458 Speciale Exhaust Recommendations | Page 2 | FerrariChat
Discussion in '458 Italia/488/F8' started by obbob, Aug 1, 2018.
  1. F12KID
    F12KID F1 Rookie
    Nov 27, 2013
    2,578
    Yes, they will if you have sport cats and rear boxes already. NR are the only ones that make an inconel one. And since you already opted for the inconel rest box then you are good to go!
  2. Nel1
    Nel1 Karting
    Jul 11, 2012
    166
    Thanks for the insight. Your setup seems to be ideal.
    Looking forward to hearing it some more.
  3. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,573
    SoCal
    Edward
    Nel let me know if you’re in SoCal, bunch of us do a lot of runs and meet. Sounds much better in person!
    Sent from my 16M
  4. Fabspeed Motorsport
    Sponsor
    Feb 5, 2009
    3,059
    Fort Washington, PA
    John S
    Phil from Fabspeed.
    The headers will make a difference! If you have already done the box and don't want to go catless. The 200 Cell sport cats should have made a bigger difference but if they did not make enough of a difference you also might want to go back to stock mufflers and keep the valves open. I have looked into these mufflers and they are very free flowing with the valves open.
  5. Nel1
    Nel1 Karting
    Jul 11, 2012
    166
    Thx Eddie. I am in Houston, so quite a drive to SoCal, LOL.... but I will keep it in mind in case that I visit your area. In the meantime, I will settle with any videos that you share. Take care.
    plastique999 likes this.
  6. Golattus
    Golattus Karting
    227
    JN
    I’m running Larini 200 cell sport cats and OEM silencers with forza valve controller and sound is amazing.
    Speciale silencers are almost nothing compared to standard Italia.
  7. plastique999
    Nov 9, 2008
    8,573
    SoCal
    Edward
    I’ll try to get more vids up next weekend
    Sent from my 16M
  8. Nel1
    Nel1 Karting
    Jul 11, 2012
    166
    Would love to hear your Speciale some more, particularly the sound inside the cabin at low and high ROMs / accelerations. Your car sounds sooooooo good!
    Hopefully you will have a chance to share more vids soon.
  9. Golattus
    Golattus Karting
    227
    JN
    To me, once valves are set in open position, spending time on a aftermarket silencer will not increase sound as this is hidden in the OEM cats and also in the headers. Aftermarket headers will bring apart from sound, lower engine bay temperatures, increased reliability as OEM flexible joint fades with past of time and becomes dangerous at some point when it gets old, and of course better high end response.
    So, IMHO, go for the headers and smile.
  10. obbob
    obbob Formula Junior
    Aug 14, 2017
    774
    Aftermarket muffler will still change the sound. Stock Speciale uses an H-pipe. Most aftermarket companies use an X-pipe.
    Also, valved systems will always be impacted by the muffler. Even with valves open, some of the exhaust will still go through the muffler or “quiet” path. This is why non valved systems are louder than a valved system, even if the valves are open.
    FFan5 likes this.
  11. plastique999
    Nov 9, 2008
    8,573
    SoCal
    Edward
    Thank you! I’m still extremely happy with the setup.
    In cabin, I will say that it doesn’t sound too loud...my DBS with Quiksilver exhaust and MurcieSV straightpiped are much louder in cabin.
    I’ll work on some more vids!
    Of note, I do have the Capristo remote linked up to my IPE system to open and close valves.
    Sent from my 16M
  12. Golattus
    Golattus Karting
    227
    JN
    S
    Speciale silencers are pure minimalism, nothing to do with standard 458.
  13. DRPM
    DRPM Karting
    Mar 25, 2016
    151
    Montreal Quebec
    Thanks for info
    I’m searching for solution for my new to me Speciale
    Disappointed with the pitch/sound following my Italia with valve controller which was superb.
    dustman likes this.
  14. Golattus
    Golattus Karting
    227
    JN
    First step, open the valves.
  15. DRPM
    DRPM Karting
    Mar 25, 2016
    151
    Montreal Quebec
    +1
    The issue is also above 5000 rpm
    I’m not hearing the Italia scream in the Speciale
    Sad they muffled this out at the factory.
  16. Golattus
    Golattus Karting
    227
    JN
    Next step, sport catalyst (200 cel or even 100).
    Then aftermarket headers or de restrict the OEM units.
    Thus you will find the sound you are missing.
  17. dustman
    dustman F1 Veteran
    9,023
    The true sound from Italia can’t be brought back. But as others have posted here, you can make improvements to the speciale.
    However I concur, disappointing. I heard it was to prepare people for how poorly the 488 would sound but I doubt that.
  18. Golattus
    Golattus Karting
    227
    JN
    I’m sorry but my Speciale with valves opened, 200 cel sport cats and headers simply rocks. Standard Italia cannot scream like her specially in the upper range.
    If what you miss from 458 are pops and cracks, well, then take it to a specialist to perform a repro.
  19. obbob
    Aug 14, 2017
    774
    For pitch, the biggest change will come from changing the muffler. Almost all aftermarket brands will increase pitch because they all use x-pipe designs. Stock Speciale uses h-pipe. If you want volume, then cats are the biggest restriction. Headers is a combination of both. Most people do not get headers because it essentially doubles the cost of the entire system, but I would recommend it if it’s in budget.
    In terms of brands, IPE is the most popular and highest pitch. Tubi is the loudest but low pitched.
    My personal favorites are Kline and novitec. Good luck making a decision!
  20. plastique999
    Nov 9, 2008
    8,573
    SoCal
    Edward
    Agree with both above...
    The S line on my 16M is a simple X pipe and it transforms the low baritone of the Scud to a much higher cleaner pitch.
    I used to think that it was the best F1 sound ever, but...
    I feel like my IPE setup on the S is even better - louder, higher pitch and tone and brings back some of the pops and gurgles. For $10k on a $350k+ car, it is cheaper than some CF options on your S and is an absolute must.
    Stock exhaust on both Scud and S is weak and meager.
    Sent from my 16M
    obbob likes this.
  21. DRPM
    DRPM Karting
    Mar 25, 2016
    151
    Montreal Quebec
    Who sells IPE in North America?
  22. plastique999
    Nov 9, 2008
    8,573
    SoCal
    Edward
    I see you are in Canada, I know a guy who sells them up there. Let me know if Interested and he can probably get you good pricing.
    Sent from my 16M
  23. DRPM
    DRPM Karting
    Mar 25, 2016
    151
    Montreal Quebec
    Yes
    PM sent
    thanks
  24. plastique999
    Nov 9, 2008
    8,573
    SoCal
    Edward
    Sent from my 16M
    veilstylez likes this.
  25. Malkey189
    Malkey189 Rookie
    Aug 15, 2022
    5
    London
    Eli
    Hi, I recently had the Novitec sport cats (200 cel) and their sport exhaust (stainles steel) put into my speciale but it hasn’t done much to the tone. What did you end up doing on yours to get a more f1 sounding tone?
