488/458 Sound Comparison | Page 3 | FerrariChat
Discussion in '458 Italia/488/F8' started by jaa1359, Mar 24, 2016.
  1. cavsct94
    cavsct94 Karting
    Aug 26, 2013
    179
    Indianapolis, IN
    The 4_8 is better! Wash. Rinse. Repeat.
    Viperjoe likes this.
  2. AlfistaPortoghese
    AlfistaPortoghese Moderator
    Mar 18, 2014
    3,778
    Europe, but not by much.
    Nuno
    Same here. Turned it on once, the day I got the car, just to see if it worked and if not, so I could have it fixed/replaced under warranty.
    Apparently I have the JBL sound system and speakers on the back of my seats, but can't even tell you if they're any good or not :D
    Kind regards,
    Nuno.
    xfrgtr and Jasflora like this.
  3. AlfistaPortoghese
    Mar 18, 2014
    3,778
    Nuno
    I believe both are wonderful Ferraris. It is my humble opinion that the 458 has a very large fan base, made up of owners and enthusiasts, because it's special. The 488 also has a very large fan base, because it's fast. Not that the 458 isn't fast nor that the 488 isn't special too, but I believe if something is special, it'll have a lasting impact, whereas if something is just fast/faster, it's impact tends to wear off in a more pronounced fashion and/or disappear over time, namely when the next fastest thing is released.
    Kind regards,
    Nuno.
    Jasflora likes this.
  4. 3POINT8
    3POINT8 F1 Veteran
    Jan 23, 2014
    5,205
    couldn't agree more
  5. Jasflora
    Jasflora Karting
    Sep 30, 2018
    62
    Leeds United Kingdom
    Jas flora
    I seem to gravitate to tunnels when I drive mine. Not sure why ...
    AlfistaPortoghese likes this.
  6. Golattus
    Golattus Karting
    227
    JN
    Hi
    I do drive regularly an Speciale and occasionally a 488 of a friend. Also I have a McLaren, turbo of course.
    Impossible to compare both engines. One is torque and growling everywhere (and this hesitating turbo response the first second), the other revvy, screams up there upscale and direct response on the gas.
    End of an era. 488 us better car for sure but...
  7. Jasflora
    Jasflora Karting
    Sep 30, 2018
    62
    Jas flora
    Sadly I had to revert to factory settings as car started misfiring at low revs and error message p2440 and p2442 came up this morning. Ferrari tech said he has seen a lot of these and it’s brst to fit capristo. Car now drives perfect but doesn’t sound half as good ☹️
  8. PJxxx
    PJxxx Karting
    Sep 14, 2017
    129
    PJ Cusano
    Hello Jasflora. Did you pin the valves open or did you use a switch? I’ve just plugged my lines and am hoping not see errors.
  9. ForeverNA
    ForeverNA F1 Rookie
    2,535
    I think it's decent enough....
  10. Jasflora
    Jasflora Karting
    Sep 30, 2018
    62
    Jas flora
    I had dealer pin them
    Was fine for a few days sound was fantastic
    Yesterday it started mis firing in low gears lots of loud pops no error messages on dash but I knew something was wrong. Took it to dealer who found pending errors on left bank. Unpinned valves and it runs fine though too quiet. He said only solution is a capristo or equivalent
    PJxxx likes this.
  11. Cigarzman
    Cigarzman F1 Veteran
    I had my valves pinned open on my 458 and my 488 with no issues ever. Best , Kirk.
    Viperjoe and PJxxx like this.
  12. wrs
    wrs F1 World Champ
    13,732
    Lakeway, Texas
    William
    I bought the Tubi straight pipe exhaust which has the valves so that the ECU can manage backpressure as designed. The dealer service rep told me this was the best way to go. I keep the car in RACE and the valves open at 2500 RPM. The sound of this exhaust is really an improvement because it removes the baffle/muffler. I am very happy with the improvement in sound and have not had any CELs or bad performance.
  13. dustman
    dustman F1 World Champ
    11,167
    Without a shadow of a doubt the 458 sounds significantly better.
    488 is without a doubt significantly quicker.
    Nothing silly, just facts.
    Caeruleus11, xfrgtr and tekaefixe like this.
  14. dmark1
    dmark1 F1 World Champ
    BANNED Owner
    Feb 26, 2008
    11,439
    Americas Team Headquarters
    Mark
    Wonder how the sounds of a Speciale compare with a Pista. Haven't heard the Pista "live" so I have no way of comparing. The stock Speciale sound was the only thing I found disappointing on my car. Hope the Pista is better.
  15. plastique999
    plastique999 F1 Veteran
    Nov 9, 2008
    8,827
    SoCal
    Edward
    Did you consider exhaust like Capristo on the S?
    Sent from my 16M
  16. Jasflora
    Jasflora Karting
    Sep 30, 2018
    62
    Jas flora
    Yes, I thought I would try pinning them first
    The mid firing put me off and I’m pinned them. I miss the soundtrack though so will have the Capristo installed for spring.
  17. Viperjoe
    Viperjoe F1 Rookie
    Same here. The vacuum diaphragm bypass valves on my 2018 488 were plugged on day 1; 1600 miles and 7 months later, absolutely no issues whatsoever. Just a great sounding exhaust.
  18. Cigarzman
    Joe, you better get driving as I’m at 3500 miles in 6 months.
    Viperjoe and Shadowfax like this.
  19. BlueIn2Red
    BlueIn2Red Karting
    Sep 29, 2006
    234
    Tring, UK
    The 488 sounds great for what it is, but there is no substitute for revs in my opinion - the extra 1500 in the case of the 458 making all the difference in terms of that visceral scream.
  20. dustman
    11,167
    Agree with you and sadly there was no fix to be had to get the wonderful sound back like the Italia or spider.
    I’ve always wondered if ferrari intentionally made the speciale sound worse as prep for the disappointment of the 488. They didn’t have to change the internals for the speciale but chose to.
    tekaefixe likes this.
  21. dustman
    11,167
    Spent some time driving the 488 spider today and reinforced my opinion the sound is significantly inferior vs the 458.
    The 488 is far more rigid and compliant as a spider though. Wonderful improvement over the 458 spider!
    But I found myself bored even when pushing hard.
    Perhaps the Perf Spyder has jaded me a touch but I wasn’t enthralled at all in the 488. No offense meant.
    xfrgtr and Caeruleus11 like this.
  22. tekaefixe
    tekaefixe Formula 3
    May 10, 2012
    1,201
    CH
    Paulo
    How do you compare the rigidity of the 488 Spider with your lambo?
  23. dustman
    11,167
    Drove 488 spider again this morning.
    If the Perf is a 9/10 in terms of rigidity, the 488 is 8/10. Pretty damn good.
    You could drive the 488 cross country no problem. Never felt that way in any of the 458's I owned.
  24. tekaefixe
    tekaefixe Formula 3
    May 10, 2012
    1,201
    CH
    Paulo
    The 458 spider would be a 6? Did you drive a spider mclaren? Is it a 10?
    Thank you!!
  25. ScuderiaCarParts
    157
    London, UK
    Scuderia Car Parts
