Unobtainium Supplies: 328 round dash vent | FerrariChat
Discussion in '308/328' started by Verell, Jan 8, 2015.
  1. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    #1 Verell, Jan 8, 2015
    I have just begun production of a repair kit containing the most commonly failing parts of the 328 round dash vents:
    The two louvers and the cross link are made from fiberglass reinforced UV & chemical resistant polyurethane (see 1st picture below).
    By the end of the month I will begin production of complete vent assemblies(2nd picture below)
    Part #s and prices are:
    61738800 328 round dash vent complete 328 3 Oz $195.00 + $9.05
    61738800-REPKT 328 dash vent repair kit – 2 louvers + link 328 2 Oz $97.00 + $8.25 S&I
    To order click on my name by this post & select [Send eMAIL to Verell]
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    #2 Verell, Jan 8, 2015
    Tillman asked for some improvements in this thread:
    http://www.ferrarichat.com/forum/308-328/252464-need-part-center-top-dash-ac-vent-86-328-gts.html
    The base material is stronger, AND I've done two things to strengthen the tabs:
    1. Added a buttress to each tab(see pictures below)
    2. Moulded inside each tab is U shaped piece of 20 gage wire. It loops around around each tab's hole with the legs of the U bent & anchored inside the buttress.
    These pictures below show the OEM louver tabs side by side with Unobtainium's buttressed tabs:
  3. TacElf
    TacElf Formula 3
    Aug 15, 2010
    1,719
    Seattle area
    Jeff
    That's a pretty clever way to strengthen the plastic. Nicely done.
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Forgot to mention, I'm also strengthening the link by casting lengths of wire inside with a small L end that fits inside the posts.
  5. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,203
    So. CA & NV
    Peter
    We need someone to reproduce the frames around the center console switches. They truly seem to be Unobtainium now.
    I'll send you my supply of Unicorn horn if needed to reproduce them.
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    #6 Verell, Jan 9, 2015
    Is #61819700 (#29 on TAV115) what you're asking about:
  7. Sigmacars
    Sigmacars Formula 3
    1,252
    I can make them no problem in my molding company but like always how many of them can i sell.if i can sell 100 pcs then $45-50 is ok
  8. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,627
    E ' ' '/ F
    Enzo Gorlomi
    #8 GrigioGuy, Jan 10, 2015
    What about the pins (for lack of better term) that the vanes attach to the circular surround and rotate on? Once those snap the whole thing drops into the vent tube. Have they been strengthened?
  9. TrojanFan
    Nov 17, 2008
    5,203
    So. CA & NV
    Peter
    No, I was referring to the orange, blue and yellow frames (what Ferrari calls them) that go under the fan cntrol knobs.
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    That's one of the reasons I'm still working on the circular parts. The pins are small & the surround material is pretty thin. My current thinking is to cast in steel dowel pins, but am open to suggestions.
  11. docdozer
    docdozer Karting
    Jun 17, 2009
    150
    Central Maine,
    Charley
    Are these the same vents that are used on the 308 and GT4?
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    No, the 308 & GT4 use a different part.
    I do have a NOS 308 vent, so making one is on the list, but most likely not for awhile.
  13. marczero
    marczero Karting
    Sep 18, 2014
    80
    Perth WA
    Marco
    GREAT! ..... Dash doesnt need to come out to replace for the 328 ? any hints on how to actually get the ring that holders the louvres ...i can seem to do it at all....
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    The louver ring just snaps into the dash mounted piece. The ring has a shallow (~0.5mm) groove that a mating ridge in the mating piece fits into.
    It's a tight fit, but it does just pop out. I ended up just pushing it out with my thumbs while holding the other piece, but I had it out in my hands. IIRC I also gave it a bit of rotating motion at the same time.
    I haven't tried to do this, but I suspect that it would have a bit more give if the louvers were removed first. The ring has about 2mm long posts that the louver pivots on. I removed my louvers by using a very stiff spatula to pry along the side of the louver until it popped out of the ring. Just be careful & not break the linkage by trying to move the released louver until the other louver is also released.
  15. AHudson
    AHudson F1 Rookie
    2,781
    Florida
    Adams Hudson
    Wow Verell, didn't know you were working on this! I broke the living heck out of mine in the fall, just hit it a bit hard and the whole thing dominoed into its little hole.
    Fished it out and used washers on either side of an epoxy mess. Works, but yours will be so much better.
    I've bought Verrels stuff before, for my Boxer's pull latch (engine and boot) to 512TR lamp holders, all of excellent over-engineered quality. If Verrel had worked for Ferrari at time of production, we'd be up there with Camry's on reliability.
  16. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,542
    Dumpster Fire #31
    SMG
    how about casting the part with a divot or pilot hole and fitting a spring loaded shell in it?
    J.W. Winco, Inc. - Spring Loaded Shells
    should hold and also allow for assy without bending or fatiguing the part. just a thought.
  17. TrojanFan
    Nov 17, 2008
    5,203
    So. CA & NV
    Peter
    #17 TrojanFan, Jan 27, 2015
  18. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    #18 Verell, Jan 28, 2015
    Conceptually I like the idea. From a quick look at the shell specs, the smallest one (2mm dia) might work. Have to make some measurements as I'm not sure there's room for a 12mm deep hole. IIRC, there's only about 6 - 8 mm of total space in that area.
    Still, maybe I can find a smaller one from another source, or cut the spring & shell down.
    Alternative might be to put the shell in the louver & the mating hole in the ring, I think this is more promising.
    Will think about it after I get dug out from the 28" or so of snow the Blizzard of '15 dumped on me yesterday.
  19. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    I'm sure interested, and I know others are. BTW, the way the frames are painted, translucent color (blue, orange, or yellow) is painted on the frame top, which is clear plastic. Then the black "graphics" in painted over the top. The frame edges are also painted black. If someone could create the black graphics as a stick-on, it would be easy to recondition the old frames. The graphics are the same for all 4 fan frames. Just a thought.....
  20. GrigioGuy
    Nov 26, 2001
    33,627
    E ' ' '/ F
    Enzo Gorlomi
    Would they then work with the stock rings? Or does that eliminate the rebuild kits?
  21. Kidasters
    Kidasters Formula Junior
    Oct 4, 2013
    546
    Houston, Tx
    Ken
    Holy moley Verell! Stay warm!
    Ken
  22. AP328
    AP328 Karting
    89
    Canada
    I presume that the complete dash vent at $195 is per vent, correct?
  23. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    This is all a SWAG, but I'm thinking that if I can just make the louver pivot holes deeper then they still would be backwards compatible!
    Just to set expectations, I'm running slower than planned on the molds for the two rings. Part of the delay is figuring out a pivot pin solution.
  24. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    Yes
  25. AP328
    AP328 Karting
    89
    Canada
    Any update?
