488 GTB (458 replacement) | Page 187 | FerrariChat
Discussion in '458 Italia/488/F8' started by synergy, Aug 7, 2014.
  1. Gene-O
    Gene-O Formula Junior
    Mar 10, 2015
    271
    You may be right. Just not a very professional way to review a car where the sound is a big part of the discussion. A bit further on in the video, there's actually a portion where the exhaust falls silent, and only the dialogue is audible... but the car is still moving...
    My point is, in most of the more mainstream reviews of this car, the sound perspective is clearly "inside" the car and you can tell it's so, unless they specifically tell you up front that they put a microphone outside by the tailpipe. Chris Harris and EVO come to mind of well recorded reviews.
    But hey, I know it's just whistling in the dark... they'll sell them all, and those of us that want to collect it will do that... those of use that want power over anything else will do that too... and those of us that like what we got, will keep it. Everybody happy !!
  2. TopspeedPT
    TopspeedPT Formula 3
    Jul 6, 2012
    1,103
    Portugal
    [ame]http://www.youtube.com/watch?v=NOSyrBB7rlk[/ame]
  3. 458italia2014
    458italia2014 Formula 3
    Aug 3, 2013
    1,048
    See I don't think the 488 sounds like every other turbo car out there. I think it still has that Ferraris sound, not as high pitched obviously but it is still there.
  4. Lesia44
    Lesia44 F1 World Champ
    17,890
    It's definitely got something of the F430 going on. It has the same baritone.
  5. 95spiderman
    95spiderman F1 World Champ
    17,429
    ny
    488 sounds a bit like a modified modern Porsche to me. not bad but not Ferrari amazing either.
  6. koop
    koop Formula Junior
    Apr 30, 2011
    811
    heres a great sounding turbo ferrari!
    [ame]http://www.youtube.com/watch?v=H4op55iXWsk[/ame]
  7. mik458spider
    mik458spider Formula 3
    Jan 13, 2013
    1,386
    It's not the same between a turbocharged engine built from scratch and adding turbo on highly tuned NA engine. When built from scratch, the engine is not highly tuned, totally depending on the turbo to get the expected power. That's why for the 488, even you get an aftermarket exhaust, it just won't sound like the NA race car, because the problem is not in the exhaust, it's in the engine. It's not a highly tuned engine.
    If you add a turbo on a highly tuned NA, the sound will still scream. It's just the engine won't last so long this way.
  8. dustman
    dustman F1 World Champ
    11,413
    The 488 spider in the video review did not sound great....no excitement.
    On the list now for one, but plenty of time to decide.
  9. ScrappyB1972
    ScrappyB1972 Karting
    Feb 20, 2015
    113
    Um, not. I think you're misguided in thinking that a high static compression ratio is the only way an engine can be considered as being in a high state of tune.
  10. qwertstnbir
    qwertstnbir Formula 3
    Jul 14, 2013
    1,620
    488 is not for sound lover, people need to accept this or chose other car
  11. Lesia44
    17,890
  12. Milanno
    Milanno Formula Junior
    Feb 23, 2012
    949
    Well said!
  13. singletrack
    singletrack F1 Veteran
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    Or they could spend 5-8k and make it louder very easily with an aftermarket option; which we haven't even heard yet. It still sounds better than many cars out there.
  14. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
  15. Milanno
    Feb 23, 2012
    949
    Lets face it, most Ferrari owners are not into aftermarket thing + you are playing with losing your factory warranty.
  16. qwertstnbir
    Jul 14, 2013
    1,620
    sound will be louder but still deformed by turbine
  17. Lesia44
    17,890
    Yes, the problem is not that it's not loud enough. Nor is the problem that it's a particularly bad sound. The problem is lack of range. It's all rather 'one note' so you don't get that aural cue that the revs are rising as you do in the 458 when the anger rises. The 458's engine note goes to different places which reflect what the engine is doing. The 488s sound always seems to be in the same place so all you get is more of the same.
  18. qwertstnbir
    Jul 14, 2013
    1,620
    serous question: it's technically possible to remove turbine from 488? it would still have power around 500 hp?
  19. Lesia44
    17,890
    It probably a certainty that the engine is tuned in concert with the turbos so simply removing them would unbalance things. But, given that turbos are an external add on I'd guess that, in theory at least, they could be removed and you'd still have a functioning unit.
    It's an interesting thought. Mind you, would you really do away with all that extra performance just for 20% more sound?
  20. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    Muffled sure....and the lower redline hurts the symphony as well. But we are comparing to some of the best sounding Ferrari's ever (and some other V10s etc) so, have to keep that in mind.
  21. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    No. You would have to change a ton of internals as the compression of a turbo motor is far different than NA.
    If Ferrari built the best 3.9L NA V8 they could, it would probably put out around 500-520HP.
  22. singletrack
    Mar 16, 2011
    5,805
    Pittsburgh, PA
    It would still work with massive retuning, but it would suck. It wouldn't be responsive, and it would probably be around 400HP IMHO; maybe less.
    488 Compression ratio: 9.4:1
    458 Compression ratio: 12.5:1
    Speciale Compression ratio: 14:1
  23. Lesia44
    17,890
    Yes. When I used the term 'a functioning unit' I meant in the sense of functioning adequately at best rather than as we would expect of a Ferrari.
  24. Graz
    Graz Formula 3
    Oct 15, 2012
    2,329
    New Jersey and Florida
    Graziano
    Hmmm that might be like a 458 just less power. Good idea :)
