, 2010
    1,647
    Milwaukee, WI
    Ferrarifobs.com
    The 4 towards the rear were easy. The front 4 were very difficult.
  11. ilko
    ilko Karting
    Aug 20, 2008
    152
    P1303 came up on my 458 as well - I scanned it with a Bosch OBD2 reader.
    First I swapped coil packs and then spark plugs between cylinders 3 & 4, the code always comes back as P1303. There could be a vacuum leak, or a stuck fuel injector, or even a knock sensor faulty, but I'd like to know if P1303 is indeed a misfire in cylinder 3 or perhaps an altogether different fault? I don't have access to a Ferrari scan tool, so I'm relying on my off-the shelf Bosch reader that's why I'm not positive of the meaning of the fault...
    Does anybody have a list of CEL fault codes for the 458?
    Thanks!
  12. gobble
    gobble Formula 3
    Jan 29, 2010
    1,647
    Milwaukee, WI
    Ferrarifobs.com
    Do you have access to a Launch tool? Where are you located?
  13. ilko
    ilko Karting
    Aug 20, 2008
    152
    Unfortunately not. I'm in San Diego.
