488 clock needs changing | FerrariChat
Discussion in '458 Italia/488/F8' started by Scott4503, Nov 20, 2020.
Tags:
  1. Scott4503
    Scott4503 Rookie
    Dec 1, 2014
    31
    seattle
    scott halliday
    anyone know the exact steps to change the time on the 488? i cant seem to find any videos and its definitely Not the same as the 458
  2. docster
    docster Formula Junior
    267
    Oregon
    David
    Should be able to do this from the Settings menu in the left TFT display. (This can be done with the ignition on but engine off, or with engine running but car stationary. However, the Date-Hour submenu cannot be accessed when the car is being driven.) Press the Back button on the left side of the dash to bring up the left TFT Status screen; using the right-pointing button on the left TFT screen control "wheel," toggle across to Settings (gear wheel icon at far right) and press OK in the center of the control. This brings up a menu of several adjustable items, one of which is Date-Hour. Use the down button on the control to highlight this, then press either OK or the right-pointing button to enter the Date/Hour setting submenu, toggle down to highlight Time, press OK to access & set to desired time. (12-hr or 24-hr format can also be chosen here.)
    Not particularly intuitive, but it works!
  3. AD211
    AD211 Formula 3
    Aug 19, 2017
    1,055
    South Carolina
    Andy
    docster likes this.
  4. Scott4503
    Scott4503 Rookie
    Dec 1, 2014
    31
    seattle
    scott halliday
    Thank you! Love my car but this is always difficult. Thanks. I’ll try it
  5. jdlegg
    jdlegg Karting
    Dec 22, 2009
    231
    Bryan
    James D
    Or just wait 5 months and it will be correct again. :)
  6. Scott4503
    Scott4503 Rookie
    Dec 1, 2014
    31
    seattle
    scott halliday
    Very funny
  7. Scott4503
    Scott4503 Rookie
    Dec 1, 2014
    31
    seattle
    scott halliday
    Ok
    So what if when you push the left side BACK button, while sitting, nothing happens?
    But while driving it does work but only to dimming menu items
  8. docster
    267
    Oregon
    David
    Maybe press Back button while driving to get to Status screen, then stop in a safe place and see if going to Settings has Date-Hour option available? If not, maybe go back to Status screen, shut engine off & try again while TFT screen is still active...
  9. cole328
    cole328 Formula Junior
    May 9, 2014
    882
    Ha. Darn. That’s a lot of steps ! What are the. Italians thinking ??
  10. AD211
    AD211 Formula 3
    Aug 19, 2017
    1,055
    South Carolina
    Andy
    Tried today too. To no avail. Let us know if you figure the craziness out!
  11. gilly6993
    gilly6993 Formula 3
    Aug 20, 2009
    2,479
    Longmeadow, MA
    Eric
    It is quite the adventure to change the clock in these cars. Good luck. It’s easy once you figure it out though and then proceed to forget when DST rolls around.
  12. docster
    267
    Oregon
    David
    In my 2018 488 GTB, the quoted procedure(s) will consistently work when getting in car & turning ignition on by pressing Start/Stop button without depressing brake pedal, and/or starting car without driving off. If that's not the case with yours, it would appear there are electrical gremlins at work! :(
