News
458 Spider engine lid gas struts
Discussion in 'Technical Q&A' started by Joegnsx, Nov 1, 2018.
  1. Joegnsx
    Joegnsx Formula Junior
    Dec 1, 2012
    927
    Valrico, FL & Franklin, NC
    Joe Gliksman
  2. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    330
    SW Suburbs of Chicago, IL
    Lawrence P.
    I need to replace mine as well. Any installation tips you can share? Tools used? thanks much
  3. Joegnsx
    Dec 1, 2012
    927
    Joe Gliksman
    Small screwdriver is all I needed—plus a stick to prop the lid open while replacing. There is a clip to pry out (only halfway) and the end of the strut pops off.
    ShadowLAP likes this.
  4. Regular Guy 01
    Regular Guy 01 Karting
    149
    Tacoma, WA
    Eugene Greer
    I replaced mine a couple of months ago also.
    It was very annoying when I went to open the lid and it wouldn't stay up on its own.
    I purchased mine from Scuderia Car Parts on line. Price was fair (not as low as you paid) but they are OEM parts.
    If you have your original struts you might consider having them rebuilt and keep them for the future.
    Strutwise out of BC Canada is the only shop I know that does this and its owner, Frank, is a good guy.
    He can even add a little bit of extra pressure to make them stiffer.
    Hopefully, the shafts are good and nobody as used Vise Grips on them. Even if they have (and they aren't too badly damaged) Frank can work with them.
    Quick turn around and great service...... what more can you ask for.
    Regards,
    Gene Greer
  5. ShadowLAP
    May 15, 2017
    330
    Lawrence P.
    Thanks to all of you who contributed comments. With you guidance I was able to replace my struts in 15 minutes. I purchased the original replacements from Ricambi. It was a simple and quick repair.
    Regular Guy 01 likes this.
  6. Regular Guy 01
    149
    Tacoma, WA
    Eugene Greer
    Awesome job on replacing your struts.
    If the ones you took off are in good physical condition, send them out to Frank at Strutwise and you will always have an extra set.
    You never know when you might need them......
    Regards,
    Gene Greer
