Buy
488 Brakes from track use
Discussion in 'Tracking & Driver Education' started by MVPJEFFMVP, Jul 7, 2021.
  1. MVPJEFFMVP
    MVPJEFFMVP Rookie
    Aug 14, 2011
    19
    New Jersey
    It was suggested I post this here since the brakes appear work from minimal track use:
    I'm close to closing a deal on a 2016 488 from a private seller who just had the car's annual service done today. The inspection by the dealer noted 50% brake wear. The car has 6200 miles. Is this extreme wear for only 6200miles? I know the owner was reported to have taken the car to two track days sponsored by the selling dealership.
    With that being asked, without expecting to track the vehicle, what would be the expected mileage remaining on the brakes? If needing to be replaced, is anyone aware of the replacement cost?
    Thanks in advance!
  3. LVP488
    LVP488 F1 Rookie
    Jan 21, 2017
    3,797
    France
    The "computed" brake wear is not a very reliable figure - to have an accurrate diagnostic I suppose one would need to remove the rotors and weight them.
    Another issue that may not be reflected in the reported wear is the fact that the surface of the disc may become irregular (one could feel it by touching it) resulting in extremely accelerated pads wear.
    In Europe the full brakes replacement (discs, pads, labour) is around 16 K€, maybe around 20 K$ in the US. At this price some alternative (switching to Surface Transform CCM or Giro disc steel discs, for instance) may be considered.
    My 488 had dead CCM discs after less than 10,000 miles, I did more than two track days though but was cautious with cooling the brakes. I replaced them with Surface Transform discs with Pagid pads.
  4. Alexcle
    Alexcle Karting
    121
    Alex D
    hi, I looked for steel rotors for an F12 and I cannot see giro or surface transform making something compatible. what other company's do you recommend and how much should we expect for a shop to switch the rotors and pads out?
    last but not least, is there anyway to add brake ducting on a f12?
    thank you for reading.
  5. SV488
    SV488 Rookie
    Jun 4, 2021
    4
    Sesha Varadarajan
    Hi... I regularly track my 488GTB... A car that's pushed well on the track will run through a set of pads in about 3 days (about 220-240 track minutes). I assume when they say 50 brake life he meant the pads..
    The rotors themselves last far longer.. I seem to consume about 10 percent over the same 3 days.
    Sent from my SM-N950U1 using FerrariChat.com mobile app
    mdrums likes this.
  6. windsock
    windsock Formula Junior
    612
    Arlington, Washington
    Giro disc has them you may need to give Mike a call.
  8. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    5,261
    Hopefully some place nice.
    A.B
    If you contact Craig at Surface Transforms he can help you. They make discs for the entire 4X8/F8 range as well as the 812 and F12 TDF. You will need to send them a front and rear disc, but other than that, they can do it.
    PM me if you want his contact details.
  9. SV488
    SV488 Rookie
    Jun 4, 2021
    4
    Sesha Varadarajan
    Yup... I just converted my 488 to running Girodisks with pads from Cobalt racing... Has good brake feel and no hint of fade running 20min sessions at the track. It is more noisy on the street and I would go with street pads if the use is baised to street.
    mdrums likes this.
  10. Il Co-Pilota
    5,261
    A.B
    That's one thing I like about the Surface Transforms discs I have. I can run RSC1 pads on street and RSL1 on track. No fade at over 700c, lightweight, and resurfaceable.
  11. SV488
    SV488 Rookie
    Jun 4, 2021
    4
    Sesha Varadarajan
    After I saw one of your earlier posts on SST I looked at that as a serious option. On paper it has all the benefits of Carbon ceramics (fade, weight, brake dust reduction) and solves the one problem (consumable cost for track junkies). Just that in the smaller market I live (Portland Oregon) no one was familiar with them plus the practicality of waiting for the rotors to come back (or having a spare set) dissuaded me. I am still considering those for other track car (GT3) and trying to find a onotber shop here.
  13. mdrums
    mdrums Formula 3
    Jun 11, 2006
    1,110
    Tampa
    Check out the positive reviews of the SST rotors on Rennlist for your GT3. A couple of my track friends ran them with excellent results. If I was still a track rat and wanted to run carbon ceramic rotors and did a ton of events and had the $ I'd definitely run them.
  14. MoreGarages413
    MoreGarages413 Karting
    Jan 21, 2019
    65
    Suburban Philadelphia PA
    Jay B
    I’ve not heard of surface transforms previously, and am getting closer to rotor replacement on my 458. Do folks really get equal or better performance/life out of their significantly lower cost product?
  15. Il Co-Pilota
    5,261
    A.B
    Yes. And it's not that much cheaper. They are just not taxed as Ferrari parts are. If yoy look at it from a net price point, the ST rotors are significantly more expensive. Brembo and Ferrari just carry a huge premium.
    It's not a product made in a small shed. They are oem for brands like Mercedes, Koenigsegg etc. It's a real product.
    If you look at the price of OE Ferrari discs without dealer markup and the cost for dealer installation, i.e if you bought them from Eurospares, the OE is only 10-15% more than the ST set. The savings lie in the longer disc life, longer pad life, and the fact that they can be resurfaced a few times for MUCH less than the initial purchase cost. But as net price of the materials, production costs and time, they are much more expensive than Brembos.
